查看: 9340|回复: 15
[图块] 块内复制
发表于 2014-9-28 13:25:35 | 显示全部楼层 |阅读模式
  • 插件名称 : 块内复制
  • 作  者 : SZSU
  • 运行环境 :OpenDCL
  • 发布时间 :2014-09-28
  • 命令名称 :bcopy
  • 插件介绍 :可任意复制块内的内容
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
(defun c:bcopy (/ e el ss *error*)
  (defun *error* (msg) (command ".erase" ss "") (princ))
  (setq ss (ssadd))
  (while (setq e (nentselp "\n选择块内实体: "))
    (setq el (entget (car e)))
    (cond ((ssmemb (car e) ss)
    (entdel (car e))
   (t
    (entmake el)
    (if (= (length e) 4)
      (vla-transformby
        (vlax-ename->vla-object (entlast))
        (vlax-tmatrix (caddr e))
    (ssadd (entlast) ss)
    (sssetfirst nil ss)
  (cond ((and (> (sslength ss) 0)
       (setq P1 (getpoint "\n指定基点<原位置>:"))
  (command ".move" "non" P1)
  (while (/= 0 (getvar "cmdactive"))
    (command "\\")
  (princ)
(defun c:add_to_blk (/ blk bn bname mat ss ssl)
  (if (and
(setq bn (nentselp "\n拾取图块: "))
(= (length bn) 4)  ;块
(progn
   (princ "\n选择添加实体...")
   (setq ss (ssget ))
      )     ;end and 条件
    (progn
      (setq bname (cdr (assoc 2 (entget (last (last bn))))) ;获取块名
     blk   (vla-item (vla-get-blocks *doc*) bname) ;获取块定义
     mat   (ea:matrix_inverse (caddr bn)) ;获取WCS->OCS矩阵
      (setq ssl (mapcar 'vlax-ename->vla-object (fsxm-ss->enlist ss)))
      (foreach e ssl (vla-transformby e (vlax-tmatrix mat)))
     ;变换到块定义的UCS
      (vlax-invoke *doc* 'CopyObjects ssl blk)
      (vla-regen *doc* acActiveviewport) ;更新Insert
      (foreach e ssl (vla-delete e))
  (princ)
(defun ea:matrix_inverse (matrix / m0     m1     m2     m3
     m00  m01 m02    m03    m10    m11
     m12  m13 m20    m21    m22    m23
     _a  ea:determinant       a11    a12
     a21  a22 a33    a34    a41    a42
     a43  a13 a23    a31    a32
  ;;行列式展开,计算代数余子式
  (defun ea:determinant (a00 a01 a02 a10 a11 a12 a20 a21 a22 /)
    (- (+ (* a00 a11 a22)
   (* a01 a12 a20)
   (* a02 a21 a10)
       (* a02 a11 a20)
       (* a01 a10 a22)
       (* a00 a21 a12)
  (setq m0 (car matrix)
m1 (cadr matrix)
m2 (nth 2 matrix)
m3 (last matrix)
  (setq m00 (car m0)
m01 (cadr m0)
m02 (nth 2 m0)
m03 (last m0)
  (setq m10 (car m1)
m11 (cadr m1)
m12 (nth 2 m1)
m13 (last m1)
  (setq m20 (car m2)
m21 (cadr m2)
m22 (nth 2 m2)
m23 (last m2)
  (setq a11 (ea:determinant m11 m12 m13 m21 m22 m23 0.0 0.0 1.0)
a12 (- (ea:determinant m10 m12 m13 m20 m22 m23 0.0 0.0 1.0))
a13 (ea:determinant m10 m11 m13 m20 m21 m23 0.0 0.0 1.0)
a21 (- (ea:determinant m01 m02 m03 m21 m22 m23 0.0 0.0 1.0))
a22 (ea:determinant m00 m02 m03 m20 m22 m23 0.0 0.0 1.0)
a23 (- (ea:determinant m00 m01 m03 m20 m21 m23 0.0 0.0 1.0))
a31 (ea:determinant m01 m02 m03 m11 m12 m13 0.0 0.0 1.0)
a32 (- (ea:determinant m00 m02 m03 m10 m12 m13 0.0 0.0 1.0))
a33 (ea:determinant m00 m01 m03 m10 m11 m13 0.0 0.0 1.0)
a41 (- (ea:determinant m01 m02 m03 m11 m12 m13 m21 m22 m23))
a42 (ea:determinant m00 m02 m03 m10 m12 m13 m20 m22 m23)
a43 (- (ea:determinant m00 m01 m03 m10 m11 m13 m20 m21 m23))
  (list (list a11 a21 a31 a41)
(list a12 a22 a32 a42)
(list a13 a23 a33 a43)
'(0.0 0.0 0.0 1.0)
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2014-10-13 10:50:19 | 显示全部楼层
这个好像就是EXPRESS里的NCOPY吧,高版本CAD已经集成了该命令!
回复 支持 2 反对 0
发表于 2014-9-28 13:58:23 | 显示全部楼层
以后发布插件做个动画演示吧,看下链接 : http://bbs.xdcad.net/forum.php?m ... &extra=page%3D1
好的谢谢提醒啦  详情 回复 发表于 2014-9-28 20:33
发表于 2014-9-28 14:59:43 | 显示全部楼层
:):)good这个功能有用
 楼主| 发表于 2014-9-28 20:33:35 | 显示全部楼层
XDSoft 发表于 2014-9-28 13:58
以后发布插件做个动画演示吧,看下链接 : http://bbs.xdcad.net/forum.php?mod=viewthread&tid=667674&ext ...
好的谢谢提醒啦
发表于 2014-9-29 08:23:28 | 显示全部楼层
c:bcopy中有错误——所选实体不能移出
缺少函数:fsxm-ss->enlist
发表于 2014-10-8 22:27:35 | 显示全部楼层
和express里的功能有什么区别?
发表于 2014-10-10 06:49:28 | 显示全部楼层
很好很强大~~~~
发表于 2015-4-5 13:28:59 | 显示全部楼层
CAD每次进去块编辑 退出来后都很慢
发表于 2015-4-16 21:19:17 | 显示全部楼层
这个功能好,先保存
发表于 2015-4-16 22:06:12 | 显示全部楼层
感谢   分享
发表于 2018-1-11 18:24:22 | 显示全部楼层
这个蛮好,正好需要,非常感谢
发表于 2018-1-22 16:23:21 | 显示全部楼层
感谢,现在才知道这个命令
发表于 2021-2-5 09:35:22 | 显示全部楼层
感谢楼主分享!
发表于 2021-2-5 10:52:04 | 显示全部楼层
高版本中的NCOPY可以实现块内嵌套的拷贝
GMT+8, 2026-11-22 07:44 , Processed in 0.551757 second(s), 38 queries , Gzip On, File On.
