查看: 784|回复: 1
[求助]:commands may not be nested more than 4 deep
发表于 2003-8-19 10:21:48 | 显示全部楼层 |阅读模式
r14,为什么有时候我在执行某个命令时会出现以下错误信息:commands may not be nested more than 4 deep.
它的意思应该是命令嵌套不能超过4层。但对它这个嵌套我不太理解。是一个命令里调用了超过4命令?应该不会。还是命令里套命令,超过了4层,这就很难抑制了,而且为什么是在某个命令要执行几遍才出错,可以说没什么规律。这个错误一出来,程序就要退出了。
不知哪位大虾遇到过这种情况?
发表于 2003-8-19 23:59:20 | 显示全部楼层
Re: [求助]:commands may not be nested more than 4 deep
最初由 catwang_G 发布
[B]r14,为什么有时候我在执行某个命令时会出现以下错误信息:commands may not be nested more than 4 deep.
它的意思应该是命令嵌套不能超过4层。但对它这个嵌套我不太理解。是一个命令里调用了超过4命令?应该不会。... [/B]
与R14无关的,在R15中也有可能出现.
你看看下面就知道原因了.
[B]Note[/B]
The acedCommand() function supports re-entrance up to four levels deep. AutoLISP does not support re-entrance, so if acedCommand() is called from within a function that has been executed via the AutoLISP/acedDefun() interface, there is no need to worry about re-entering acedCommand(). Commands registered via acedRegCmds->addCommand(), however, do support re-entrance and there is no way to determine how many levels of re-entrance are currently in effect to avoid exceeding the limit of four levels. If you must use acedCommand() in functions registered via acedRegCmds->addCommand(), you can avoid exceeding the re-entry limit of four levels, if you:
  1. Do not use acedCommand() in functions registered as ACRX_CMD_TRANSPARENT
  2. Do not use acedCommand() to execute any other commands registered via acedRegCmds->addCommand()
  3. Do not use acedCommand() to execute anything that will allow user interaction
你多半是在命令函数中没有正确使用acedCommand / ads_command,违背上面的3条
GMT+8, 2026-11-4 07:22 , Processed in 0.975146 second(s), 34 queries , Gzip On.
