查看: 3857|回复: 7
[图块] 交互提取块内实体轮廓线
发表于 2016-11-22 20:58:41 | 显示全部楼层 |阅读模式
  • 插件名称 : 块内轮廓
  • 作  者 : Lispboy
  • 运行环境 :XDRX API 晓东工具箱
  • 发布时间 :2016-11-22
  • 命令名称 :XDTB_BlockSingleBound
  • 插件介绍 :交互提取块内实体轮廓线
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
[sell]
(defun c:XDTB_BlockSingleBound (/ blk bound bound1 e el el1 ents mat mat-b2w
                                  mat-w2b pts1 pts2 scr ss1 tf wid x yon
  (defun _getent (e / bound x)
    (mapcar
      '(lambda (x)
         (if (xdrx_entity_boundingboxintersectwith x e)
           (progn
             (xdrx_curve_union x e t)
             (xdrx_setpropertyvalue (entlast) "constantwidth" wid)
             (xdrx_object_swapid (entlast) e)
             (xdrx_entity_delete (list x (entlast)))
      ents
  (xdrx_begin)
  (if (not #block_wid)
    (setq #block_wid 0.0)
  (if (not #block_color)
    (setq #block_color 7)
  (if (not #block_gen)
    (setq #block_gen "是")
  (setq scr (xdrx_system_screenMetrics)
        scr (cadr scr)
        scr (/ scr 100)
  (setq tf t)
  (xdrx_setmark)
  (setq ents nil)
  (while tf
    (xdrx_initget "C W G")
    (xdrx_prompt "\n当前设置:颜色(" #block_color ") / 宽度(" #block_wid
                 ") / 所有块生成(" #block_gen ")"
    (if (setq e (nentsel "\n拾取块中要提取轮廓的多段线[颜色(C)宽度(W)/生成(G)]<退出>:"))
      (cond
        ((= e "W")
          (if (setq wid (getreal (xdrx_prompt "\n输入轮廓线宽度<" #block_wid
                                              ">:" t
            (setq #block_wid wid)
        ((= e "G")
          (setq yon (xdrx_yesorno "\n是否所有块生成轮廓线" 1))
          (if (= yon 1)
            (setq #block_gen "否")
        ((= e "C")
          (setq #block_color (xdrx_color_select #block_color))
        ((= (type e) 'LIST)
          (setq blk (car (last e))
                e (car e)
                mat-b2w (xdrx_matrix_block2wcs blk)
                pts1 (xdrx_getpropertyvalue e "vertices")
                pts2 (xdrx_points_transform pts1 mat-b2w)
          (if (setq bound1 (xdrx_geom_searchoutline e wid))
            (progn
              (xdrx_entity_transform bound1 mat-b2w)
              (_getent bound1)
              (setq ents (cons bound1 ents))
              (xdrx_entity_setproperty ents "color" 1 "constantwidth" scr)
            (xdrx_prompt "\n选择的实体不能生成轮廓,重选.")
      (setq tf nil)
  (setq ss1 (xdrx_getss 9)
        el1 (xdrx_pickset->ents ss1)
  (xdrx_entity_setproperty ss1 "color" #block_color "constantwidth" wid)
  (if (and
        ss1
        (= #block_gen "是")
    (progn
      (setq el (xdrx_getpropertyvalue blk "BlockReferenceEntities"))
      (setq mat-w2b (xdrx_matrix_inverse mat-b2w))
      (mapcar
        '(lambda (x)
           (setq mat (xdrx_matrix_block2wcs x)
                 mat (xdrx_matrix_product mat mat-w2b)
           (xdrx_entity_transformedcopy ss1 mat)
        el
  (xdrx_end)
  (if (setq ss1 (xdrx_getss))
    (sssetfirst nil ss1)
  (princ)
[/sell]
发表于 2016-11-23 09:55:41 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2016-11-24 13:30:23 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2016-11-25 18:46:05 | 显示全部楼层
这个很实用。
发表于 2018-7-30 21:12:09 | 显示全部楼层
感谢楼主分享哇
发表于 2018-9-7 04:35:21 | 显示全部楼层
谢谢!!下载学习了
发表于 2020-6-6 10:38:43 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2020-11-30 01:43:36 | 显示全部楼层
非常有用!!感谢分享!!!
GMT+8, 2026-11-22 10:33 , Processed in 0.206049 second(s), 24 queries , Gzip On, File On.
