查看: 810|回复: 10
[密技]:我设计的快捷键认你分享
发表于 2003-8-4 13:25:12 | 显示全部楼层 |阅读模式
;  AutoCAD Program Parameters File For AutoCAD Release 14
;  External Command and Command Alias Definitions
;  Copyright (C) 1997 by Autodesk, Inc.
;  Each time you open a new or existing drawing, AutoCAD searches
;  the support path and reads the first acad.pgp file that it finds.
;  While AutoCAD is running, you can invoke other programs or utilities,
;  such Windows system commands, utilities, and applications.
;  You define external commands by specifying a command name to be used
;  from the AutoCAD command prompt and an executable command string
;  that is passed to the operating system.
;  You can abbreviate frequently used AutoCAD commands by defining
;  aliases for them in the command alias section of acad.pgp.
;  You can create a command alias for any AutoCAD command,
;  device driver command, or external command.
;  Recommendation: back up this file before editing it.
;  There is a bonus application for editing command aliases as well as
;  a sample acad.pgp file with many more command aliases.
;  See the bonus\cadtools folder for more details.
;  External command format:
;  <Command name>,[<DOS request>],<Bit flag>,
  • <Prompt>,
    ;  The bits of the bit flag have the following meanings:
    ;  First bit (1): if set, don't wait for the application to finish
    ;  Second bit (2): if set, run the application minimized
    ;  Third bit (4): if set, run the application "hidden"
    ;  Bits 2 and 4 are mutually exclusive; if both are specified only the 2 bit is used.
    ;  The most useful values are likely to be 0 (start the application and wait
    ;  for it to finish), 1 (start the application and don't wait), 3 (minimize and don't
    ;  wait), and 5 (hide and don't wait). Values of 2 and 4 should normally be avoided,
    ;  as they make AutoCAD unavailable until the application has completed.
    ;  Examples of external commands for command windows
    DEL,       DEL,            0,请输入将被删除的文件: ,
    DIR,       DIR,            0,请输入待列表的文件: ,
    TYPE,      TYPE,           0,请输入须显示内容的文件名: ,
    fcopy,     copy,           0,请输入拷贝源文件及目标文件(中间隔以空格): ,
    ren,       ren,            0,请输入改名源文件名及目标文件名(中间隔以空格): ,
    EDIT,      START EDIT,     1,请输入待编辑的文件: ,
    SH,        ,               1,*DOS Command: ,
    SHELL,     ,               1,*SHELL to dos command :,
    START,     START,          1,*Application to start: ,
    ; Examples of external commands for Windows
    ; See also the STARTAPP AutoLISP function for an alternative method.
    EXPLORER,  START EXPLORER, 1,,
    NOTEPAD,   START NOTEPAD,  1,*请输入待编辑的文件: ,
    PBRUSH,    START PBRUSH,   1,,
    ; Command alias format:
    ;   <Alias>,*<Full command name>
    ;  The following are guidelines for creating new command aliases.
    ;  1.  Try the first character of the command, then try the first two,
    ;         then the first three.
    ;  2.  Ignore "DD" at the beginning of a command.
    ;  3.  Abbreviate the following prefixes:
    ;        Examples: 3 for 3D, A for ASE, D for Dim, I for Image, R for render.
    ;  4.  Once an alias is defined, add suffixes for related aliases:
    ;        Examples: R for Redraw, RA for Redrawall, L for Line, LT for Linetype.
    ;  5.  An alias should reduce a command by at least two characters.
    ;  6.  Commands with a control key equivalent, status bar button, or function key
    ;        do not require a command alias.
    ;        Examples: Use Control-N, -O, -P, and -S for New, Open, Print, and Save
    ;  7.  Use a hyphen to differentiate between command line and dialog box commands.
    ;  8.  Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
    ;  Sample aliases for AutoCAD commands
    ;  These examples include most frequently used commands.
