查看: 1692|回复: 0
[LISP函数]:下面是本人写的一个画六角螺母的程序,与大家共享
发表于 2002-5-30 03:23:56 | 显示全部楼层 |阅读模式
  1. [FONT=courier new]
  2. 1)B_NUT.LSP
  3. ;这是一个基于AutoCad 14.0下关于画六角螺母主视图的程序
  4. ;它可以在"nut_..."层上画六角螺母主视图
  5. ;本程序作者b.w
  6. ;本程序无偿使用
  7. ;如有更好建议,请联系b.w
  8. ;版本:1.1.01
  9. ;日期:15/11-2001
  10. ;B_nut_diameter : 螺母大小
  11. ;B_nut_layer    : 画螺母的层
  12. ;B_nut_center   : 螺母插入点
  13. ;B_nut_radins   : 螺母外六角内切圆半径
  14. ;B_current_lt   : 保存当前线型变量
  15. ;B_current_layer: 保存当前层边量
  16.   (cond
  17.      (  (and ai_dcl (listp ai_dcl)))          ; it's already loaded.
  18.      (  (not (findfile "ai_utils.lsp"))                     ; find it
  19.         (ai_abort "DDMODIFY"
  20.                   (strcat "Can't locate file AI_UTILS.LSP."
  21.                           "\n Check support directory.")))
  22.      (  (eq "failed" (load "ai_utils" "failed"))            ; load it
  23.         (ai_abort "DDMODIFY" "Can't load file AI_UTILS.LSP"))
  24.   )
  25. (defun B_NUT_SLIDE_CHANGE;改变视图选择
  26.   (
  27.   /
  28.   )
  29.   (if (= B_nut_view 10201)
  30.     (progn
  31.       (B_NUT_SLIDE_STAR "B_NUT_FLANK")
  32.       (set_tile "B_NUT_VIEW_S_DCL" "1")
  33.       (setq B_nut_view 10202)
  34.       (mode_tile "B_NUT_ANGLE_DCL" 0)
  35.       (mode_tile "B_NUT_ANGLE_S_DCL" 0)
  36.     );end-progn
  37.     (progn
  38.       (B_NUT_SLIDE_STAR "B_NUT_FACE")
  39.       (set_tile "B_NUT_VIEW_S_DCL" "0")
  40.       (setq B_nut_view 10201)
  41.       (mode_tile "B_NUT_ANGLE_DCL" 1)
  42.       (mode_tile "B_NUT_ANGLE_S_DCL" 1)
  43.     );end-progn
  44.   );end-if
  45. );end-B_NUT_SLIDE_CHANGE
  46. (defun B_NUT_HILITE
  47.   (
  48.   B_nut_tile
  49.   /
  50.   )
  51.   (B_NUT_SLIDE_CHANGE)
  52.   (if (/= B_nut_last_slide B_nut_tile)
  53.      (progn
  54.         (mode_tile B_nut_tile 4)
  55.         (if (/= B_nut_last_slide nil)
  56.            (mode_tile B_nut_last_slide 4)
  57.         );end-if
  58.      );end-progn
  59.   );end-if
  60.   (setq B_nut_last_slide B_nut_tile)
  61. );end-B_NUT_HILITE
  62. (defun B_NUT_SLIDE_STAR;启动幻灯片
  63.   (
  64.   B_nut_slide
  65.   /
  66.   )
  67.   (start_image "B_NUT_VIEW_DCL");开始建立图象
  68.   (fill_image 0 0 (dimx_tile "B_NUT_VIEW_DCL") (dimy_tile "B_NUT_VIEW_DCL") -2
  69.   );以AUTOCAD图形背景色填充
  70.   (slide_image 0 0 (dimx_tile "B_NUT_VIEW_DCL") (dimy_tile "B_NUT_VIEW_DCL") (strcat "B_NUT(" B_nut_slide ")")
  71.   );end-silde_image从幻灯片库中调入幻灯片
  72.   (end_image);结束当前激活图象的建立
  73. );end-B_NUT_SLIDE_STAR
  74. (defun B_NUT_ANGLE_INPUT
  75.   (
  76.   /
  77.   )
  78.   (setq B_nut_angle (* 0.017453292 (atof (get_tile "B_NUT_ANGLE_DCL"))))
  79. );end-B_NUT_ANGLE_INPUT
  80. (defun B_NUT_CENTER_INPUT
  81.   (
  82.   /
  83.   )
  84.   (setq B_nut_center_x (atof (get_tile "B_NUT_CENTER_X_DCL")))
  85.   (setq B_nut_center_y (atof (get_tile "B_NUT_CENTER_Y_DCL")))
  86.   (setq B_nut_center_z (atof (get_tile "B_NUT_CENTER_Z_DCL")))
  87.   (setq B_nut_center (list B_nut_center_x B_nut_center_y B_nut_center_z))
  88. );end-B_NUT_CENTER_INPUT
  89. (defun B_NUT_DIAMETER_SELECTION
  90.   (
  91.    /
  92.   )
  93.   (cond
  94.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "0")
  95.       (setq B_nut_diameter 1.6)
  96.       (set_tile "B_NUT_DIAMETER_DCL" "1.6")
  97.     );end-0
  98.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "1")
  99.       (setq B_nut_diameter 2.0)
  100.       (set_tile "B_NUT_DIAMETER_DCL" "2.0")
  101.     );end-1
  102.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "2")
  103.       (setq B_nut_diameter 2.5)
  104.       (set_tile "B_NUT_DIAMETER_DCL" "2.5")
  105.     );end-2
  106.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "3")
  107.       (setq B_nut_diameter 3.0)
  108.       (set_tile "B_NUT_DIAMETER_DCL" "3.0")
  109.     );end-3
  110.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "4")
  111.       (setq B_nut_diameter 4.0)
  112.       (set_tile "B_NUT_DIAMETER_DCL" "4.0")
  113.     );end-4
  114.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "5")
  115.       (setq B_nut_diameter 5.0)
  116.       (set_tile "B_NUT_DIAMETER_DCL" "5.0")
  117.     );end-5
  118.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "6")
  119.       (setq B_nut_diameter 6.0)
  120.       (set_tile "B_NUT_DIAMETER_DCL" "6.0")
  121.     );end-6
  122.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "7")
  123.       (setq B_nut_diameter 8.0)
  124.       (set_tile "B_NUT_DIAMETER_DCL" "8.0")
  125.     );end-7
