查看: 695|回复: 5
[求助]:关于Auto CAD2000的快捷键设置。
发表于 2003-8-30 11:44:07 | 显示全部楼层 |阅读模式
Auto CAD2000的快捷键设置我都是用acad.pgp,但Auto CAD2004怎么没有了。
发表于 2003-8-30 12:11:04 | 显示全部楼层
工具-自定义,不是有吗
发表于 2003-8-30 14:13:47 | 显示全部楼层
To create a shortcut key for a toolbar or menu
From the Tools menu, choose Customize. Then choose Keyboard.
The Keyboard tab is automatically selected.
Under Categories, select the toolbar or menu that contains the command for which you want to modify shortcut key assignments. If you can't find the right category, click AutoCAD Commands to display all AutoCAD commands.
Under Commands, select the command for which you want to modify the shortcut key assignment.
The current shortcut key, if any, is displayed under Current Keys.
Click inside the Press New Shortcut Key box. Hold down a modifer key and press a letter key. Modifier keys can inlcude CTRL, ALT, CTRL+SHIFT, and ALT+SHIFT.
Currently Assigned To displays the current assignment (if any) for the shortcut key. If you do not want to replace the current assignment, go back to step 4 and use a different shortcut key.
Choose Assign. Then choose Close.
发表于 2003-9-1 12:35:38 | 显示全部楼层
搜索PGP
发表于 2003-9-1 13:07:50 | 显示全部楼层
2004的菜单文件及pgp文件不在原来的地方了。具体位置参考下图
发表于 2003-9-2 09:04:23 | 显示全部楼层
经过高手指导,终于会了,谢谢
GMT+8, 2026-11-3 06:08 , Processed in 0.546317 second(s), 43 queries , Gzip On.
