查看: 1422|回复: 10
[推荐]:我的acad.pgp,涵盖了大部分acad2002与ET1.9的常用命令
发表于 2003-8-3 14:00:46 | 显示全部楼层 |阅读模式
acad2002自带的acad.pgp简写命令并不完整,我对照帮助的命令大全写了自己的acad.pgp。说明如下:
   1. 按照acad2002和附带的ET1.9帮助中的命令清单整理。
   2.有些命令点取工具条效率较高就没写进来,比如dim的系列命令,还有少数我个人很少用的命令没有写进来。
   3.功能可以相互代替的就用一个命令代替
   4.没有按照许多人推荐的左手键方式编写,这是属于个人习惯问题,当然也可以自己再修改。
   5.大写的命令为cad2002自带的命令,小写的为ET1.9的命令。
=,         *matchprop
+,         *union
-,         *subtract
*,         *intersect
3A,        *3DARRAY
3F,        *3DFACE
3P,        *3dpan
3O,        *3DORBIT
3PL,       *3DPOLY
3R,        *rotate3d
3M,        *mirror3d
3W,        *3dswivel
3Z,        *3dzoom
A,         *ARC
AC,        *ADCENTER
act,       *arctext
AR,        *AREA
AL,        *ALIGN
AY,        *ARRAY
B,         *BLOCK
b2x,       *blocktoxref
ba,        *battman
bet,       *bextend
bl,        *breakline
BO,        *BOUNDARY
bp,        *blockreplace
bt,        *btrim
BR,        *BREAK
bu,        *burst
C,         *copy
CB,        *copybase
c2l,       *copytolayer
CH,        *CHAMFER
CI,        *CIRCLE
cli,       *clipit
D,         *DIST
DI,        *DIVIDE
dme,       *dimex
dmi,       *dimim
DS,        *DSETTINGS
DX,        *DTEXT
E,         *ERASE
EE,        *EATTEDIT
EL,        *ELLIPSE
EDS,       *EDGESURF
ET,        *EXTEND
etr,       *extrim
EU,        *EXTRUDE
f,         *exfillet
fl,        *flatten
Ft,        *FILTER
FI,        *FIND
G,         *GROUP
ga,        *gatte
gs,        *getsel
H,         *BHATCH
HE,        *HATCHEDIT
I,         *INSERT
ID,        *ID
L,         *LINE
l=,        *laymch
LA,        *LAYER
lc,        *laycur
ld,        *laydel
LE,        *LENGTHEN
lf,        *layoff
LI,        *LIST
lk,        *laylck
lm,        *laymrg
lma,       *lman
ln,        *layon
ls,        *layiso
lsps,      *lspsurf
ltr        *laytrans
luk,       *layulk
lus,       *layuniso
lv,        *layvpi
lvm,       *layvpmode
lw,        *laythw
lwa,       *laywalk
lz,        *layfrz
M,         *MOVE
mco,       *mocoro
ME,        *MEASURE
MI,        *MIRROR
ML,        *MLINE
MLE,       *MLEDIT
MLS,       *MLSTYLE
mpe,       *mpedit
MT,        *MTEXT
MU,        *Multiple
MV,        *MVIEW
nc,        *ncopy
o,         *exoffset
OP,        *OPTIONS
ok,        *overkill
P,         *PAN
PE,        *PEDIT
pj,        *pljoin
PL,        *PLINE
PR,        *PROPERTIES
QD,        *QDIM
QL,        *QLEADER
QS,        *QSELECT
R,         *REDRAW
rc,        *revcloud
RE,        *REGEN
RT,        *RECTANGLE
RG,        *REGION
RO,        *ROTATE
RES,       *REVSURF
RUS,       *RULESURF
RV,        *REVOLVE
S,         *STRETCH
SE,        *SECTION
SC,        *SCALE
SCT,       *scaletext
SI,        *SLICE
SO,        *SOLID
SOE,       *SOLIDEDIT
SOP,       *SOLPROF
SOV,       *SOLVIEW
SP,        *SPLINE
st,        *mstretch
STD,       *standards
STY,       *style
ssx,       *ssx
suh,       *superhatch
T,         *TRIM
TB,        *TOOLBAR
TAS,       *TABSURF
te,        *tedit
tf,        *textfit
tm,        *textmask
U,         *U
UC,        *DDUCS
UCI,       *UCSICON
UCP,       *DDUCSP
UN,        *UNITS
V,         *ddVIEW
VI,        *VIEWRES
VP,        *DDVPOINT
W,         *WBLOCK
wi,        *wipeout
X,         *EXPLODE
XC,        *XCLIP
xli,       *xlist
XP,        *XPLODE
xpa,       *xpath
XR,        *XREF
Z,         *ZOOM
发表于 2003-8-3 17:45:02 | 显示全部楼层
acad.pgp
这个文件很有用,可以把命令修改成自己方便的简写,加快输入速度
用编辑软件可以方便的编辑这个文件
发表于 2003-8-3 17:47:18 | 显示全部楼层
E.T1.9是什么东西????
发表于 2003-8-3 17:50:41 | 显示全部楼层
最初由 lvt2321 发布
[B]E.T1.9是什么东西???? [/B]
那是CAD的扩展工具。
发表于 2003-8-3 18:10:10 | 显示全部楼层
存盘了,用用看,辛苦了
发表于 2003-8-3 20:42:30 | 显示全部楼层
我DELETE命令不可用了。不知道在.PGP文件下要怎样定义?
发表于 2003-8-3 21:39:25 | 显示全部楼层
命令比较全,有参考价值,谢谢!
发表于 2003-8-4 09:01:05 | 显示全部楼层
请问2004下。PGP文件放在什么位置了?
发表于 2003-8-5 01:59:07 | 显示全部楼层
AUTOCAD2004\USERDATACACHE\SUPPORT
发表于 2003-8-17 11:13:12 | 显示全部楼层
E.T1.9是什么东西????
发表于 2003-8-17 22:05:06 | 显示全部楼层
我还是习惯左手键,方便多了。每个人习惯不一样。
GMT+8, 2026-11-3 07:02 , Processed in 0.653985 second(s), 52 queries , Gzip On.
