查看: 1099|回复: 0
[求助]:通过AcDbRegion生成AcBrBrep再检测点的相对位置,返回总是0?附源程序
发表于 2003-7-14 22:47:19 | 显示全部楼层 |阅读模式
目的:通过封闭的线生成一个AcDbRegion 再生成AcDbBrep
再检测点或者线与它的相对位置,但返回值总是0 unknowed?
如下:
AcDbObjectIdArray ids;
if( selectEntitys( ids )!=RTNORM )
        return;
Acad::ErrorStatus es;
AcDbVoidPtrArray curves;
AcDbVoidPtrArray regions;
AcDbRegion *pRegion=NULL;
AcDbObject* pObj;
AcDbObjectId regionId;
for( int iii=0; iii<ids.logicalLength(); iii++ )        {
if( acdbOpenObject( pObj,ids[iii],AcDb::kForRead ) ) {
   acutPrintf("\nacdbOpenObject failed");
        continue;
curves.append( (void*)pObj );
if( (es = AcDbRegion::createFromCurves(curves, regions)) != Acad::eOk ) {
        acutPrintf("\ncreateFromCurves failed ");
                AfxMessageBox(" not ok ");
else{
AfxMessageBox(" ok ");
int nums=regions.length();
acutPrintf(" num==%d ",nums );
if( nums<=0 ){
   acutPrintf(" 0regions ");
  es=Acad::eInvalidInput;
else if( nums>1 ){
acutPrintf(" %d-regions ",nums);
for( iii=0; iii<nums; iii++ ){
   delete ((AcDbObject*)regions[iii]);
else if( (pRegion = AcDbRegion::cast((AcRxObject*)regions[0])) == NULL){
        acutPrintf("\nCouldn't generate region\n");
AfxMessageBox(" === ");
if( es==Acad::eOk )
  postToDb( pRegion, regionId );
for( iii=0; iii<curves.length(); iii++ )
((AcDbObject*)curves[iii])->close();
AcGePoint3d pt;
//AcBrBrep *pBrep=NULL;
AcBr::Relation relation;
int retcode;
if( es==Acad::eOk ){
AfxMessageBox("brep---start");
acdbOpenAcDbEntity( (AcDbEntity*&) pRegion, regionId, AcDb::kForRead );
AcBrBrep*pBrep = new AcBrBrep;
pBrep->setSubentPath( AcDbFullSubentPath( regionId, AcDbSubentId()));
AcGe::PointContainment containment;
AcBrEntity* container;
//或者如下生成也同样
//pBrep= (AcBrBrep*) pRegion->body();
//pBrep = new AcBrBrep;
//pBrep->set( (AcDbEntity&) pRegion );
AfxMessageBox("brep");
if( pBrep==NULL ){
AfxMessageBox("null");
else{
while(1){
if( acedGetPoint( NULL,"pt ",asDblArray(pt ))==RTNORM ){
//pBrep->getPointRelationToBrep(pt, relation);
pBrep->getPointContainment( pt, containment,container);
acutPrintf("  AcBr=%d ",containment );
//返回值总是0 为什么???
if( containment==AcGe::kInside ){
                                                retcode=1;
else if( containment==AcGe::kOnBoundary){
                                                retcode=0;
else if( containment==AcGe::kOutside){
                                                retcode=-1;
else{
                                        retcode=-20;
                                        //else
                                        //        retcode=-10;
                                        acutPrintf(" %d ", retcode );
                                        //if( container!=NULL )
                                        //        delete container;
                                else
                                        break;
delete pBrep;
                pRegion->close();
        //for( iii=0; iii<curves.length(); iii++ )
        //        ((AcDbObject*)curves[iii])->close();
        //if( pRegion!=NULL )
        //        delete pRegion;
GMT+8, 2026-11-3 19:09 , Processed in 0.583094 second(s), 32 queries , Gzip On.
