查看: 4132|回复: 7
[曲线] 查询三维曲线上点标高
已领礼包: 593个
发表于 2014-10-13 20:03:06 | 显示全部楼层 |阅读模式
  • 插件名称 : 标高查询
  • 作  者 : eachy
  • 运行环境 :XDRX API OpenDCL
  • 发布时间 :2014-10-13
  • 命令名称 :xdtb_caleheight
  • 插件介绍 :标高查询
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
XdGe 几何库版,可以查询多条首尾相接曲线组上任一点标高
  1. (defun c:XDtb_CalcHeight (/                   c:lhight_form1_OnInitialize
  2.                           olderr           myerr
  3.                           c3d                   p1
  4.                           p
  5.                          )
  6.   (defun myerr (msg)
  7.     (if        (dcl_form_isactive lhight_form1)
  8.       (dcl_form_close lhight_form1)
  9.     )
  10.     (setq *error* olderr)
  11.     (xdge::free)
  12.     (princ)
  13.   )
  14.   (defun c:lhight_form1_OnInitialize (/ sp box)
  15.     (setq box (xdrx_document_pixelbox))
  16.     (dcl_control_setpos
  17.       lhight_form1
  18.       (car (last box))
  19.       (cadr (last box))
  20.       168
  21.       128
  22.     )
  23.     (setq sp (xdge::getpropertyvalue c3d "hasStartPoint" "hasEndPoint"))
  24.     (dcl_control_settext
  25.       lhight_form1_shight
  26.       (vl-princ-to-string (last (car sp)))
  27.     )
  28.     (dcl_control_settext
  29.       lhight_form1_ehight
  30.       (vl-princ-to-string (last (cadr sp)))
  31.     )
  32.   )
  33.   (setq        olderr        *error*
  34.         *error*        myerr
  35.   )
  36.   (if
  37.     (and (setq ss (ssget '((0 . "Line,*Polyline,spline"))))
  38.          (setq lst (xdrx_pickset->ents ss))
  39.          (setq
  40.            lst (vl-remove-if '(lambda (x) (xdrx_curve_isclosed x)) lst)
  41.          )
  42.     )
  43.      (progn
  44.        (setq strl '("YWt6A4UYAABu3NlbBuKTJjU2Ki9mgLi5shNKU1V2Eh8aWtsYR+Q4Oi71tCnxO2W/YuMP0o8/NPR1"
  45.                     "E2cmpfz0FqfcWYq+SD8TEqnMO9VedrSkO4oOhLE3Q5kA3aAaWEuOILDDmUWBB6OBgcGRIBAAHEz/"
  46.                     "15zxXfgwCrbLYUB+0X2+VCtvHQ9FPKbzVMq3Q/p06t8ksCN2NTOfztDLHHEUC9N8b8p11O/ICBcX"
  47.                     "6yCTHK31W6ryX8/ItCfTOauWr6tMVNoZcrfmVNertvTrrCRYifam3axkayXbihDtTfJ+DKraFN1H"
  48.                     "LC52uflyMmMctPDceZmuW8ULAL9BG47XP7BzaaCq+MPOo658Tch7M5a4PyfJJZFbUIvGJoXakOLZ"
  49.                     "B/l2WXbBW0KevPughUZc2y1S48zhxiL5qlDQrNLpdoUDEIL9kv36uS9Ok7lX+URZ7nuVDjjKnYuP"
  50.                     "P5yUwj7ItSAekk/7TQOQjzHzI525+uFuADqG2afxTEYlIt9xQmFwSPCLeBwR0MORBkmUwgwnn+rm"
  51.                     "pxA1r/faBNIpU5viNieDnI4/V81HWH2w4jC3XNlKZ8U0J7mRJFjd0BXSqbfYJpssEmAuXmDsXZAt"
  52.                     "gQX6kWzAPUY2jQ8exSMFsBO+N2o39xcYutsANtBjDrCyst3hp5dfokuddaEpm9XNGvFtABgCSd+E"
  53.                     "JXfIOKcJrkBJZsV07g2yniV08awNYUmIdbRAF6ipAIYyhefmj73hj2FXu8Dmma2DQfcep8bmuBFL"
  54.                     "lUlWBd2/+3Spb3+Ud0luQDTmV87znBIv3HZoWyjV6Bo0OthXv4e3h7WHtoe5h7eHtge+B7wHuge4"
  55.                     "B7YPmUYEu6NV8GKJijc4Q+xbHZ7MNvjpWtr1rJfYXi3wVxovXGkQNEodd1fv2STsV6/JPPe72DpX"
