查看: 1081|回复: 4
[分享]:CAD快捷键
发表于 2003-7-11 11:27:09 | 显示全部楼层 |阅读模式
cad的使用,要养成一手键盘,一手鼠标的习惯,要不然,速度永远也别想提高
3A, *3Darray
3F, *3Dface
3P, *3Dpoly
A, *Arc
Aa, *Matchprop
Aad, *Aseadmin
Aex, *Aseexport
Al, *Align
Ali, *Aselinks
Ap, *Appload
Ar, *Array
Aro, *Aserows
Ase, *Aseselect
Asq, *Asesqled
At, *Ddattdef
-At, *Attdef
Ate, *Ddatte
-Ate, *Attedit
Av, *Dsviewer
B, *Bmake
-B, *Block
Bh, *Bhatch
Bo, *Boundary
-Bo, *-Boundary
Br, *Break
C, *Circle
Cc, *Copy
Cg, *Chprop
-Ch, *Change
Cha, *Chamfer
Col, *Ddcolor
D, *Dist
Dal, *Dimaligned
Dan, *Dimangular
Dba, *Dimbaseline
Dce, *Dimcenter
Dco, *Dimcontinue
Dd, *Ddim
Ddi, *Dimdiameter
Ded, *Dimedit
Dimali, *Dimaligned
Dimang, *Dimangular
Dimbase, *Dimbaseline
Dimcont, *Dimcontinue
Dimdia, *Dimdiameter
Dimed, *Dimedit
Dimlin, *Dimlinear
Dimord, *Dimordinate
Dimover, *Dimoverride
Dimrad, *Dimradius
Dimsty, *Dimstyle
Dimted, *Dimtedit
Div, *Divide
Dli, *Dimlinear
Do, *Donut
Dor, *Dimordinate
Dov, *Dimoverride
Dr, *Draworder
Dra, *Dimradius
Dst, *Dimstyle
Dt, *Dtext
Dv, *Dview
E, *Erase
Ed, *Ddedit
El, *Ellipse
Ex, *Extend
Exit, *Quit
Exp, *Export
Ext, *Extrude
F, *Offset
Ff, *Fillet
Fi, *Filter
G, *Group
-G, *Group
Gr, *Ddgrips
H, *Bhatch
-H, *Hatch
He, *Hatchedit
Hi, *Hide
I, *Ddinsert
-I, *Insert
Iad, *Imageadjust
Iat, *Imageattach
Icl, *Imageclip
Im, *Image
-Im, *-Image
Imp, *Import
In, *Intersect
Inf, *Interfere
Io, *Insertobj
La, *Layer
-La, *-Layer
Le, *Leader
Lead, *Leader
Len, *Lengthen
Li, *List
Ls, *List
Lt, *Linetype
-Lt, *-Linetype
Lts, *Ltscale
Me, *Measure
Ml, *Mline
Mo, *Ddmodify
Ms, *Mspace
Mt, *Mtext
Mv, *Mview
Os, *Ddosnap
-Os, *-Osnap
-P, *-Pan
Pa, *Pastespec
Pe, *Pedit
Po, *Point
Pol, *Polygon
Pr, *Preferences
Pre, *Preview
Print, *Plot
Ps, *Pspace
Pu, *Purge
Q, *Plan
R, *Redraw
Ra, *Redrawall
Re, *Regen
Rea, *Regenall
Rec, *Rectangle
Reg, *Region
Ren, *Ddrename
-Ren, *Rename
Rev, *Revolve
Rm, *Ddrmodes
Rpr, *Rpref
Rr, *Mirror
Rt, *Rotate
S, *Pan
Sa, *Shade
Sc, *Scale
Scr, *Script
Se, *Ddselect
Sec, *Section
Set, *Setvar
Sl, *Slice
Sn, *Snap
So, *Solid
Sp, *Spell
Spe, *Splinedit
Spl, *Spline
Ss, *Stretch
St, *Style
Su, *Subtract
-T, *-Mtext
Ta, *Tablet
Th, *Thickness
Ti, *Tilemode
Tm, *Tilemode
To, *Toolbar
Tol, *Tolerance
Tor, *Torus
Tr, *Trim
Ttt, *Mtext
Uc, *Dducs
Ucp, *Dducsp
Un, *Ddunits
-Un, *Units
Uni, *Union
V, *Move
-V, *View
Ve, *Ddview
Vp, *Ddvpoint
Vv, *Vpoint
W, *Wblock
We, *Wedge
Ww, *Ucs
X, *Line
Xa, *Xattach
Xb, *Xbind
-Xb, *-Xbind
Xc, *Xclip
Xl, *Xline
Xr, *Xref
-Xr, *-Xref
Xx, *Pline
Xxx, *Explode
Z, *Zoom :5 :5
发表于 2003-7-12 09:28:14 | 显示全部楼层
每人习惯不同,设置也会不一样
发表于 2003-7-12 17:21:42 | 显示全部楼层
是系统安装默认的快捷键吗?
发表于 2003-7-12 18:49:59 | 显示全部楼层
怎样修改快捷键?我记得以前AUTO2000的EXPRESS里面有,现在AUTOCAD2002却没有,不知为什么?
发表于 2003-7-13 10:31:45 | 显示全部楼层
其实只要在系统目录下找到acad.pgp文件用笔记本打开就可以修改
设置自己喜欢的快捷键了
GMT+8, 2026-11-3 02:14 , Processed in 0.457672 second(s), 40 queries , Gzip On.
