查看: 1248|回复: 0
[ARX函数]:谈论一下块
发表于 2002-6-22 20:59:31 | 显示全部楼层 |阅读模式
块的建立:
BOOL CreatBlock(AcDbObjectIdArray objIds, char* pBlockName)
                if (objIds.isEmpty()) return FALSE;
                AcDbObject* pObj;
                AcDbObjectIdArray objList;
                AcDbObjectId objId,owner_Id = AcDbObjectId::kNull;
                for (int i=0;objIds.length()>i;i++)
                        objId=objIds.at(i);
                        if (acdbOpenObject(pObj, objId, AcDb::kForRead)!=Acad::eOk) return FALSE;
                        if (pObj->ownerId() == owner_Id)
                                objList.append(objId);
                        else if (i == 0)
                                owner_Id = pObj->ownerId();
                        pObj->close();
                AcDbBlockTable *pBlockTable;
                acdbCurDwg()->getBlockTable(pBlockTable,AcDb::kForWrite);
                AcDbBlockTableRecord *pBlockTableRec=new AcDbBlockTableRecord();
                //                if (pBlockName=="")//匿名块的建立?no setAnonymous();
                pBlockTableRec->setName(pBlockName);
                pBlockTable->add(pBlockTableRec);//BlockTableRecord加入BlockTable
                pBlockTableRec->close();
                AcDbObjectId  cur_blockId;//指向当前的bock_table_record
                pBlockTable->getAt(pBlockName, cur_blockId);
                pBlockTable->close();
                AcDbIdMapping idMap;
       acdbCurDwg() ->deepCloneObjects(objList, cur_blockId, idMap);
                return TRUE;
以上相当于在块定义对话框中选择了保留项.现在块就存在于AcDbBlockTable 中,对他的操作就简单了
插入块:
        AcDbEntity* pblock;
        acdbCurDwg()->getBlockTable(pBlockTable,AcDb::kForWrite);//得到块表的指针
    AcDbBlockTableRecord *pBlockTableRecord;
        pBlockTable->getAt(pBlockName,cur_blockId);//得到块的id
        acdbOpenObject(pblock,cur_blockId,AcDb::kForRead);
    pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,AcDb::kForWrite);
    pBlockTableRecord->appendAcDbEntity(returnId,pblock);
        pblock->close();
        return TRUE;
//以上的思路是得到块的指针pblock,通appendAcDbEntity把块加入ACDB_MODEL_SPACE,
//但是这是错误的,你会发现pblock同时存在于ACDB_MODEL_SPACE,pBlockName中,
        AcDbObjectId cur_blockId,BlockTableId;
    pBlockTable->getAt(ACDB_MODEL_SPACE, BlockTableId);
        objList.append(cur_blockId);
    acdbCurDwg() ->deepCloneObjects(objList, BlockTableId, idMap);
        return TRUE;
//以上是根据建立块的反思路进行的,首先得到块的id(cur_blockId),利用deepCloneObjects,加入ACDB_MODEL_SPACE,
//当然也会迭代块内的物体,放入objList,再利用deepCloneObjects,加入ACDB_MODEL_SPACE,(我没式过).
//以上方法也没成功,请高手指导指导.
GMT+8, 2026-11-22 10:29 , Processed in 0.479172 second(s), 11 queries , Gzip On, File On.