  126.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "8")
  127.       (setq B_nut_diameter 10.0)
  128.       (set_tile "B_NUT_DIAMETER_DCL" "10.0")
  129.     );end-8
  130.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "9")
  131.       (setq B_nut_diameter 12.0)
  132.       (set_tile "B_NUT_DIAMETER_DCL" "12.0")
  133.     );end-9
  134.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "10")
  135.       (setq B_nut_diameter 16.0)
  136.       (set_tile "B_NUT_DIAMETER_DCL" "16.0")
  137.     );end-10
  138.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "11")
  139.       (setq B_nut_diameter 20.0)
  140.       (set_tile "B_NUT_DIAMETER_DCL" "20.0")
  141.     );end-11
  142.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "12")
  143.       (setq B_nut_diameter 24.0)
  144.       (set_tile "B_NUT_DIAMETER_DCL" "24.0")
  145.     );end-12
  146.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "13")
  147.       (setq B_nut_diameter 30.0)
  148.       (set_tile "B_NUT_DIAMETER_DCL" "30.0")
  149.     );end-13
  150.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "14")
  151.       (setq B_nut_diameter 36.0)
  152.       (set_tile "B_NUT_DIAMETER_DCL" "36.0")
  153.     );end-14
  154.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "15")
  155.       (setq B_nut_diameter 42.0)
  156.       (set_tile "B_NUT_DIAMETER_DCL" "42.0")
  157.     );end-15
  158.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "16")
  159.       (setq B_nut_diameter 48.0)
  160.       (set_tile "B_NUT_DIAMETER_DCL" "48.0")
  161.     );end-16
  162.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "17")
  163.       (setq B_nut_diameter 56.0)
  164.       (set_tile "B_NUT_DIAMETER_DCL" "56.0")
  165.     );end-17
  166.     ((= (get_tile "B_NUT_DIAMETER_S_DCL") "18")
  167.       (setq B_nut_diameter 64.0)
  168.       (set_tile "B_NUT_DIAMETER_DCL" "64.0")
  169.     );end-18
  170.   );end-cond
  171. );end-B_NUT_DIAMETER_SELECTION
  172. (defun B_NUT_DIAMETER_INPUT
  173.   (
  174.    /
  175.   )
  176.   (set_tile "error" "")
  177.   (cond
  178.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 1.6)
  179.       (setq B_nut_diameter 1.6)
  180.       (set_tile "B_NUT_DIAMETER_S_DCL" "0")
  181.     );end-0
  182.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 2.0)
  183.       (setq B_nut_diameter 2.0)
  184.       (set_tile "B_NUT_DIAMETER_S_DCL" "1")
  185.     );end-1
  186.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 2.5)
  187.       (setq B_nut_diameter 2.5)
  188.       (set_tile "B_NUT_DIAMETER_S_DCL" "2")
  189.     );end-2
  190.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 3.0)
  191.       (setq B_nut_diameter 3.0)
  192.       (set_tile "B_NUT_DIAMETER_S_DCL" "3")
  193.     );end-3
  194.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 4.0)
  195.       (setq B_nut_diameter 4.0)
  196.       (set_tile "B_NUT_DIAMETER_S_DCL" "4")
  197.     );end-4
  198.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 5.0)
  199.       (setq B_nut_diameter 5.0)
  200.       (set_tile "B_NUT_DIAMETER_S_DCL" "5")
  201.     );end-5
  202.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 6.0)
  203.       (setq B_nut_diameter 6.0)
  204.       (set_tile "B_NUT_DIAMETER_S_DCL" "6")
  205.     );end-6
  206.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 8.0)
  207.       (setq B_nut_diameter 8.0)
  208.       (set_tile "B_NUT_DIAMETER_S_DCL" "7")
  209.     );end-7
  210.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 10.0)
  211.       (setq B_nut_diameter 10.0)
  212.       (set_tile "B_NUT_DIAMETER_S_DCL" "8")
  213.     );end-8
  214.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 12.0)
  215.       (setq B_nut_diameter 12.0)
  216.       (set_tile "B_NUT_DIAMETER_S_DCL" "9")
  217.     );end-9
  218.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 16.0)
  219.       (setq B_nut_diameter 16.0)
  220.       (set_tile "B_NUT_DIAMETER_S_DCL" "10")
  221.     );end-10
  222.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 20.0)
  223.       (setq B_nut_diameter 20.0)
  224.       (set_tile "B_NUT_DIAMETER_S_DCL" "11")
  225.     );end-11
  226.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 24.0)
  227.       (setq B_nut_diameter 24.0)
  228.       (set_tile "B_NUT_DIAMETER_S_DCL" "12")
  229.     );end-12
  230.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 30.0)
  231.       (setq B_nut_diameter 30.0)
  232.       (set_tile "B_NUT_DIAMETER_S_DCL" "13")
  233.     );end-13