  56.                     "7FdPQIIBLlx2SVsQvDP3H7Ixd4OSaFuIH/dW3+xZIcuSGTSGhdIRp1pkBtsDoEEwhU6zAe+OV7xv"
  57.                     "vDLllfrlaecoL5HRBuUYRfdcaw0BnwFZZNSXEmRgKAZgtBdiWrLqJRUOWCzeHnPTHS8M3bwpVtuZ"
  58.                     "3xZ7ompjKsbqVi04BkXTgezOOw+DKKIy6lVJiBFdjTX+YBE3vhfaP3wUF8F17vogJuzeIKfNNjwa"
  59.                     "O2xyIMDs3ukxP2w0zlx3TQZvWz+Fo+z6fSY47M4wy1o1PEHw3zk634VRAM/aj9PbI7N0mouftnSa"
  60.                     "iwUbf1fQjwyHw+xUGyZHJycnNy3bZlVRVc1peyfX5+zSoiBqI7yhOYQVsuz+XLKMWCYcNy65EcKI"
  61.                     "nzg="
  62.                    )
  63.              c3d  (XDGL::Curve:ToCompositeCrv3d lst)
  64.        )
  65.        (dcl_project_import strl)
  66.        (dcl_form_show lhight_form1)
  67.        (while (setq p (getpoint "\nTest Point: "))
  68.          (setq p1 (xdge::getpropertyvalue c3d "closestPointTo" p))
  69.          (dcl_control_settext
  70.            lhight_form1_tPoint
  71.            (vl-princ-to-string (last p1))
  72.          )
  73.          (princ "\nHeight = ")
  74.          (princ (last p1))
  75.        )
  76.        (if (dcl_form_isactive lhight_form1)
  77.          (dcl_form_close lhight_form1)
  78.        )
  79.      )
  80.   )
  81.   (setq *error* olderr)
  82.   (xdge::free)
  83.   (princ)
  84. )
非 XdGe 库版单条曲线查询
  1. ;;线上查询
  2. (defun c:tt (/ e p)
  3.   (if (setq e (car (xdrx_entsel
  4.                      "\nPick Curve: "
  5.                      '((0 . "*line,arc,circle,ellipse"))
  6.                    )
  7.               )
  8.       )
  9.     (progn
  10.       (xdrx_pickset_highlight e)
  11.       (while (setq p (getpoint "\n测试点: "))
  12.         (setq p (xdrx_curve_getclosestpoint e p))
  13.         (princ "\n当前点高程 = ")
  14.         (princ (last p))
  15.       )
  16.       (xdrx_pickset_highlight e t)
  17.     )
  18.   )
  19.   (princ)
  20. )
指哪查哪,粗略查询
  1. ;;点哪查哪,不精确
  2. (defun c:tt1 (/ e)
  3.   (while (setq e (xdrx_entsel
  4.                    "\nPick Curve: "
  6.                  )
  7.          )
  8.     (princ "\nHeight = ")
  9.     (princ (last (apply 'xdrx_curve_getclosestpoint e)))
  10.   )
  11.   (princ)
  12. )
已领礼包: 145个
发表于 2014-10-13 21:08:43 | 显示全部楼层
能否改用下 点监视器,鼠标动,就自动弹出那个位置的信息随着鼠标变化,就不用对话框了。
已领礼包: 1268个
发表于 2014-10-13 21:33:13 来自手机 | 显示全部楼层
就是在xdrx_pointmonitor回调函数中用dcl_control_setpos修改odcl位置,另外这样可以简化对话框仅用一个无标题栏的text或者就像在位编辑一样的textbox
不是,看看这个帖子, http://bbs.xdcad.net/thread-671343-1-2.html , 不需要用对话框的。  详情 回复 发表于 2014-10-13 21:40
已领礼包: 145个
发表于 2014-10-13 21:40:05 | 显示全部楼层
st788796 发表于 2014-10-13 21:33
就是在xdrx_pointmonitor回调函数中用dcl_control_setpos修改odcl位置,另外这样可以简化对话框仅用一个 ...
一直没有用过 xdrx_pointmonitor 这个用法,看了看信息查询程序,因为是动态点,所以在查询时不能精确捕捉 另外用这个方式时如果加载了实体信息查询会临时替换掉实体信息查询功能,也需要做一个开关  详情 回复 发表于 2014-10-14 08:45
已领礼包: 593个
 楼主| 发表于 2014-10-14 08:45:12 | 显示全部楼层
已领礼包: 264个
发表于 2014-10-14 16:13:12 | 显示全部楼层
use ID command
发表于 2016-5-15 00:59:23 | 显示全部楼层
学习学习!!!!
已领礼包: 9个
发表于 2019-4-22 16:44:07 | 显示全部楼层
不错,有用学习学习
GMT+8, 2026-11-3 01:14 , Processed in 0.494531 second(s), 47 queries , Gzip On.
