查看: 956|回复: 0
[教学]:恭贺灯火重出江湖,送贺礼一份...
已领礼包: 145个
发表于 2002-5-27 11:28:29 | 显示全部楼层 |阅读模式
ADN开发资料,通过VBA如何获得块的常量属性
  1. [FONT=courier new]
  2. How to get the constant attributes of a blockref through VBA
  3. ID    12559
  4. Applies to:    AutoCAD 2000
  5. AutoCAD 2000I
  6. AutoCAD 2002
  7. Date    1/10/2002
  8. This document is part of    Attribute   Block Reference   COM-ActiveX Interfaces   VBA
  9. Question
  10. I have a drawing that has many different blocks, each block has three constant
  11. attributes (tags 'code' 'desc' and 'linfoot'). How do I get the block name,the
  12. attribute values, and find how many times the block is inserted and put this
  13. information into a spreadsheet using VBA?
  14. Answer
  15. You can get the block information from the block definition in the block table
  16. using VBA.
  17. The following sample demonstrates this by getting all the attributes of all the
  18. block references found in model space. You need to create a simple form which
  19. contains a listbox named ListBox1 and a button that starts the following
  20. procedure:
  21. Private Sub CommandButton1_Click()
  22.   Dim elem As Object
  23.   Dim block As AcadBlock
  24.   Dim item As Object
  25.   Dim Array1 As Variant
  26.   Dim count As Integer
  27.   Dim MBtest1 As String
  28.   Dim str As String
  29.   For Each elem In ThisDrawing.ModelSpace
  30.     If elem.EntityName = "AcDbBlockReference" Then
  31.         If elem.HasAttributes Then
  32.         Array1 = elem.GetAttributes
  33.         For count = LBound(Array1) To UBound(Array1)
  34.             If (Array1(count).EntityName) = "AcDbAttribute" Then
  35.                 MBtest1 = Array1(count).TagString & " - " &
  36. Array1(count).TextString
  37.                 ListBox1.AddItem MBtest1
  38.             End If
  39.         Next count
  40.         'Get the block definition from the block table
  41.         str = elem.Name
  42.         Set block = ThisDrawing.Blocks.item(str)
  43.         For Each item In block
  44.           str = item.EntityName
  45.          'Get the Constant attributes
  46.           If item.EntityName = "AcDbAttributeDefinition" Then
  47.             If item.Mode = acAttributeModeConstant Then
  48.               ListBox1.AddItem item.TagString & " - " & item.TextString
  49.             End If
  50.           End If
  51.         Next item
  52.         End If
  53.     End If
  54.    Next elem
  55. End Sub
  56. [/FONT]
GMT+8, 2026-11-2 06:14 , Processed in 0.529131 second(s), 32 queries , Gzip On.