  234.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 36.0)
  235.       (setq B_nut_diameter 36.0)
  236.       (set_tile "B_NUT_DIAMETER_S_DCL" "14")
  237.     );end-14
  238.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 42.0)
  239.       (setq B_nut_diameter 42.0)
  240.       (set_tile "B_NUT_DIAMETER_S_DCL" "15")
  241.     );end-15
  242.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 48.0)
  243.       (setq B_nut_diameter 48.0)
  244.       (set_tile "B_NUT_DIAMETER_S_DCL" "16")
  245.     );end-16
  246.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 56.0)
  247.       (setq B_nut_diameter 56.0)
  248.       (set_tile "B_NUT_DIAMETER_S_DCL" "17")
  249.     );end-17
  250.     ((= (atof (get_tile "B_NUT_DIAMETER_DCL")) 64.0)
  251.       (setq B_nut_diameter 64.0)
  252.       (set_tile "B_NUT_DIAMETER_S_DCL" "18")
  253.     );end-18
  254.     (T
  255.       (set_tile "error" "输入的数据无效或无此螺母的数据")
  256.       (mode_tile "B_NUT_DIAMETER_DCL" 2)
  257.     );end-T
  258.   );end-cond
  259. );end-B_NUT_DIAMETER_INPUT
  260. (defun B_NUT_CRITERION_SELECTION
  261.   (
  262.   /
  263.   )
  264.   (cond
  265.     ((= (get_tile "B_NUT_CRITERION_S_DCL") "0")
  266.       (setq B_nut_criterion 10211)
  267.       (set_tile "B_NUT_CRITERION_DCL" "I型六角螺母-A和B级(GB6170-1986)")
  268.     );end-0
  269.     ((= (get_tile "B_NUT_CRITERION_S_DCL") "1")
  270.       (setq B_nut_criterion 10212)
  271.       (set_tile "B_NUT_CRITERION_DCL" "I型六角螺母-C级(GB/T41-1986)")
  272.     );end-1
  273.     ((= (get_tile "B_NUT_CRITERION_S_DCL") "2")
  274.       (setq B_nut_criterion 10213)
  275.       (set_tile "B_NUT_CRITERION_DCL" "六角薄螺母-A和B级(GB6172-1986)")
  276.     );end-2
  277.   );end-cond
  278. );end-B_NUT_CRITERION_SELECTION
  279. (defun B_NUT_DCL_DEFAULT_CRITERION
  280.   (
  281.   /
  282.   )
  283.   (cond
  284.     ((= B_nut_criterion 10211)
  285.      (set_tile "B_NUT_CRITERION_S_DCL" "0")
  286.      (set_tile "B_NUT_CRITERION_DCL" "I型六角螺母-A和B级(GB6170-1986)")
  287.     );end-0
  288.     ((= B_nut_criterion 10212)
  289.      (set_tile "B_NUT_CRITERION_S_DCL" "1")
  290.      (set_tile "B_NUT_CRITERION_DCL" "I型六角螺母-C级(GB/T41-1986)")
  291.     );end-1
  292.     ((= B_nut_criterion 10213)
  293.      (set_tile "B_NUT_CRITERION_S_DCL" "2")
  294.      (set_tile "B_NUT_CRITERION_DCL" "六角薄螺母-A和B级(GB6172-1986)")
  295.     );end-2
  296.   );end-cond
  297. );end-B_NUT_DCL_DEFAULT_CRITERION
  298. (defun B_NUT_DCL_DEFAULT_DIAMETER
  299.   (
  300.   /
  301.   )
  302.   (cond
  303.     ((= B_nut_diameter 1.6)
  304.       (set_tile "B_NUT_DIAMETER_DCL" "1.6")
  305.       (set_tile "B_NUT_DIAMETER_S_DCL" "0")
  306.     );end-0
  307.     ((= B_nut_diameter 2.0)
  308.       (set_tile "B_NUT_DIAMETER_DCL" "2.0")
  309.       (set_tile "B_NUT_DIAMETER_S_DCL" "1")
  310.     );end-1
  311.     ((= B_nut_diameter 2.5)
  312.       (set_tile "B_NUT_DIAMETER_DCL" "2.5")
  313.       (set_tile "B_NUT_DIAMETER_S_DCL" "2")
  314.     );end-2
  315.     ((= B_nut_diameter 3.0)
  316.       (set_tile "B_NUT_DIAMETER_DCL" "3.0")
  317.       (set_tile "B_NUT_DIAMETER_S_DCL" "3")
  318.     );end-3
  319.     ((= B_nut_diameter 4.0)
  320.       (set_tile "B_NUT_DIAMETER_DCL" "4.0")
  321.       (set_tile "B_NUT_DIAMETER_S_DCL" "4")
  322.     );end-4
  323.     ((= B_nut_diameter 5.0)
  324.       (set_tile "B_NUT_DIAMETER_DCL" "5.0")
  325.       (set_tile "B_NUT_DIAMETER_S_DCL" "5")
  326.     );end-5
  327.     ((= B_nut_diameter 6.0)
  328.       (set_tile "B_NUT_DIAMETER_DCL" "6.0")
  329.       (set_tile "B_NUT_DIAMETER_S_DCL" "6")
  330.     );end-6
  331.     ((= B_nut_diameter 8.0)
  332.       (set_tile "B_NUT_DIAMETER_DCL" "8.0")
  333.       (set_tile "B_NUT_DIAMETER_S_DCL" "7")
  334.     );end-7
  335.     ((= B_nut_diameter 10.0)
  336.       (set_tile "B_NUT_DIAMETER_DCL" "10.0")
  337.       (set_tile "B_NUT_DIAMETER_S_DCL" "8")
  338.     );end-8
  339.     ((= B_nut_diameter 12.0)
  340.       (set_tile "B_NUT_DIAMETER_DCL" "12.0")
  341.       (set_tile "B_NUT_DIAMETER_S_DCL" "9")
  342.     );end-9
  343.     ((= B_nut_diameter 16.0)
  344.       (set_tile "B_NUT_DIAMETER_DCL" "16.0")
  345.       (set_tile "B_NUT_DIAMETER_S_DCL" "10")
  346.     );end-10
  347.     ((= B_nut_diameter 20.0)
  348.       (set_tile "B_NUT_DIAMETER_DCL" "20.0")
  349.       (set_tile "B_NUT_DIAMETER_S_DCL" "11")
  350.     );end-11
  351.     ((= B_nut_diameter 24.0)
  352.       (set_tile "B_NUT_DIAMETER_DCL" "24.0")
