查看: 1799|回复: 0
[分享] Display Forms inside async AutoCAD commands
已领礼包: 859个
发表于 2014-10-17 17:00:47 | 显示全部楼层 |阅读模式
        By Philippe Leefsma
  You may have given a try already at the very cool async .Net 4.5 feature.
  When displaying a form inside an async AutoCAD 2015 command, it happens that the synchronization context is not restored properly after closing the form, which provoke some undesirable behavior, for example the output of Editor.WriteMesage not being displayed in the command line.
  A simple way to work around it is to save the current context prior to show the form and reset it once it closes.
  An example of what I’m talking about just below:
// simulates an async function
private static async Task<string> AsyncTask(string name)
    await Task.Delay(5000);
    return "Hello " + name;
[CommandMethod("ADN", "SyncContextCmd", CommandFlags.Transparent)]
async static public void SyncContextCmd()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    // saves current synchronization context
    var syncContext = SynchronizationContext.Current;
    AdnForm form = new AdnForm();
    var dialogResult = Application.ShowModalDialog(form);
    // restores synchronization context
    SynchronizationContext.SetSynchronizationContext(
        syncContext);
    if (dialogResult != System.Windows.Forms.DialogResult.OK)
        return;
    // process form result asynchronously
    string result = await AsyncTask(form.UserName);
    // editor.WriteMessage works OK now
    ed.WriteMessage("\nResult: " + result + "\n");
GMT+8, 2026-11-3 13:52 , Processed in 0.430943 second(s), 32 queries , Gzip On.