    3A,    *3DARRAY
    3F,    *3DFACE
    3P,    *3DPOLY
    Aa,     *ARRAY
    AD,    *ID
    AE,    *AREA
    AL,    *ALIGN
    AP,    *APERTURE
    ATP,   *ATTDISP
    AT,    *DDATTE
    -AT,   *ATTEDIT
    ATT,   *DDATTDEF
    -ATT,  *ATTDEF
    AV,    *DSVIEWER
    AW,    *ARROW
    B,     *BREAK
    bb,     *blkout
    br,    *blkinput
    BD,    *PTBREAK
    BF,    *DIMYI2
    BH,    *BHATCH
    BJ,    *DIMYI0
    BL,    *BMAKE
    -BL,   *BLOCK
    BO,    *BOUNDARY
    -BO,   *-BOUNDARY
    BQ,    *DIMW
    BY,    *DIMYI1
    d,    *DDEDIT1
    C,     *COPY
    cc,     *dimlwf
    CCc,    *CHAMFER
    CD,    *SET_LYR
    CG,    *CHG_LYR
    CH,    *DDCHPROP
    -CH,   *CHANGE
    CO,    *DDCOLOR
    CR,    *CIRCLE
    CX,    *TOWIDTH
    CY,    *OFF_LYR
    Dd,     *Dmaddl
    Dc,   *DIMTEDIT
    gg,    *DDEDIT
    DDD,   *DIMMP
    DDV,   *DDVPOINT
    DF,    *DMDIV
    DG,    *CHVAL
    DGF,   *RECOV
    dh,     *dmmge
    ds,    *dmhor1
    DI,    *DIST
    DIV,   *DIVIDE
    DO,    *DONUT
    DST,   *DIMSTYLE
    DT,    *DTEXT
    DV,    *DVIEW
    dw,     *dimwdf
    DX,    *DDIM
    DXI,   *DXFIN
    DXO,   *DXFOUT
    DZ,    *DMVER
    DZB,   *MAXCHA
    E,     *ERASE
    EL,    *ELEV
    ELL,   *ELLIPSE
    EN,    *END
    EP,    *EXPLODE
    EX,    *EXTEND
    F,     *FILLET
    FD,    *ENLGVP
    FF,    *FILL
    FI,    *FILTER
    FW,    *WDREVY
    fz,      *fzh
    FZzz,    *WDREVX
    zb,     *GROUP
    GR,    *DDGRIPS
    -GR,   *GRID
    H,     *HIDE
    HE,    *HATCHEDIT
    HL,    *HIGHLIGHT
    HT,    *HATCH
    HY,    *MK3VP
    I,     *DDINSERT
    -I,    *INSERT
    IM,    *IMAGE
    -IM,   *-IMAGE
    J,     *JOIN
    L,     *LINE
    tc,      *LAYER
    -LA,   *-LAYER
    LE,    *LEADER
    LEN,   *LENGTHEN
    LI,    *LIST
    LS,    *LTSCALE
    LT,    *LINETYPE
    -LT,   *-LINETYPE
    LTS,   *LTSCALE
    M,     *MOVE
    sA,   *MATCHPROP
    ME,    *MEASURE
    MI,    *MIRROR
    MJ,    *RMAREA
    ML,    *MLINE
    a,   *DDMODIFY
    MMM,   *WDNAME
    MN,    *MENU
    MS,    *MSPACE
    MT,    *MTEXT
    -MT,   *-MTEXT
    MV,    *MVIEW
    N,     *NEW
    q,     *OFFSET
    OP,    *OPEN
    OS,    *DDOSNAP
    -OS,   *-OSNAP
    w,    *PAN
    -P,    *-PAN
    PA,    *PASTESPEC
    PB,    *PICKBOX
    PE,    *PEDIT
    PG,    *POLYGON
    PGP,   *REINIT
    PL,    *PLINE
    PN,    *PLAN
    PO,    *POINT
    POL,   *POLYGON
    PR,    *PREFERENCES
    PRE,   *PREVIEW
    da,   *PLOT
    PS,    *PSPACE
    PT,    *PLOT
    PU,    *PURGE
    o,     *QUIT