  353.       (set_tile "B_NUT_DIAMETER_S_DCL" "12")
  354.     );end-12
  355.     ((= B_nut_diameter 30.0)
  356.       (set_tile "B_NUT_DIAMETER_DCL" "30.0")
  357.       (set_tile "B_NUT_DIAMETER_S_DCL" "13")
  358.     );end-13
  359.     ((= B_nut_diameter 36.0)
  360.       (set_tile "B_NUT_DIAMETER_DCL" "36.0")
  361.       (set_tile "B_NUT_DIAMETER_S_DCL" "14")
  362.     );end-14
  363.     ((= B_nut_diameter 42.0)
  364.       (set_tile "B_NUT_DIAMETER_DCL" "42.0")
  365.       (set_tile "B_NUT_DIAMETER_S_DCL" "15")
  366.     );end-15
  367.     ((= B_nut_diameter 48.0)
  368.       (set_tile "B_NUT_DIAMETER_DCL" "48.0")
  369.       (set_tile "B_NUT_DIAMETER_S_DCL" "16")
  370.     );end-16
  371.     ((= B_nut_diameter 56.0)
  372.       (set_tile "B_NUT_DIAMETER_DCL" "56.0")
  373.       (set_tile "B_NUT_DIAMETER_S_DCL" "17")
  374.     );end-17
  375.     ((= B_nut_diameter 64.0)
  376.       (set_tile "B_NUT_DIAMETER_DCL" "64.0")
  377.       (set_tile "B_NUT_DIAMETER_S_DCL" "18")
  378.     );end-18
  379.   );end-cond
  380. );end-B_NUT_DCL_DEFAULT_DIAMETER
  381. (defun B_NUT_DCL_DEFAULT_VIEW
  382.   (
  383.   /
  384.   )
  385.   (if (= B_nut_view 10201)
  386.     (progn
  387.       (B_NUT_SLIDE_STAR "B_NUT_FACE")
  388.       (set_tile "B_NUT_VIEW_S_DCL" "0")
  389.       (mode_tile "B_NUT_ANGLE_DCL" 1)
  390.       (mode_tile "B_NUT_ANGLE_S_DCL" 1)
  391.     );end-progn
  392.     (progn
  393.       (B_NUT_SLIDE_STAR "B_NUT_FLANK")
  394.       (set_tile "B_NUT_VIEW_S_DCL" "1")
  395.       (mode_tile "B_NUT_ANGLE_DCL" 0)
  396.       (mode_tile "B_NUT_ANGLE_S_DCL" 0)
  397.     );end-progn
  398.   );end-if
  399. );end-B_NUT_DCL_DEFAULT_VIEW
  400. (defun B_NUT_DCL_DEFAULT
  401.   (
  402.   /
  403.   )
  404.   (if B_nut_view
  405.     (B_NUT_DCL_DEFAULT_VIEW)
  406.   );end-if
  407.   (if B_nut_diameter
  408.     (B_NUT_DCL_DEFAULT_DIAMETER)
  409.   );end-if
  410.   (if B_nut_criterion
  411.     (B_NUT_DCL_DEFAULT_CRITERION)
  412.   );end-if
  413.   (if B_nut_angle
  414.     (set_tile "B_NUT_ANGLE_DCL" (rtos (* 57.29577951 B_nut_angle)))
  415.   );end-if
  416.   (if B_nut_center
  417.     (progn
  418.       (set_tile "B_NUT_CENTER_X_DCL" (rtos B_nut_center_x))
  419.       (set_tile "B_NUT_CENTER_Y_DCL" (rtos B_nut_center_y))
  420.       (set_tile "B_NUT_CENTER_Z_DCL" (rtos B_nut_center_z))
  421.     );end-cond
  422.   );end-if
  423. );end-B_NUT_DCL_DEFAULT
  424. (defun B_NUT_SET_BEGIN
  425.   (
  426.   /
  427.   )
  428.   (setq B_nut_view 10201)
  429.   (setq B_nut_center '(0.0 0.0 0.0))
  430.   (setq B_nut_center_x 0.0)
  431.   (setq B_nut_center_y 0.0)
  432.   (setq B_nut_center_z 0.0)
  433.   (setq B_nut_diameter 8.0)
  434.   (setq B_nut_angle 0.0)
  435.   (setq B_nut_criterion 10211)
  436. );end-B_NUT_SET_BEGIN
  437. (defun B_NUT_ACTION_TILE
  438.   (
  439.   /
  440.   )
  441.   (setq B_nut_what 7)
  442.   (B_NUT_SET_BEGIN)
  443.   (while (> B_nut_what 2)
  444.     (if (not (new_dialog "B_NUT" B_nut_id))
  445.       (exit)
  446.     );end-if
  447.     (B_NUT_SLIDE_STAR "B_NUT_FACE")
  448.     (mode_tile "B_NUT_CRITERION_DCL" 1)
  449.     (mode_tile "B_NUT_ANGLE_DCL" 1)
  450.     (B_NUT_DCL_DEFAULT)
  451.     (action_tile "B_NUT_VIEW_DCL" "(B_NUT_HILITE B_NUT_VIEW_DCL)")
  452.     (action_tile "B_NUT_VIEW_S_DCL" "(B_NUT_HILITE B_NUT_VIEW_DCL)")
  453.     (action_tile "B_NUT_DIAMETER_DCL" "(B_NUT_DIAMETER_INPUT)")
  454.     (action_tile "B_NUT_DIAMETER_S_DCL" "(B_NUT_DIAMETER_SELECTION)")
  455.     (action_tile "B_NUT_CRITERION_S_DCL" "(B_NUT_CRITERION_SELECTION)")
  456.     (action_tile "B_NUT_ANGLE_S_DCL" "(done_dialog 3)")
  457.     (action_tile "B_NUT_ANGLE_DCL" "(B_NUT_ANGLE_INPUT)")
  458.     (action_tile "B_NUT_CENTER_DCL" "(done_dialog 4)")
  459.     (action_tile "B_NUT_CENTER_X_DCL" "(B_NUT_CENTER_INPUT)")
  460.     (action_tile "B_NUT_CENTER_Y_DCL" "(B_NUT_CENTER_INPUT)")
  461.     (action_tile "B_NUT_CENTER_Z_DCL" "(B_NUT_CENTER_INPUT)")
  462.     (action_tile "cancel"  "(done_dialog 0)")
  463.     (action_tile "accept"  "(done_dialog 1)")
  464.     (setq B_nut_what (start_dialog))
  465.     (cond
  466.       ((= B_nut_what 4)
  467.         (initget 1)
  468.         (setq B_nut_center (getpoint "\n插入点: ")
  469.               B_nut_center_x (car B_nut_center)
  470.               B_nut_center_y (cadr B_nut_center)
  471.               B_nut_center_z (caddr B_nut_center)
  472.         )
  473.       );end-4
  474.       ((= B_nut_what 3)
