查看: 2139|回复: 0
[研讨] MLine 的 Style
已领礼包: 859个
发表于 2014-11-1 11:03:32 | 显示全部楼层 |阅读模式
手册上说明 Style  是 Read / Write ,经测试 write 仅对 new Mline  有效,已经存在的 Mline 其 Style 只能read 不能 write,ARX 也如此
修改样式只能删除重画!
Creating MLine entity in .NETBy Virupaksha Aithal
Below code shows the procedure to at the Mline entity through .NET in AutoCAD. The important points to remember here is to set the Mline style and the setting of normal. In the below code, the database current mline style is used. You can get/set the current mlstyle using property “CmlstyleID”.
[CommandMethod("AddMline")]
public static void AddMline()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        //get the mline style
        Mline line = new Mline();
        //get the current mline style
        line.Style = db.CmlstyleID;
        line.Normal = Vector3d.ZAxis;
        line.AppendSegment(new Point3d(0, 0, 0));
        line.AppendSegment(new Point3d(10, 10, 0));
        line.AppendSegment(new Point3d(20, 10, 0));
        //open modelpace
        ObjectId ModelSpaceId =
            SymbolUtilityServices.GetBlockModelSpaceId(db);
        BlockTableRecord model = Tx.GetObject(ModelSpaceId,
                         OpenMode.ForWrite) as BlockTableRecord;
        model.AppendEntity(line);
        Tx.AddNewlyCreatedDBObject(line, true);
        Tx.Commit();
  1.         [CommandMethod("test20")]
  2.         public void MatMlineStyle()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Database db = doc.Database;
  6.             Editor ed = doc.Editor;
  7.             Transaction tr = db.TransactionManager.StartTransaction();
  8.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect Source MLine");
  9.             peo.SetRejectMessage("*Not MLine*");
  10.             peo.AddAllowedClass(typeof (Mline ),true);
  11.             PromptEntityResult per = ed.GetEntity(peo);
  12.             if (per.Status !=PromptStatus.OK)
  13.             {
  14.                 return;
  15.             }
  16.             SelectionFilter filter = new SelectionFilter(new TypedValue[]{new TypedValue(0,"mline") });
  17.             PromptSelectionOptions pso = new PromptSelectionOptions();
  18.             pso.MessageForAdding = "\rSelect destination Mline objects: ";
  19.             PromptSelectionResult psr = ed.GetSelection(pso, filter);
  20.             if (psr.Status != PromptStatus.OK)
  21.             {
  22.                 return;
  23.             }
  24.             using (tr)
  25.             {
  26.                 try
  27.                 {
  28.                     BlockTableRecord btr = (BlockTableRecord) tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  29.                     ObjectId id = per.ObjectId;
  30.                     Mline sMline = (Mline) id.GetObject(OpenMode.ForRead);
  31.                     ObjectId mstyle = sMline.Style;
  32.                     ObjectId[] ids = psr.Value.GetObjectIds();
  33.                     for (int i = 0; i < ids.Length ; i++)
  34.                     {
  35.                         Mline cMline = (Mline)ids[i].GetObject(OpenMode.ForWrite);
  36.                         Mline nMline = new Mline();
  37.                         nMline.Style = mstyle;
  38.                         nMline.Normal = cMline.Normal;
  39.                         nMline.Justification = sMline.Justification;
  40.                         nMline.Scale = sMline.Scale;
  41.                         for (int j = 0; j < cMline.NumberOfVertices; j++)
  42.                         {
  43.                             nMline.AppendSegment(cMline.VertexAt(j));
  44.                         }
  45.                         btr.AppendEntity(nMline);
  46.                         nMline.SetPropertiesFrom(cMline);
  47.                         nMline.SwapIdWith(cMline.ObjectId, true, true);
  48.                         cMline.Erase();
  49.                         tr.AddNewlyCreatedDBObject(nMline, true);
  50.                     }
  51.                     tr.Commit();
  52.                 }
  53.                 catch (Exception)
  54.                 {
  55.                     throw;
  56.                 }
  57.             }
  58.         }
GMT+8, 2026-11-3 07:33 , Processed in 0.490004 second(s), 32 queries , Gzip On.
