查看: 1908|回复: 2
[已解决] [求助]:哪位高人帮我解答下小问题(问题已解决)
发表于 2008-6-5 20:24:55 | 显示全部楼层 |阅读模式
下面这段代码是在图中标出每点的XY坐标值,虽然功能已经实现了,但还有点小毛病,运行完显示“no function definition: nil”,我想是否是“TEXT”语句还未结束响应,不知要如何结束响应,如果不用IF语句,程序就正常结束,这又是为什么,望哪位高手帮我解答下,谢谢了!
(defun c:pin (/ H)
(command "osmode" "8")
(setvar "orthomode" 0)
(setq H (CDR (ASSOC 40 (TBLSEARCH "STYLE" (GETVAR "TEXTSTYLE")))))
(setq p (getpoint "\n请指定要标注的坐标点:"))
(setq x (car p))
(setq y (cadr p))
(setq x (rtos x 2 2))
(setq y (rtos y 2 2))
(setq x (strcat "X=" x))
(setq y (strcat "Y=" y))
(setq p1 (getpoint p "\n请指定写入标注的位置:"))
(command "layer" "s" 1 "" )
(command "color" "byl" )
(command"line" p p1 "")
(IF (= H 0.0)
( (command"text" (list (car p1) (cadr p1)) 3 0 x);系统字高等零
(command"text" (list (car p1) (- (cadr p1) 5)) 3 0 y))
( (command"text" (list (car p1) (cadr p1)) 0 x );系统字高大于零
(command"text" (list (car p1) (- (cadr p1) (* h 1.35) )) 0 y )
(command "osmode" "191")
问题已解决:
http://p4.xdcad.net/forum/showth ... 3341189#post3341189
发表于 2008-6-5 21:08:45 | 显示全部楼层
  1. (defun c:pin (/ H)
  2.   (command "osmode" "8")
  3.   (setvar "orthomode" 0)
  4.   (setq H (CDR (ASSOC 40 (TBLSEARCH "STYLE" (GETVAR "TEXTSTYLE")))))
  5.   (setq p (getpoint "\n请指定要标注的坐标点:"))
  6.   (setq x (car p))
  7.   (setq y (cadr p))
  8.   (setq x (rtos x 2 2))
  9.   (setq y (rtos y 2 2))
  10.   (setq x (strcat "X=" x))
  11.   (setq y (strcat "Y=" y))
  12.   (setq p1 (getpoint p "\n请指定写入标注的位置:"))
  13.   ;; (command "layer" "s" 1 "")
  14.   (command "layer" "s" "0" "")
  15.   (command "color" "byl")
  16.   (command "line" p p1 "")
  17.   (if (= H 0.0)
  18.     (progn
  19.       (command "text" (list (car p1) (cadr p1)) 3 0 x) ;系统字高等零
  20.       (command "text" (list (car p1) (- (cadr p1) 5)) 3 0 y)
  21.     )
  22.     (progn
  23.       (command "text" (list (car p1) (cadr p1)) 0 x) ;系统字高大于零
  24.       (command "text"
  25.                (list (car p1) (- (cadr p1) (* h 1.35)))
  26.                0
  27.                y
  28.       )
  29.     )
  30.   )
  31.   (command "osmode" "191")
  32. )
发表于 2008-6-5 23:27:06 | 显示全部楼层
  6.   (setq x (car p))
  17.   (if (= H 0.0)
  18.     (progn
  21.     )
  22.     (progn
  24.       (command "text"
  26.                0
  27.                y
  28.       )
  29.     )
  30.   )
  32. )
GMT+8, 2026-11-22 10:50 , Processed in 0.350110 second(s), 14 queries , Gzip On, File On.