  475.        (setq B_nut_angle (getorient "请输入螺母角度: "))
  476.       );end-3
  477.     );end-cond
  478.   );end-while
  479. );end-B_NUT_ACTION_TILE
  480. (defun B_NUT_MAKE_LAYER
  481.   (
  482.   /
  483. ;  B_nut_diameter
  484.   B_nut_layer
  485.   B_lay_exist
  486.   )
  487.   (cond
  488.     ((= B_nut_criterion 10211)
  489.       (setq B_nut_layer (strcat "B_NUT_i-" (itoa (fix B_nut_diameter))))
  490.     );end-10211
  491.     ((= B_nut_criterion 10212)
  492.       (setq B_nut_layer (strcat "B_NUT_c-" (itoa (fix B_nut_diameter))))
  493.     );end-10211
  494.     ((= B_nut_criterion 10213)
  495.       (setq B_nut_layer (strcat "B_NUT_b-" (itoa (fix B_nut_diameter))))
  496.     );end-10211
  497.   );end-cond
  498.   (setq B_lay_exist (tblsearch "layer" B_nut_layer))
  499.   (if (/= B_lay_exist nil)
  500.     (setvar "CLAYER" B_nut_layer)
  501.     (command "layer" "M" B_nut_layer "C" "45" "" "")
  502.   );end-if
  503.   (princ)
  504. );end-B_NUT_MAKE_LAYER
  505. (defun B_NUT_DRAW_CENTER_FACE
  506.   (
  507.    /
  508. ;  B_current_lt
  509. ;  B_nut_center
  510. ;  B_nut_radins
  511.   )
  512.   (setq B_current_lt (getvar "CELTYPE"))
  513.   (if (/= B_current_lt "CENTER")
  514.     (setvar "CELTYPE" "CENTER")
  515.     (setvar "CELTYPE" B_current_lt)
  516.   );end-iF
  517.   (setvar "OSMODE"        0)
  518.   (command "line" (list (+ (car B_nut_center) (* B_nut_radins 1.3)) (cadr B_nut_center) 0)
  519.                   (list (- (car B_nut_center) (* B_nut_radins 1.3)) (cadr B_nut_center) 0) ""
  520.   );end-command
  521.   (command "line" (list (car B_nut_center) (+ (cadr B_nut_center) (* B_nut_radins 1.3)) 0)
  522.                   (list (car B_nut_center) (- (cadr B_nut_center) (* B_nut_radins 1.3)) 0) ""
  523.   );end-command
  524.   (setvar "OSMODE"       51)
  525.   (setvar "CELTYPE" B_current_lt)
  526. );end-B_NUT_DRAW_CENTER_FACE
  527. (defun B_NUT_COUNT_WHORL
  528.   (
  529.    /
  530. ;  B_nut_center
  531. ;  B_nut_diameter
  532. ;  B_nut_star
  533.   )
  534.    (setq B_nut_star (polar B_nut_center 3.316125579 (/ B_nut_diameter 2.0)))
  535. );end-B_NUT_COUNT_WHORL
  536. (defun B_NUT_DRAW_WHORL
  537.   (
  538.    /
  539. ;  B_current_lt
  540. ;  B_nut_center
  541. ;  B_nut_diameter
  542. ;  B_nut_star
  543.   )
  544.   (setq B_current_lt (getvar "CELTYPE"))
  545.   (if (/= B_current_lt "CONTINUOUS")
  546.     (setvar "CELTYPE" "CONTINUOUS")
  547.     (setvar "CELTYPE" B_current_lt)
  548.   );end-iF
  549.   (setvar "OSMODE"        0)
  550.   (command "ARC" "C" B_nut_center B_nut_star "A" "-270"
  551.   );end-command
  552.   (setvar "OSMODE"        51)
  553.   (if (/= B_current_lt "BYLAYER")
  554.     (setvar "CELTYPE" "BYLAYER")
  555.     (setvar "CELTYPE" B_current_lt)
  556.   );end-iF
  557.   (setvar "OSMODE"        0)
  558.   (command "CIRCLE" B_nut_center "D" (* 0.85 B_nut_diameter)
  559.   );end-command
  560.   (setvar "OSMODE"        51)
  561.   (setvar "CELTYPE" B_current_lt)
  562. );end-B_NUT_DRAW_WHORL
  563. (defun B_NUT_DRAW_SHAPE_FACE
  564.   (
  565.    /
  566. ;  B_nut_center
  567. ;  B_nut_radins
  568.   )
  569.   (setvar "OSMODE"        0)
  570.   (command "CIRCLE" B_nut_center B_nut_radins
  571.   );end-command
  572.   (command "POLYGON" "6" B_nut_center "C" B_nut_radins
  573.   );end-command
  574.   (setvar "OSMODE"        51)
  575. );end-B_NUT_DRAW_SHAPE_FACE
  576. (defun B_NUT_COUNT_SHAPE
  577.   (
  578.    /
  579.   B_nut_dat
  580.   B_nut_dat_find
  581.   B_nut_date_file
  582.   )
  583.   (cond
  584.     ((= B_nut_criterion 10211)
  585.       (setq B_nut_date_file "B_nut_i.dat")
  586.     );end-1
  587.     ((= B_nut_criterion 10212)
  588.       (setq B_nut_date_file "B_nut_c.dat")
  589.     );end-2
  590.     ((= B_nut_criterion 10213)
  591.       (setq B_nut_date_file "B_nut_b.dat")
  592.     );end-3
  593.   );end-cond
  594.   (setq B_nut_dat_find (findfile B_nut_date_file))
  595.   (if (= B_nut_dat_find nil)
  596.      (B_ERROR "Don't find nut date file")
  597.      (progn
  598.         (setq B_nut_dat (open B_nut_dat_find "r"))
  599.         (setq B_nut_dat_line (read-line B_nut_dat))
  600.         (B_NUT_CHANGE_CHR_INT B_nut_dat_line)
  601.         (while (and (/= B_nut_dat_line nil)
  602.                     (/= (car B_nut_dat_line) B_nut_diameter)
  603.                )
  604.               (setq B_nut_dat_line (read-line B_nut_dat))
  605.               (if (/= B_nut_dat_line nil)
  606.                  (B_NUT_CHANGE_CHR_INT B_nut_dat_line)
