查看: 1004|回复: 0
[分享]:手动修复工具箱搜索路径
已领礼包: 593个
发表于 2003-7-26 13:15:04 | 显示全部楼层 |阅读模式
用于手动添加支持路径到当前配置,你所作的仅是任意指定一个工具箱目录下的文件(用于CAD2002)
  1. (defun c:addxdsoft (/                 str-cut      StrUnParse   str-search
  2.                     $dir         oldsup              xdsoftpath   newsupport
  3.                    )
  4.   (defun str-cut (fa-str str how / len li no)
  5.     (setq len (strlen str))
  6.     (while (setq no (vl-string-search str fa-str))
  7.       (if (/= no 0)
  8.         (setq li (cons (substr fa-str 1 no) li))
  9.       )
  10.       (setq li           (cons (substr fa-str (1+ no) len) li)
  11.             fa-str (substr fa-str (+ no len 1))
  12.       )
  13.     )
  14.     (if        (/= "" fa-str)
  15.       (setq li (cons fa-str li))
  16.     )
  17.     (if        how
  18.       (vl-remove str (reverse li))
  19.       (reverse li)
  20.     )
  21.   )
  22.   ;;相当xdrx_txtsrch
  23.   ;;出现的位置
  24.   ;;(str-search "12341234123456""12")-->(1 5 9)
  25.   (defun str-search (fa-str str / a len li no)
  26.     (setq len (strlen str)
  27.           a   0
  28.     )
  29.     (while (setq no (vl-string-search str fa-str a))
  30.       (setq li (cons no li)
  31.             a  (+ len no)
  32.       )
  33.     )
  34.     (mapcar '1+ (reverse li))
  35.   )
  36. ;;;==================================================================
  37. ;;; (StrUnParse Lst Delimiter)
  38. ;;;                Parses a list of strings into 1 delemited string
  39. ;;;------------------------------------------------------------------
  40. ;;; Parameters:
  41. ;;;                Str                        List to concantenate
  42.   (defun StrUnParse (Lst Delimiter / return)
  43.     (setq return "")
  44.     (foreach str Lst
  45.       (setq return (strcat return Delimiter str))
  46.     ) ;_ end of foreach
  47.     (substr return 2)
  48.   ) ;_ end of defun
  49.   (setq $dir (getfiled "选择晓东工具箱任意文件" "" "" 4))
  50.   (setq oldsup (getenv "ACAD"))
  51.   (if (and $dir
  52.            (vl-string-search "XDSOFT" (strcase $dir))
  53.            (/= (length (str-search (strcase oldsup) "XDSOFT")) 4)
  54.       )
  55.     (progn
  56.       (if (str-search (strcase oldsup) "XDSOFT")
  57.         (progn
  58.           (setq tmplst (reverse (str-cut oldsup ";" t)))
  59.           (while (str-search (strcase (car tmplst)) "XDSOFT")
  60.             (setq tmplst (cdr tmplst))
  61.           )
  62.           (setq oldsup (strunparse (reverse tmplst) ";"))
  63.         )
  64.       )
  65.       (setq
  66.         xdsoftpath
  67.                    (strunparse
  68.                      (reverse
  69.                        (member "XDSOFT" (reverse (str-cut (strcase $dir) "\" t)))
  70.                      )
  71.                      "\"
  72.                    )
  73.         newsupport (strcat oldsup
  74.                            ";"
  75.                            (strcat xdsoftpath "\\SYS;")
  76.                            (strcat xdsoftpath "\\LISP;")
  77.                            (strcat xdsoftpath "\\LIB;")
  78.                            (strcat xdsoftpath "\\BIN")
  79.                    )
  80.       )
  81.       (setenv "ACAD" newsupport)
  82.       (if (not (menugroup "xdsoft"))
  83.         (command ".menuload" "xdsoft")
  84.       )
  85.       (princ "\n成功添加 XDSoft 工具箱!")
  86.     )
  87.     (princ "\n不是工具箱目录文件!")
  88.   )
  89.   (princ)
  90. )
  91. (c:addxdsoft)
GMT+8, 2026-11-7 06:04 , Processed in 0.461984 second(s), 32 queries , Gzip On.
