查看: 13951|回复: 41
[每日一码] 常用函数
已领礼包: 604个
发表于 2013-6-15 16:35:09 | 显示全部楼层 |阅读模式
[常用函数] 收集:自贡黄明儒
  1. ;;; 1 [功能] 检查加载vlisp扩展
  2. (vl-load-com)
  3. ;;; 2  常数(lisp编辑器在输出局部变量时,带*的会排在前面.caoyin这样写很有道理)
  4. (setq *en2obj* vlax-ename->vla-object
  5.       *obj2en* vlax-vla-object->ename
  6.       *2pi* (* pi 2)
  7.       *0.5pi* (/ pi 2)
  8.       *0.25pi* (/ pi 4)                       ; 常用vla对象、集合
  9.       *acad* (vlax-get-acad-object)
  10.       *doc* (vla-get-activedocument *acad*)
  11.       *docs* (vla-get-documents *acad*)
  12.       *ms* (vla-get-modelspace *doc*)
  13.       *ps* (vla-get-paperspace *doc*)
  14.       *blks* (vla-get-blocks *doc*)
  15.       *lays* (vla-get-layers *doc*)
  16.       *lts* (vla-get-linetypes *doc*)
  17.       *sts* (vla-get-textstyles *doc*)
  18.       *grps* (vla-get-groups *doc*)
  19.       *dims* (vla-get-dimstyles *doc*)
  20.       *louts* (vla-get-layouts *doc*)
  21.       *vps* (vla-get-viewports *doc*)
  22.       *vs* (vla-get-views *doc*)
  23.       *dics* (vla-get-dictionaries *doc*) ; 常用的几个外部接口对象
  24.       *fso* (vlax-get-or-create-object "Scripting.FileSystemObject")
  25.       *wsh* (vlax-get-or-create-object "wscript.shell")
  26.       *shell* (vlax-get-or-create-object "Shell.Application")
  27.       *scr* (vlax-get-or-create-object "ScriptControl")
  28.       *wbem* (vlax-get-or-create-object "WbemScripting.SWbemLocator")
  29. )
  30. ;;; 3 [功能] 返回活动空间vla对象
  31. (defun mj:activespace ()
  32.   (if (= 1 (vlax-get-property doc* 'activespace)) ; 模型1,布局0
  33.     *ms*
  34.     *ps*
  35.   )
  36. )
  37. ;;; 4.1 [功能] 返回当前活动空间名称("model" or "paper")
  38. (defun mj:activespace-name ()
  39.   (if (= 1 (vla-get-activespace *doc*))
  40.     "Model"
  41.     "Paper"
  42.   )
  43. )
  44. ;;; 4.2 [功能] 返回空间名称,如"model"或者"layout1"...
  45. (defun mj:activespace1 ()
  46.   (vla-get-name (vla-get-activelayout *doc*))
  47. )
  48. ;;; 5 [功能] 返回preferences vla对象
  49. (defun mj:acadprefs ()
  50.   (vlax-get-property *acad* 'preferences)
  51. )
  52. ;;; 6 [功能] 返回指定引用的属性
  53. ;;; tabname:application,display,drafting,files,opensave,output,profiles,selection
  54. ;;; ,system,user
  55. ;;; 示例   (mj:getprefkey 'files 'supportpath)  获取支持文件路径
  56. (defun mj:getprefkey (tabname keyname)
  57.   (vlax-get-property (vlax-get-property (mj:acadprefs) tabname) keyname)
  58. )
  59. ;;; 7 [功能] 更改引用设置
  60. ;;; 示例 (mj:setprefkey "opensave" "incrementalsavepercent" 0)
  61. (defun mj:setprefkey (tabname keyname newval)
  62.   (vlax-put-property (vlax-get-property (mj:acadprefs) tabname) keyname newval)
  63. )
  64. ;;; 8 [功能] 返回 acad对象的属性
  65. ;;; propname:activedocument,application,caption,documents,fullname,height,hwnd,lo
  66. ;;; caleid,menubar,
  67. ;;; menugroups,name,path,preferences,statusid,vbe,version,visible,width,windowlef
  68. ;;; t,windowstate,windowtop
  69. ;;; 示例 (mj:acadprop 'fullname)
  70. (defun mj:acadprop (propname)
  71.   (vlax-get-property *acad* propname)
  72. )
  73. ;;; 9 [功能] 对象名称
  74. ;;; 示例 (mj:name *acad*) returns "autocad"
  75. ;;; 示例 (mj:name *ms*)返回"*model_space"
  76. (defun mj:name (obj)
  77.   (if (vlax-property-available-p obj 'name)
  78.     (vlax-get-property obj 'name)
  79.     "<NONE_NAME>"
  80.   )
  81. )
更多见附件。
常用函数.lsp
184.76 KB, 下载次数: 914, 下载积分: D豆 -1 , 活跃度 1
售价: 1 D豆  [记录]
评分
参与人数 3D豆 +8 贡献 +3 收起 理由
炫翔 + 5 + 3 很给力!经验;技术要点;资料分享奖!
laibinwu + 1 很给力!经验;技术要点;资料分享奖!
ScmTools + 2 资料分享奖!
查看全部评分
发表于 2013-6-15 17:21:19 | 显示全部楼层
一下子做出这么多变量来,CAD加载的是不是太多了?
提倡环保,按需加载,事后释放
评分
参与人数 1D豆 +2 收起 理由
炫翔 + 2 技术引导讨论和指点奖!
查看全部评分
发表于 2013-7-10 19:26:34 | 显示全部楼层
無法在win7 64bit autocad 2010執行
請問如何解決?
这个跟AUTOCAD无关,你找下如果在WIN7 64位下 使用 ACTIVEX ScriptControl 的资料。  详情 回复 发表于 2013-7-10 19:38
发表于 2013-7-10 19:38:36 | 显示全部楼层
請問如何解決?
已领礼包: 363个
发表于 2013-11-12 10:15:30 | 显示全部楼层
收藏了,慢慢学习..
发表于 2014-1-6 11:32:58 | 显示全部楼层
好东西,赞:lol
发表于 2014-4-27 00:19:31 | 显示全部楼层
很好的资源~  下载收藏~
发表于 2014-6-6 07:57:40 | 显示全部楼层
回复有D豆吗.
已领礼包: 127个
发表于 2014-6-9 09:14:03 | 显示全部楼层
这些函数怎么使用啊!!!小白求教!!!
发表于 2014-7-13 15:52:16 | 显示全部楼层
很好的学习资料,希望楼主放出明经上的收集,那边不能付款失效了!
发表于 2014-8-1 02:17:30 | 显示全部楼层
非常好,方便!
发表于 2014-11-1 17:04:36 | 显示全部楼层
谢谢楼主,资料很给力,谢谢!
已领礼包: 5个
发表于 2014-11-18 13:24:41 | 显示全部楼层
好东西,收了,谢谢分享...
发表于 2014-11-24 16:05:20 | 显示全部楼层
支持,下载学习一下.
发表于 2014-12-11 15:19:30 | 显示全部楼层
收藏了,慢慢学习..
GMT+8, 2026-11-3 01:53 , Processed in 0.680404 second(s), 67 queries , Gzip On.