  607.               );end-if
  608.         );end-while
  609.         (if (= B_nut_dat_line nil)
  610.            (B_error "NOT THIS NUMBER NUT DATE")
  611.         );end-if
  612.         (close B_nut_dat)
  613.      );end-progn
  614.   );end-if
  615. );end-B_NUT_COUNT_SHAPE
  616. (defun B_NUT_CHANGE_CHR_INT
  617.   (
  618.    B_dat_line
  619.    /
  620.   B_dat_n
  621.   B_one_chr
  622.   B_one_real
  623.   B_line_list
  624.   )
  625.   (setq B_line_list nil)
  626.   (setq B_dat_n 1)
  627.   (while (/= B_dat_line "")
  628.         (setq B_dat_n 1)
  629.         (while (and (/= (substr B_dat_line B_dat_n 1) ",") (/= (substr B_dat_line B_dat_n 1) ""))
  630.               (setq B_dat_n (+ B_dat_n 1))
  631.         );end-while
  632.         (setq B_one_chr (substr B_dat_line 1 (- B_dat_n 1)))
  633.         (setq B_one_real (atof B_one_chr))
  634.         (setq B_line_list (append B_line_list (list B_one_real)))
  635.         (setq B_dat_line (substr B_dat_line (+ B_dat_n 1)))
  636.   );end-while
  637.   (setq B_nut_dat_line B_line_list)
  638. );end-B_NUT_CHANGE_CHR_INT
  639. (defun B_ERROR
  640.   (
  641.    B_error_chr
  642.    /
  643.   )
  644.   (princ "ERROR:")
  645.   (princ B_error_chr)
  646.   (terpri)
  647. );end-B_ERROR
  648. (defun B_NUT_DRAW_CENTER_FLANK
  649.   (
  650.    /
  651. ;  B_current_lt
  652. ;  B_nut_center
  653. ;  B_nut_radins
  654.   )
  655.   (setq B_current_lt (getvar "CELTYPE"))
  656.   (if (/= B_current_lt "CENTER")
  657.     (setvar "CELTYPE" "CENTER")
  658.     (setvar "CELTYPE" B_current_lt)
  659.   );end-iF
  660.   (setvar "OSMODE"        0)
  661.   (command "line" (polar B_nut_center B_nut_angle -3.0) (polar B_nut_center B_nut_angle (+ B_nut_ply 3.0)) ""
  662.   );end-command
  663.   (setvar "OSMODE"        51)
  664.   (setvar "CELTYPE" B_current_lt)
  665. );end-B_NUT_DRAW_CENTER_FLANK
  666. (defun B_NUT_DRAW_FLANK
  667.   (
  668.    /
  669. ;  B_nut_center
  670. ;  B_nut_radins
  671.    B_nut_polygon
  672.    B_nut_fillet
  673.    B_nut_point0
  674.    B_nut_point1
  675.    B_nut_point2
  676.    B_nut_point3
  677.    B_nut_point4
  678.    B_nut_point5
  679.    B_nut_point6
  680.   )
  681.   (setq B_nut_fillet (/ B_nut_diameter 10.0))
  682.   (setq B_nut_polygon (* B_nut_radins 1.154700538))
  683.   (setq B_nut_point0  (polar B_nut_center B_nut_angle B_nut_fillet))
  684.   (setq B_nut_point1  (polar B_nut_point0 (+ B_nut_angle 1.570796) (/ B_nut_polygon 1.0)))
  685.   (setq B_nut_point2  (polar B_nut_point0 (+ B_nut_angle 1.570796) (/ B_nut_polygon 2.0)))
  686.   (setq B_nut_point3  (polar B_nut_point0 (+ B_nut_angle 1.570796) (/ B_nut_polygon -2.0)))
  687.   (setq B_nut_point4  (polar B_nut_point0 (+ B_nut_angle 1.570796) (/ B_nut_polygon -1.0)))
  688.   (setq B_nut_point5  (polar B_nut_center (+ B_nut_angle 1.570796) (* B_nut_polygon 0.75)))
  689.   (setq B_nut_point6  (polar B_nut_center (+ B_nut_angle 1.570796) (* B_nut_polygon -0.75)))
  690.   (setvar "OSMODE"        0)
  691.   (command "line" B_nut_point1 (polar B_nut_point1 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) ""
  692.   );end-command
  693.   (command "line" B_nut_point2 (polar B_nut_point2 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) ""
  694.   );end-command
  695.   (command "line" B_nut_point3 (polar B_nut_point3 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) ""
  696.   );end-command
  697.   (command "line" B_nut_point4 (polar B_nut_point4 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) ""
  698.   );end-command
  699.   (command "line" B_nut_point5 B_nut_point6 ""
  700.   );end-command
  701.   (command "line" (polar B_nut_point5 B_nut_angle B_nut_ply) (polar B_nut_point6 B_nut_angle B_nut_ply) ""
  702.   );end-command
  703.   (command "arc" (polar B_nut_point1 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) (polar B_nut_point5 B_nut_angle B_nut_ply) (polar B_nut_point2 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0)))
  704.   );end-command
  705.   (command "arc" (polar B_nut_point4 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) (polar B_nut_point6 B_nut_angle B_nut_ply) (polar B_nut_point3 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0)))
  706.   );end-command
  707.   (command "arc" (polar B_nut_point2 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0))) (polar B_nut_center B_nut_angle B_nut_ply) (polar B_nut_point3 B_nut_angle (- B_nut_ply (* B_nut_fillet 2.0)))
