查看: 1047|回复: 2
[LISP函数]:请高手优化该程序!
已领礼包: 2个
发表于 2003-8-8 13:50:26 | 显示全部楼层 |阅读模式
功能:任意方向矩形阵列
  1. (defun c:da (/ z obj1 obj2 a b c d pt1 pt2)
  2.   (command "undo" "be")
  3.   (setq z (getvar "cmdecho"))
  4.   (setvar "cmdecho" 0)
  5.   (prompt "\n请选择需要阵列的实体:")
  6.   (setq obj2 (ssget))
  7.   (initget 6)
  8.   (setq a (getint "\n输入行数 (---) <1> "))
  9.   (if (= a nil)
  10.     (setq a 1)
  11.   )
  12.   (initget 6)
  13.   (setq b (getint "\n输入列数 (|||) <1> "))
  14.   (if (= b nil)
  15.     (setq b 1)
  16.   )
  17.   (initget 3)
  18.   (if (/= a 1)
  19.     (setq c (getdist "\n输入行间距(---):"))
  20.   )
  21.   (initget 3)
  22.   (if (/= b 1)
  23.     (setq d (getdist "\n输入列间距(|||):"))
  24.   )
  25.   (setq
  26.     obj1 (car
  27.            (entsel "\n请选择实体以便转换座标系or以两点选定阵列方向:")
  28.          )
  29.   )
  30.   (if (= obj1 nil)
  31.     (progn
  32.       (setq pt1 (getpoint "\n请选取线段起点:"))
  33.       (setq pt2 (getpoint pt1 "\n请选取线段终点:"))
  34.       (command "line" pt1 pt2 "")
  35.       (setq obj1 (entlast))
  36.     )
  37.   )
  38.   (command "ucs" "ob" obj1)
  39.   (if  (= a 1)
  40.     (command "array" obj2 "" "r" a b d)
  41.     (if (= b 1)
  42.     (command "array" obj2 "" "r" a b c )
  43.       (command "array" obj2 "" "r" a b c d)
  44.   ))
  45. (command "erase" obj1 "")
  46.   (command "ucs" "world")
  47.   (setvar "cmdecho" z)
  48.   (command "undo" "e")
  49.   (princ)
  50. )
发表于 2003-8-8 15:15:15 | 显示全部楼层
“  (command "ucs" "world")  ”
你怎么知道原来的“world"?
发表于 2003-8-8 15:26:52 | 显示全部楼层
不好,见过INVENTOR中的阵列功能吗?那才叫方便。
GMT+8, 2026-11-2 21:40 , Processed in 0.421718 second(s), 35 queries , Gzip On.
