查看: 1400|回复: 0
[LISP程序]:一段打印新开图纸的代码 - 请高手指点哪里出错了
发表于 2008-8-25 22:24:58 | 显示全部楼层 |阅读模式
假如打开了autocad,当前图纸为drawing1.dwg, 现在想写一段代码让它打开d:\test\drawing3.dwg并且用PDF995打印机把它打印成PDF, 代码如下,但是打印出来的总是drawing1, 而不是想要的drawing3, 请个位高手斧正。谢谢!
(defun c:go ()
  (setq AcadObject (vlax-get-acad-object))
  (setq    ActiveDocument
     (vla-get-ActiveDocument AcadObject)
  (setq AcadDocuments (vla-get-documents AcadObject))
  (setq    AcadDocument
     (vla-open AcadDocuments
           "d:\\test\\drawing3.dwg"
  (vla-put-activedocument  AcadObject  AcadDocument)
  (vla-plottodevice
    (vla-get-plot
      AcadDocument
    "PDF995"
  (vla-close AcadDocument :vlax-false)
  (vlax-release-object AcadDocument)
  (vlax-release-object AcadObject)
GMT+8, 2026-11-22 09:35 , Processed in 0.343214 second(s), 9 queries , Gzip On, File On.
