查看: 5424|回复: 7
比较简单实用的小程序,等分曲线选择集
发表于 2013-4-11 09:58:45 | 显示全部楼层 |阅读模式
直接上代码了
[C#] 纯文本查看 复制代码
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace Fsxm.Acad
    public class BreakCurve
        //全局变量,默认等分的段数
        static int n = 2;
        static double dist = 5;
        static string Mod = "N";
        //等分曲线选择集
        [CommandMethod("AveragesCurve", CommandFlags.UsePickSet)]
        public void AveragesCurveSs()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            #region 用户输入=================================================
            while (true)
                if (Mod == "D")
                    PromptDistanceOptions op = new PromptDistanceOptions("\n输入定距等分的距离[定数等分(N)]", "N");
                    op.DefaultValue = dist;
                    op.AllowZero = false;
                    PromptDoubleResult drst = ed.GetDistance(op);
                    if (drst.Status == PromptStatus.OK)
                        Mod = "D";
                        dist = drst.Value;
                        break;
                    else if (drst.Status == PromptStatus.Keyword)
                        Mod = "N";
                    else if (drst.Status == PromptStatus.Cancel)
                        return;
                    else
                        break;
                else if (Mod == "N")
                    PromptIntegerOptions iop = new PromptIntegerOptions("\n输入定数等分的段数[定距等分(D)]", "D");
                    iop.DefaultValue = n;
                    PromptIntegerResult irst = ed.GetInteger(iop);
                    if (irst.Status == PromptStatus.OK && irst.Value >= 2)
                        Mod = "N";
                        n = irst.Value;
                        break;
                    else if (irst.Status == PromptStatus.Keyword)
                        Mod = "D";
                    else if (irst.Status == PromptStatus.Cancel)
                        return;
                    else
                        break;
            PromptSelectionResult srt = ed.GetSelection
                (new SelectionFilter(new TypedValue[] { new TypedValue(0, "arc,circle,ellipse,*line") }));
            SelectionSet ss;
            if (srt.Status == PromptStatus.OK)
                ss = srt.Value;
            else
                return;
            #endregion ======================================================
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord Spase = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                if (Mod == "N")
                    foreach (SelectedObject obj in ss)
                        Curve cv = (Curve)tr.GetObject(obj.ObjectId, OpenMode.ForWrite);
                        foreach (DBObject dbobj in AveragesCurve(cv, n))
                            Spase.AppendEntity((Entity)dbobj);
                            tr.AddNewlyCreatedDBObject(dbobj, true);
                else//定距等分
                        Point3d pt = new Point3d(); bool sel = true;
                        double dist_Ok = dist;
                        if (obj is CrossingOrWindowSelectedObject)
                            var cobj = (CrossingOrWindowSelectedObject)obj;
                            pt = cobj.GetPickPoints()[0].PointOnLine;
                        else if (obj is FenceSelectedObject)
                            var cobj = (FenceSelectedObject)obj;
                            pt = cobj.GetIntersectionPoints()[0].PointOnLine;
                        else if (obj is PickPointSelectedObject)
                            var cobj = (PickPointSelectedObject)obj;
                            pt = cobj.PickPoint.PointOnLine;
                        else
                            sel = false;
                        if (sel && cv.StartPoint.DistanceTo(pt) > cv.EndPoint.DistanceTo(pt))
                            dist_Ok = -dist;
                        foreach (DBObject dbobj in AveragesCurve(cv, dist_Ok))
                tr.Commit();
        //定数等分单条曲线
        public DBObjectCollection AveragesCurve(Curve cv, int n)
            double ep = cv.EndParam;
            double len = cv.GetDistanceAtParameter(ep);
            double split = len / n;
            DoubleCollection pas = new DoubleCollection();
            if (cv.Closed)                //闭合曲线要先断开
                pas.Add(cv.StartParam);
            for (int i = 1; i < n; i++)
                pas.Add(cv.GetParameterAtDistance(i * split));
            cv.Erase();
            return cv.GetSplitCurves(pas);
        //等距等分单条曲线(dist<0反向等分)
        public DBObjectCollection AveragesCurve(Curve cv, Double dist)
            double dst = 0;
            //从最后开始等分
            if (dist < 0)
                dist = -dist;
                dst = (cv.GetDistanceAtParameter(cv.EndParam) % dist) - dist;
            if (cv.Closed) pas.Add(cv.StartParam);//闭合曲线要先断开
            while (true)
                dst += dist;
                if (dst >= len) break;
                pas.Add(cv.GetParameterAtDistance(dst));
            cv.Erase();
评分
参与人数 1D豆 +2 收起 理由
XDSoft + 2
查看全部评分
发表于 2013-4-11 13:45:35 | 显示全部楼层
{:soso_e179:}学习了,不过这代码挺长的,如果复杂一点的功能那不是.......
嘿嘿,当然要比lisp长N倍哈,但是执行速度秒杀lispN倍  发表于 2013-4-11 22:35
发表于 2013-7-2 14:31:54 | 显示全部楼层
呵呵,看到高手了,fsxm好
发表于 2020-5-6 16:53:04 | 显示全部楼层
学习,谢谢
发表于 2020-5-7 14:05:58 | 显示全部楼层
向大佬学习
发表于 2020-10-16 17:24:28 | 显示全部楼层
谢谢,学习一下!!!
发表于 2020-12-29 12:14:56 | 显示全部楼层
回复学习。分享源代码都是英雄
发表于 2021-3-11 16:15:50 | 显示全部楼层
谢谢 学习!
GMT+8, 2026-11-22 07:46 , Processed in 1.305012 second(s), 24 queries , Gzip On, File On.
