查看: 1343|回复: 0
[教学]:用VBA实现ACAD的lengthen命令
已领礼包: 145个
发表于 2002-6-17 02:30:00 | 显示全部楼层 |阅读模式
下面的代码实现ACAD的lengthen命令的DY选项。
  1. [FONT=courier new]
  2. Public Sub lengthenExample()
  3.     Dim oLine As AcadLine
  4.     Dim angle1 As Double
  5.     Dim dist1 As Double, dist2 As Double, distStPntPickPnt As Double, halfLenOfLine As Double
  6.     Dim pickedPnt2 As Variant, returnPnt As Variant
  7.     Dim basePnt(0 To 2) As Double
  8.     Dim lineObj As AcadLine
  9.     Dim intPoints As Variant
  10.     Dim myRay As AcadRay
  11.
  12.     ThisDrawing.Utility.GetEntity oLine, pickedPnt2, "select object to lengthen"
  13.
  14.     ' distance between the startpoint and
  15.     ' the picked point
  16.     dist1 = Abs((oLine.StartPoint(0) - pickedPnt2(0)) * (oLine.StartPoint(0) - pickedPnt2(0)))
  17.     dist2 = Abs((oLine.StartPoint(1) - pickedPnt2(1)) * (oLine.StartPoint(1) - pickedPnt2(1)))
  18.     distStPntPickPnt = Sqr(dist1 + dist2)
  19.
  20.    ' Debug.Print "Distance between stPnt and pickedPnt " & dist3 ' for testing
  21.
  22.     ' Use to determine which point should be modified
  23.     halfLenOfLine = oLine.Length / 2
  24.
  25.     ' this is 90 degrees
  26.     angle1 = oLine.Angle - 1.57
  27.
  28.     ' basePnt needs to be either the StartPoint or EndPoint
  29.     ' of the selected line
  30.      If distStPntPickPnt < halfLenOfLine Then
  31.         basePnt(0) = oLine.StartPoint(0)
  32.         basePnt(1) = oLine.StartPoint(1)
  33.         basePnt(2) = oLine.StartPoint(2)
  34.      Else
  35.         basePnt(0) = oLine.EndPoint(0)
  36.         basePnt(1) = oLine.EndPoint(1)
  37.         basePnt(2) = oLine.EndPoint(2)
  38.      End If
  39.
  40.     returnPnt = ThisDrawing.Utility.GetPoint(basePnt, "Enter a point: ")
  41.
  42.     Dim polarPnt As Variant
  43.     Dim distance As Double
  44.
  45.     ' the distance value is not important
  46.     ' this line is going to be erased, it is just
  47.     ' need for the IntersectWith function below
  48.     distance = 5
  49.     polarPnt = ThisDrawing.Utility.PolarPoint(returnPnt, angle1, distance)
  50.     ' Create a ray from the base point to the polar point
  51.      Set myRay = ThisDrawing.ModelSpace.AddRay(returnPnt, polarPnt)
  52.
  53.     ' Find the intersection points
  54.     ' intPoints = oLine.IntersectWith(lineObj, acExtendBoth)
  55.      intPoints = oLine.IntersectWith(myRay, acExtendBoth)
  56.     ' Change the StartPoint or EndPoint of the line
  57.     If distStPntPickPnt < halfLenOfLine Then
  58.         basePnt(0) = intPoints(0)
  59.         basePnt(1) = intPoints(1)
  60.         basePnt(2) = intPoints(2)
  61.         oLine.StartPoint = basePnt
  62.      Else
  63.         basePnt(0) = intPoints(0)
  64.         basePnt(1) = intPoints(1)
  65.         basePnt(2) = intPoints(2)
  66.         oLine.EndPoint = basePnt
  67.      End If
  68.
  69.      myRay.Delete
  70.
  71.      ThisDrawing.Regen acActiveViewport
  72. End Sub
  73. [/FONT]
GMT+8, 2026-11-2 05:14 , Processed in 0.524677 second(s), 32 queries , Gzip On.