  708.   );end-command
  709.   (command "arc" B_nut_point1 B_nut_point5 B_nut_point2
  710.   );end-command
  711.   (command "arc" B_nut_point3 B_nut_point6 B_nut_point4
  712.   );end-command
  713.   (command "arc" B_nut_point3 B_nut_center B_nut_point2
  714.   );end-command
  715.   (setvar "OSMODE"        51)
  716. );end-B_NUT_DRAW_FLANK
  717. (defun B_NUT
  718.   (
  719.    /
  720.    B_nut_old_cmd
  721.    B_nut_id
  722.    B_nut_last_slide
  723.    B_nut_tile
  724.    B_nut_view;视图选择变量,主视图:10201,侧视图:10202
  725.    B_nut_diameter;螺母尺寸变量
  726.    B_nut_criterion;标准号变量
  727.    B_nut_center;插入点变量
  728.    B_nut_center_x;插入点X坐标变量
  729.    B_nut_center_y;插入点Y坐标变量
  730.    B_nut_center_z;插入点Z坐标变量
  731.    B_nut_what;窗口循环变量
  732.    B_nut_angle;角度变量
  733.    B_current_layer
  734.    B_current_lt
  735.    B_nut_radins
  736.    B_nut_ply
  737.    B_nut_star
  738.    B_nut_dat_line
  739.   )
  740.   (setq B_nut_old_cmd (getvar "CMDECHO"))
  741.   (setvar "CMDECHO" 0)
  742.   (setq B_nut_id (load_dialog "B_NUT"));装入B_DRAWING.DCL
  743.   (B_NUT_ACTION_TILE)
  744.   (if (= B_nut_what 1)
  745.     (progn
  746.       (setq B_current_layer (getvar "CLAYER"))
  747.       (B_NUT_COUNT_SHAPE);读取螺母文件数据
  748.       (if (/= B_nut_dat_line nil)
  749.         (progn
  750.           (B_NUT_MAKE_LAYER);创建螺母图层
  751.           (cond
  752.             ((= B_nut_view 10201)
  753.               (B_NUT_COUNT_WHORL)
  754.               (B_NUT_DRAW_WHORL)
  755.               (setq B_nut_radins (/ (cadr B_nut_dat_line) 2.0))
  756.               (B_NUT_DRAW_SHAPE_FACE);画正面图外形
  757.               (B_NUT_DRAW_CENTER_FACE);画螺母正面图中心线
  758.             );end-10201
  759.             ((= B_nut_view 10202)
  760.               (setq B_nut_radins (/ (cadr B_nut_dat_line) 2.0))
  761.               (setq B_nut_ply (caddr B_nut_dat_line))
  762.               (B_NUT_DRAW_FLANK);画螺母
  763.               (B_NUT_DRAW_CENTER_FLANK);画螺母侧面图的中心线
  764.             );end-10202
  765.           );end-cond
  766.         );end-progn
  767.       );end-if
  768.       (setvar "CLAYER" B_current_layer)
  769.       (unload_dialog B_nut_id)
  770.     );end-progn
  771.   );end-if
  772.   (setvar "CMDECHO" B_nut_old_cmd)
  773.   (princ)
  774. );end-B_NUT
  775. 2)B_NUT.DCL
  776. /*;这是一个基于AutoCad 14.0下画螺母的程序
  777. ;本程序作者b.w
  778. ;本程序无偿使用
  779. ;如有更好建议,请联系b.w
  780. ;版本:2.0.01
  781. ;日期:14/02-2002
  782. */
  783. B_NUT: dialog
  784.    {
  785.    aspect_ralio=0;
  786.    label = "***紧固件————螺母***  版本:试用版";
  787.    :boxed_column
  788.      {
  789.      label = " ";
  790.      :row
  791.        {
  792.        :column
  793.          {
  794.          :boxed_column
  795.            {
  796.            label = "当前视图&V";
  797.            :column
  798.              {
  799.              children_alignment=centered;
  800.              :image_button
  801.                {
  802.                key = "B_NUT_VIEW_DCL";
  803.                color                   = 0;
  804.                width                   = 25;
  805.                aspect_ratio            = 0.65;
  806.                fixed_height            = true;
  807.                fixed_width             = true;
  808.                alignment = centered;
  809.                }
  810.              :popup_list
  811.                {
  812.                label = "视图选择&I: ";
  813.                key = "B_NUT_VIEW_S_DCL";
  814.                list = "主  视  图\n侧  视  图";
  815.                edit_width =10;
  816.                }
  817.              }
  818.            }
  819.          :boxed_column
  820.            {
  821.            label = " ";
  822.            :button
  823.              {
  824.              label = "选择角度&N:";
  825.              key = "B_NUT_ANGLE_S_DCL";
  826.              edit_width = 10;
  827.              alignment = centered;
  828.              }
  829.            :edit_box
  830.              {
  831.              label = "角度&A:";
  832.              key = "B_NUT_ANGLE_DCL";
  833.              edit_width = 14;
  834.              mnemonic = "N";
  835.              }
  836.            }
  837.          }
  838.        :column
  839.          {
  840.          :boxed_column
  841.            {
  842.            label = "尺寸选择";
  843.            :column
  844.              {
  845.              children_alignment=centered;
  846.              :row
  847.                {
  848.                :text_part
  849.                  {
