查看: 3711|回复: 2
[分享] [转帖]选集关建字的使用
发表于 2013-5-5 09:06:21 | 显示全部楼层 |阅读模式
[pcode=cpp,true]
void MyCustomCommand()
  // save the old callback function
  resbuf* (*oldFunc) (const ACHAR*);
  acedSSGetKwordCallbackPtr(&oldFunc);
  // set own callback function
  acedSSSetKwordCallbackPtr(ssCallback);
  // let the user make a selection
  ads_name ss;
  // this is the keyword list
  // to use local and global keywords:
  ACHAR kwordlist[] = { _T("LInes CIRcles _ LInes CIRcles") };
  if (RTNORM != acedSSGet(_T("_:K"), NULL, kwordlist, NULL, ss)) {
    // cancel
  } else {
    acutPrintf(_T("\nDone."));
    acedSSFree(ss);
  // restore old callback function
  acedSSSetKwordCallbackPtr(*oldFunc);
Now the callback that is executed when the keyword is selected:
// Callback function for acedSSGet()
resbuf* ssCallback(const TCHAR* kword)
  // kword contains the global keyword
  acutPrintf(_T("\nCallback: '%s'"), kword);
  // result to return
  // NULL: no changes on selection set
  resbuf *result = NULL;
  if (!wcscmp(kword, _T("LInes"))) {
    // select all lines (just for testing)
    AcDbObjectIdArray objIds;
    getLines(objIds);
    // create resbuf containing single
    // enames from object id array
    result = getResbuf(objIds);
  } else if (!wcscmp(kword, _T("CIRcles"))) {
    // select all circles (just for testing)
    getCircles(objIds);
    // create resbuf containing a selection set
    ads_name ss;
    acedSSGet(_T("X"), NULL, NULL,
      acutBuildList(RTDXF0, _T("CIRCLE"), RTNONE),
      ss);
    result = acutBuildList(RTPICKS, ss, RTNONE);
  } else {
    // return an error message
    result = acutBuildList(RTSTR, _T("\nUnknown error"), RTNONE);
  return result;
And finally some additional methods for this specific sample:
resbuf* getResbuf(AcDbObjectIdArray ids)
  resbuf *result = NULL, *temp1, *temp2;
  ads_name ename;
  int length = ids.length();
  for (int i = 0; i < length; ++i) {
    acdbGetAdsName(ename, ids);
    temp2 = acutBuildList(RTENAME, ename, RTNONE);
    if (result == NULL) {
      result = temp2;
    } else {
      temp1->rbnext = temp2;
    temp1 = temp2;
  return result;
void getLines(AcDbObjectIdArray& ids)
  // select all lines from model space
  // (without any error checking)
  AcDbBlockTable *pTable;
  AcDbBlockTableRecord *pModelSpace;
  AcDbBlockTableRecordIterator *pIter;
  AcDbEntity* pEnt;
  acdbHostApplicationServices()->workingDatabase()->
    getBlockTable(pTable, AcDb::kForRead);
  pTable->getAt(ACDB_MODEL_SPACE, pModelSpace, AcDb::kForRead);
  pTable->close();
  pModelSpace->newIterator(pIter);
  pModelSpace->close();
  for (; !pIter->done(); pIter->step()) {
    pIter->getEntity(pEnt, AcDb::kForRead);
    if (pEnt->isKindOf(AcDbLine::desc()))
      ids.append(pEnt->objectId());
    pEnt->close();
  delete pIter;
void getCircles(AcDbObjectIdArray& ids)
  // select all circles from model space
  AcDbEntity* pEnt;
  pTable->close();
    if (pEnt->isKindOf(AcDbCircle::desc()))
    pEnt->close();
  delete pIter;
[/pcode]
评分
参与人数 2D豆 +7 收起 理由
XDSoft + 4 很给力!经验;技术要点;资料分享奖!
ScmTools + 3 技术引导讨论和指点奖!
查看全部评分
发表于 2013-5-5 09:16:44 | 显示全部楼层
很好的教学贴,希望后续能够看到LZ更加精彩的贴
发表于 2015-3-25 10:18:18 | 显示全部楼层
原来ssget关键字使用已经有帖子了:'(:'(:'(:'(:'(
GMT+8, 2026-11-22 08:07 , Processed in 0.239974 second(s), 14 queries , Gzip On, File On.
