查看: 1763|回复: 0
[每日一码] ARX命名一个UCS并设置为当前
发表于 2016-10-24 16:35:06 | 显示全部楼层 |阅读模式
 static void asdkucsarx_test(void)
        Acad::ErrorStatus es;
        AcDbUCSTableRecord *myUCS = new AcDbUCSTableRecord;
        //define your own ucs
        AcGePoint3d  origin_point(0,0,0);
        AcGeVector3d UCSXaxis(0,1,0);
        AcGeVector3d UCSYaxis(1,0,0);
        myUCS->setOrigin(origin_point);
        myUCS->setXAxis(UCSXaxis);
        myUCS->setYAxis(UCSYaxis);
        es=myUCS->setName( _T("MyUCS"));
        if (es != Acad::eOk)
                acutPrintf(_T("\nFailed to set name"));
                return;
        AcDbObjectId UCSId;
        AcDbSymbolTable *pUCSTable;
        if (acdbHostApplicationServices()->workingDatabase()->
                getUCSTable(pUCSTable,AcDb::kForWrite)==Acad::eOk)
                es=pUCSTable->add(UCSId,myUCS);
                es=pUCSTable->close();
                es= myUCS->close();
        else
                acutPrintf(_T("\nFailed to get UCS table"));
                return;
        //To set the current UCS, I accessed
        // the active AcDbViewportTableRecord
        // and used setUCS to set the UCS I created as current.
        AcDbViewportTable *pVT;
        es = acedVports2VportTableRecords();
                acutPrintf(
                        _T("\nFailed to load vport info into vport table records"));
                return;
        es=acdbHostApplicationServices()->
                workingDatabase()->getViewportTable(pVT,AcDb::kForRead);
                acutPrintf(_T("\nFailed to get vport table"));
                pVT->close();
                return;
        AcDbViewportTableIterator* pIter = NULL;
        es=pVT->newIterator(pIter);
                pVT->close();
                delete pIter;
                return;
        for (pIter->start();!pIter->done();pIter->step())
                AcDbViewportTableRecord* pRec;
                //it should be open for write mode
                es=pIter->getRecord(pRec,AcDb::kForWrite);
                        acutPrintf(
                                _T("\nFailed to get vport table record"));
                        pVT->close();
                        pRec->close();
                        delete pIter;
                        return;
                TCHAR* name=NULL;
                es=pRec->getName(name);
                        acutPrintf(
                                _T("\nFailed to get name from vport table"));
                        pVT->close();
                        pRec->close();
                        delete pIter;
                        return;
                if (_tcsicmp(name,_T("*ACTIVE"))==0)
                        es=pRec->setUcs(UCSId);
                es=pRec->close();
        es=acedVportTableRecords2Vports(); //force update
        es=pVT->close();
        delete pIter;
        return ;
GMT+8, 2026-11-22 08:11 , Processed in 0.300130 second(s), 11 queries , Gzip On, File On.
