查看: 861|回复: 1
[求助]:高手们帮忙修改一下程序,零件号标注
发表于 2008-6-6 08:21:25 | 显示全部楼层 |阅读模式
从网上找了一个源代码,但老是运行出错,大家帮忙看看,谢谢各位啊!
(defun C:Bxh (/ p1 p2 p3 ang bx bxh radi txth) ;标序号
  (setq radi 5) ;圆圈半径
  (setq txth 5) ;字高
  (if (not bx) (setq bx 1))
  (setq p1 (getpoint "\n请选择起点:")) ;在零件上选一点
  (setq p2 (getpoint "\n请选择第二点或回车表示无第二点")) ;标注位置处一点
  (setq bxh (getint (gstr "\n请输入序号" bx))) ;序号数
  (if bxh (setq bx bxh))
  (cond (p2
   (command "layer" "set" 2 " ") ;改到画细线图层
   (setq ang 1 (angle p1 p2))
   (setq p3 (polar p1 ang (-(distance p1 p2) radi))) ;画圆、线
   (command "pline"
   (polar p1 ang 1 0.25)
   "w" 0.5 0,5 "A" "CE"p1"A"359.9"L""W"0 0 p3"")
   (command"circle"p2 radi)
   (command "layer" "set" 6 " " ;改到写文字图层
   "text" "J" "M" p2 txth 0 bx) ;写文字
   ((not p2) ;如果在零件中直接标注
   (Command "circle" p1 radi) ;画圆
   "text" "J" "M" p1 txth 0 bx) ;写文字
  (setq bx (+ bx 1))
  (princ)
  ;-----------------------*-*6
已领礼包: 12486个
发表于 2008-6-6 20:23:18 | 显示全部楼层
出的什么错?
GMT+8, 2026-11-4 05:03 , Processed in 0.448316 second(s), 34 queries , Gzip On.
