查看: 2255|回复: 0
[分享] How to access and modify a DynamicBlockReference property in ARX and .Net?
发表于 2013-5-26 18:14:37 | 显示全部楼层 |阅读模式
  1. [CommandMethod("SetDynamicBlkProperty")]
  2. static public void SetDynamicBlkProperty()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     PromptEntityOptions prEntOptions = new PromptEntityOptions(
  8.         "Select a dynamic block reference...");
  9.     PromptEntityResult prEntResult = ed.GetEntity(prEntOptions);
  10.     if (prEntResult.Status != PromptStatus.OK)
  11.     {
  12.         ed.WriteMessage("Error...");
  13.         return;
  14.     }
  15.     using(Transaction Tx = db.TransactionManager.StartTransaction())
  16.     {
  17.         BlockReference bref = Tx.GetObject(
  18.             prEntResult.ObjectId,
  19.             OpenMode.ForWrite)
  20.                 as BlockReference;
  21.         if (bref.IsDynamicBlock)
  22.         {
  23.             DynamicBlockReferencePropertyCollection props =
  24.                 bref.DynamicBlockReferencePropertyCollection;
  25.             foreach (DynamicBlockReferenceProperty prop in props)
  26.             {
  27.                 object[] values = prop.GetAllowedValues();
  28.                 //Switch Property
  29.                 if (prop.PropertyName == "Visibility" && !prop.ReadOnly)
  30.                 {
  31.                     if (prop.Value.ToString() == values[0].ToString())
  32.                         prop.Value = values[1];
  33.                     else
  34.                         prop.Value = values[0];
  35.                 }
  36.             }
  37.         }
  38.         Tx.Commit();
  39.     }
  40. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:09 , Processed in 0.296228 second(s), 10 queries , Gzip On, File On.
