查看: 1034|回复: 5
[推荐]:一个改线宽的程序
发表于 2003-8-21 10:23:33 | 显示全部楼层 |阅读模式
(DEFUN C:MDWW( / STXT SLEN I E_NT B E_NAME NEW_1)
   (SETVAR "CMDECHO" 0)
   (PROMPT "\n             (^^)一见好心情(^^)")
   (PROMPT "\n  -----------------------------------------------")
   (IF NEW_W (SETQ NEW_W (/ NEW_W )))
   (IF (NOT NEW_W) (SETQ NEW_W 60))
   (SETQ NEW_1 (GETREAL (STRCAT "\n  输入新宽度: <" (RTOS NEW_W 2 2) "> ")))
   (IF NEW_1 (SETQ NEW_W NEW_1))
   (SETQ NEW_W (* NEW_W ))
   (PROMPT "\n 选择目标:")
   (SETQ STXT (SSGET))
   (SETQ SLEN (SSLENGTH STXT) I 0 )
   (WHILE (SSNAME STXT I)
      (SETQ E_NT (SSNAME STXT I))
      (SETQ E_NAME (ENTGET E_NT))
      (SETQ B (CDR (ASSOC 0 E_NAME)))
      (COND ((= B "POLYLINE")
              (COMMAND "PEDIT" E_NT "W" NEW_W "")
            ((= B "CIRCLE")
              (SETQ P_CEN (CDR (ASSOC 10 E_NAME)))
              (SETQ D_EN (* (CDR (ASSOC 40 E_NAME)) 2.0))
              (COMMAND "DONUT" (- D_EN NEW_W) (+ D_EN NEW_W) P_CEN "")
              (ENTDEL E_NT)
            ((OR (= B "ARC") (= B "LINE"))
              (COMMAND "PEDIT" E_NT "Y" "W" NEW_W "")
      (SETQ I (1+ I))
   (REDRAW)
(PRINC)
发表于 2003-8-21 16:39:53 | 显示全部楼层
如果是椭圆或其他曲线呢?
 楼主| 发表于 2003-8-21 16:47:31 | 显示全部楼层
椭圆及其它曲线都可以改。
发表于 2003-8-21 17:04:43 | 显示全部楼层
我怎么试了, 只能改直线, 圆弧.. 改圆还跑了位置?
发表于 2005-2-17 23:08:59 | 显示全部楼层
能重新修改一下吗
发表于 2005-2-20 14:31:21 | 显示全部楼层
还不错,但是对圆的修改略有不足:因为是新画个圆环,图层、线形、颜色等,都应该和原来的圆一致,得增加语句,提取其属性。
GMT+8, 2026-11-3 08:04 , Processed in 0.679721 second(s), 43 queries , Gzip On.