  850.                  label = "当前尺寸&U:";     //  style name
  851.                  width =10;
  852.                  fixed_width = true;
  853.                  }
  854.                :edit_box
  855.                  {                        // for user to enter/specify
  856.                key = "B_NUT_DIAMETER_DCL";
  857.                  edit_width = 11;
  858.                  edit_limit = 10;
  859.                  }
  860.                }
  861.              :popup_list
  862.                {
  863.                label = "尺      寸&S:";
  864.                key = "B_NUT_DIAMETER_S_DCL";
  865.                list = "1.6\n2.0\n2.5\n3.0\n4.0\n5.0\n6.0\n8.0\n10.0\n12.0\n16.0\n20.0\n24.0\n30.0\n36.0\n42.0\n48.0\n56.0\n64.0";
  866.                edit_width = 10;
  867.                }
  868.              }
  869.            errtile;
  870.            }
  871.          :boxed_column
  872.            {
  873.            label = "插入点&p";
  874.            :button
  875.              {
  876.              label = "选 择 点&E <";
  877.              key = "B_NUT_CENTER_DCL";
  878.              alignment = centered;
  879.              }
  880.            :edit_box
  881.              {
  882.              label = "X:";
  883.              key = "B_NUT_CENTER_X_DCL";
  884.              edit_width = 18;
  885.              mnemonic = "X";
  886.              }
  887.            :edit_box
  888.              {
  889.              label = "Y:";
  890.              key = "B_NUT_CENTER_Y_DCL";
  891.              edit_width = 18;
  892.              mnemonic = "Y";
  893.              }
  894.            :edit_box
  895.              {
  896.              label = "Z:";
  897.              key = "B_NUT_CENTER_Z_DCL";
  898.              edit_width = 18;
  899.              mnemonic = "Z";
  900.              }
  901.            }
  902.          }
  903.        }
  904.      }
  905.    :boxed_column
  906.      {
  907.      label = "国家标准号";
  908.      key = "B_GB";
  909.       :column
  910.         {
  911.         children_alignment=centered;
  912.         :row
  913.           {
  914.           :text_part
  915.             {
  916.             label = " 当 前 标 准 号&C:";
  917.             width =10;
  918.             fixed_width = true;
  919.             }
  920.           :edit_box
  921.             {
  922.           key = "B_NUT_CRITERION_DCL";
  923.             edit_width = 32;
  924.             edit_limit = 100;
  925.             }
  926.           }
  927.         :popup_list
  928.           {
  929.           label = "选 择 标 准 号 &B:";
  930.           key = "B_NUT_CRITERION_S_DCL";
  931.           list = "I型六角螺母-A和B级(GB6170-1986)\nI型六角螺母-C级(GB/T41-1986)\n六角薄螺母-A和B级(GB6172-1986)";
  932.           edit_width = 31.2;
  933.           }
  934.         }
  935.      }
  936.    : row
  937.       {
  938.       alignment=centered;
  939.       ok_cancel;
  940.       }
  941.    : boxed_column
  942.       {
  943.       label = " ";
  944.        : text
  945.           {
  946.           label="  >>版权所有,翻录不究<<";
  947.           alignment=centered;
  948.           }
  949.        : text
  950.           {
  951.           label="     >>作者:B。W<<";
  952.           alignment=centered;
  953.           }
  954.       }
  955.    }
  956. 3)B_NUT_B.DAT
  957. 1.6,3.2,1.0
  958. 2.0,4.0,1.2
  959. 2.5,5.0,1.6
  960. 3.0,5.5,1.8
  961. 4.0,7.0,2.2
  962. 5.0,8.0,2.7
  963. 6.0,10.0,3.2
  964. 8.0,13.0,4.0
  965. 10.0,16.0,5.0
  966. 12.0,18.0,6.0
  967. 16.0,24.0,8.0
  968. 20.0,30.0,10.0
  969. 24.0,36.0,12.0
  970. 30.0,46.0,15.0
  971. 36.0,55.0,18.0
  972. 42.0,65.0,21.0
  973. 48.0,75.0,24.0
  974. 56.0,85.0,28.0
  975. 64.0,95.0,32.0
  976. 4)B_NUT_I.DAT
  977. 1.6,3.2,1.3
  978. 2.0,4.0,1.6
  979. 2.5,5.0,2.0
  980. 3.0,5.5,2.4
  981. 4.0,7.0,3.2
  982. 5.0,8.0,4.7
  983. 6.0,10.0,5.2
  984. 8.0,13.0,6.8
  985. 10.0,16.0,8.4
  986. 12.0,18.0,10.8
  987. 16.0,24.0,14.8
  988. 20.0,30.0,18.0
  989. 24.0,36.0,21.5
  990. 30.0,46.0,25.6
  991. 36.0,55.0,31.0
  992. 42.0,65.0,34.0
  993. 48.0,75.0,38.0
  994. 56.0,85.0,45.0
  995. 64.0,95.0,51.0
  996. 5)B_NUT_C.DAT
  997. 5.0,8.0,5.6
  998. 6.0,10.0,6.1
  999. 8.0,13.0,7.9
  1000. 10.0,16.0,9.5
  1001. 12.0,18.0,12.2
  1002. 16.0,24.0,15.9
  1003. 20.0,30.0,18.7
  1004. 24.0,36.0,22.3
  1005. 30.0,46.0,26.4
  1006. 36.0,55.0,31.5
  1007. 42.0,65.0,34.9
  1008. 48.0,75.0,38.9
  1009. 56.0,85.0,45.9
  1010. 64.0,95.0,52.4
  1011. [/FONT]
GMT+8, 2026-11-3 01:34 , Processed in 0.436099 second(s), 32 queries , Gzip On.
