查看: 8570|回复: 17
[统计] 填充图例表
发表于 2016-12-3 15:40:45 | 显示全部楼层 |阅读模式
  • 插件名称 : 填充图例
  • 作  者 : Lispboy
  • 运行环境 :XDRX API 晓东工具箱
  • 发布时间 :2016-12-03
  • 命令名称 :XDTB_TJHATULI
  • 插件介绍 :统计全图所有的填充,建图例表
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
创建图中所有填充的图例表,后续想当刷子还是什么的,自己决定
[sell]
(defun c:XDTB_TJHATULI ( / blk clr e h ha hascl i lst lyr mode name scl ss x y)
  (defun _maketuli (clr mode lyr)
    (setq e (xdrx_polyline_make (xd::pnt:getrecpnts '(0 0 0) (* scl 10.)
                                                    (* 5 scl)
                                ) t
    (xdrx_setpropertyvalue e "constantwidth" (* scl 0.3) "color" 7 "layer"
                           lyr
    (setq ha (xdrx_hatch_make e))
    (xdrx_setpropertyvalue ha "color" clr "patternname" mode "layer" lyr)
    (setq name (xdrx_prompt "XD-TJ-HA-" mode "-" clr t))
    (if (not (setq blk (xdrx_object_get "block" name)))
      (progn
        (xdrx_block_make (strcase name) (list e ha) '(0 0 0.) t)
        (xdrx_entity_delete (entlast))
        (xdrx_draworder->back (setq ha (car (xdrx_block_getentities blk '
        (0 . "HATCH")
        (setq hascl (XD::Hatch:GetSclByGap mode (* 1.414 scl)))
        (xdrx_setpropertyvalue ha "PatternScale" hascl "patternname"
                               (list 1 mode)
    blk
  (if (setq ss (ssget "x" '((0 . "HATCH"))))
    (progn
      (setq scl (* (xd::var:getratio) (xd::var:getscaleratio)))
      (setq lst (mapcar
                  '(lambda (x)
                     (list (xdrx_getpropertyvalue x "patternname") x)
                  (xdrx_pickset->ents ss)
            lst (xd::list:groupbyindex lst 0.01)
            lst (vl-sort lst '(lambda (x y)
                                (< (car x) (car y))
            lst (mapcar
                  '(lambda (x)
                     (list (car x) (cadr x))
                  lst
            i 0
            lst (mapcar
                  '(lambda (x)
                     (setq i (1+ i))
                     (list (itoa i) (_maketuli (setq clr
        (last x) "color" t
                                               (car x) (setq lyr
        (last x) "layer" nil
                                    ) (car x) lyr
                           (vl-princ-to-string clr)
                  lst
            lst (append (list (list "填充图例表" nil nil nil nil) (list "序号" "图例" "模式" "图层" "颜色")) lst)
      (if (not #hatch_tuli_txth)
        (setq #hatch_tuli_txth 5.0)
      (if (setq h (getreal (xdrx_prompt "\n字高<" #hatch_tuli_txth ">:" t)))
        (setq #hatch_tuli_txth h)
      (xd::text:Init 1)
      (xd::table:makefromlist lst '(0 0 0) #hatch_tuli_txth (/ #hatch_tuli_txth 2.0))
      (if (vl-catch-all-error-p (vl-catch-all-apply 'XD::Drag:SimpleMove (list (entlast) "\n表格插入点:" 8 t)))
  (princ)
[/sell]
发表于 2016-12-3 15:56:07 | 显示全部楼层
正需要,支持楼主大人了!
发表于 2016-12-3 16:54:37 | 显示全部楼层
回的人少,我来小顶一下
发表于 2016-12-3 19:29:42 | 显示全部楼层
谢谢楼主,下来学习。
发表于 2016-12-4 00:12:35 | 显示全部楼层
谢谢提供,要那么多币币呀,呵呵
发表于 2016-12-4 08:44:59 | 显示全部楼层
正需要,支持楼主大人了!
发表于 2016-12-4 09:19:25 | 显示全部楼层
不错,这个挺全的!
发表于 2016-12-4 11:26:04 | 显示全部楼层
确实是难得好帖啊,顶先
发表于 2016-12-4 18:53:04 | 显示全部楼层
楼主的作品都是精品啊,太好了,谢谢
发表于 2016-12-6 09:05:51 | 显示全部楼层
谢谢楼主分享!!!!
发表于 2016-12-6 14:31:35 | 显示全部楼层
确实是难得好帖啊,顶先
发表于 2016-12-28 11:27:12 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-6-12 00:11:32 | 显示全部楼层
这个有点强大了!!
发表于 2017-11-1 10:26:47 | 显示全部楼层
这个好,要支持一下
发表于 2018-7-18 11:19:32 | 显示全部楼层
精品啊,太好了,谢谢
GMT+8, 2026-11-22 07:39 , Processed in 0.383190 second(s), 38 queries , Gzip On, File On.