    QC,    *LATOPLI
    QX,    *PLTOLA
    QD,    *WLMOVE
    R,     *REDRAW
    ra,    *rmarea
    RAdraw,    *REDRAWALL
    RD,    *REDO
    REn,    *RENAME
    -RE,   *RENAME
    RE,   *RECTANGLE
    REG,   *REGION
    REV,   *REVOLVE
    RG,    *REGEN
    RGA,   *REGENALL
    RM,    *DDRMODES
    Rt,   *ROTATE
    RPR,   *RPREF
    RRr,  *RENDER
    S,     *STRETCH
    SC,    *SCALE
    SCR,   *SCRIPT
    SD,    *SHADE
    SE,    *DDSELECT
    -SE,   *SELECT
    SET,   *SETVAR
    SL,    *SLICE
    SN,    *SNAP
    SO,    *SOLID
    SP,    *SPLFRAME
    SPL,   *SPLINE
    SPE,   *SPLINEDIT
    SS,    *QSAVE
    SSA,   *SAVEAS
    ST,    *STYLE
    SV,    *SAVE
    SU,    *SUBTRACT
    T,     *TRIM
    tc,
    tt,    *title
    TA,    *TABLET
    TB,    *TBWORD
    TE,    *TEXT
    TH,    *THICKNESS
    TI,    *TILEMODE
    TO,    *TOOLBAR
    TOL,   *TOLERANCE
    TOR,   *TORUS
    TR,    *TRACE
    UC,    *DDUCS
    UCP,   *DDUCSP
    UN,    *DDUNITS
    -UN,   *UNITS
    UNI,   *UNION
    UI,    *UCSICON
    vv,     *u
    v,    *m
    Vvv,     *DDVPOINT
    -V,    *VPOINT
    VI,    *DDVIEW
    -VI,   *VIEW
    VS,    *VSLIDE
    p,    *WBLOCK
    WEe,    *WEDGE
    we,     *wlend
    wd,     *wdname
    X,     *EXPLODE
    XA,    *XATTACH
    XB,    *XBIND
    -XB,   *-XBIND
    xc,     *towidth
    XCccc,    *XCLIP
    XL,    *XLINE
    XR,    *XREF
    -XR,   *-XREF
    XX,    *CHDASH
    YP,    *INDEXNUM2
    YM,    *INDEXDIM
    YZ,    *INDEXNUM1
    Z,     *ZOOM
    g,    *WRINPUT
    ZBD,   *DIMZB
    ZD,    *WDBRK
    ZG,    *HWORD1
  • 论坛插件加载方法
    发表于 2003-8-4 13:29:26 | 显示全部楼层
    “我设计的快捷键认你分享”
    谢谢
    发表于 2003-8-4 13:44:00 | 显示全部楼层
    老兄,帮忙只把几个常用的列出行不,因为ACAD的命令太多,不有所有的都用得上,比如line, offset, trim, charmfer, fillet, rectangle, circle, copy, pan, move等即可。
     楼主| 发表于 2003-8-4 14:23:33 | 显示全部楼层
    你只要将上面的文件拷贝出来贴在你的ACAD.PGP中就可以。
    因每个人的习惯不同,所以可能不一定适合你。我的快捷键与你不一定相同,
    我的快捷键都在左手上,这样可以左手控键盘,右手控鼠标,效率很高的!!!
    发表于 2003-8-4 15:58:40 | 显示全部楼层
    还是自己设置比较好!
    发表于 2003-8-4 17:28:32 | 显示全部楼层
    我尽量用默认的,自己设定的才放到左手上,不过也要和名字得有点联系
    发表于 2003-8-4 19:01:33 | 显示全部楼层
    是呀,不过习惯了也无所谓
    发表于 2003-8-4 23:17:32 | 显示全部楼层
    请问如何考备到贴到CAD中?我是新手,请指教!谢谢!!
     楼主| 发表于 2003-8-5 18:42:12 | 显示全部楼层
    选取内容,按右键选“复制”,回到桌面新建一空白文档,打开后“粘贴”
    保存为ACAD。PGP,然后将该文件拷贝到R14或天正的SYS目录下,覆盖原ACAD。PGA
    就可以了!
    发表于 2003-8-6 16:23:45 | 显示全部楼层
    还是每人自己设计自己的,不过还是谢谢楼上的!
    发表于 2003-8-6 18:28:03 | 显示全部楼层
    谢谢了,虽然院里有现成的
    GMT+8, 2026-11-4 20:46 , Processed in 0.785760 second(s), 52 queries , Gzip On.
