查看: 3779|回复: 15
[原创]:动态查询信息程序
发表于 2003-9-12 13:01:46 | 显示全部楼层 |阅读模式
;;功能:动态查询信息
;;文件:info.lsp
;;命令:info
;;作者:YAD
;;时间:2003.8
(defun C:info(/ myerr dxf toang fx add_solid add_text dis olderr oldos oldfill ss pd gr pt ent entold)
  (defun myerr(msg)
    (setq *error* olderr)
    (command "_.undo" "_b")
    (princ)
  (defun dxf(ent i)
    (if (= (type ent) 'ename)
      (setq ent (entget ent))
    (cdr (assoc i ent))
  (defun toang(ang i)
    (if (= i 1)
      (* ang (/ 180 pi))
      (* ang (/ pi 180))
  (defun fx(ang)
    (cond
      ((>= (/ pi 2) ang 0) (list pi (+ pi (/ pi 2)) 1))
      ((>= pi ang (/ pi 2)) (list 0 (+ pi (/ pi 2)) 1))
      ((>= (+ pi (/ pi 2)) ang pi) (list 0 (/ pi 2) 0))
      ((>= (* 2 pi) ang (+ pi (/ pi 2))) (list pi (/ pi 2) 0))
  (defun add_solid(p1 p2 p3 p4)
    (entmakex (list (cons 0 "SOLID") (cons 100 "AcDbEntity") (cons 62 1) (cons 100 "AcDbTrace")
                    (cons 10 p1) (cons 11 p2) (cons 12 p3) (cons 13 p4)
  (defun add_text(pt h ang txt style jus)
    (entmakex (list (cons 0 "TEXT") (cons 100 "AcDbEntity") (cons 62 2) (cons 100 "AcDbText") (if (= jus 0) (cons 10 pt) (list 10 0.0 0.0 0.0)) (cons 40 h)
                    (cons 1 txt) (cons 50 ang) (cons 7 style) (cons 72 (cond ((= jus 0) 0) ((= jus 1) 1) ((= jus 2) 1) ((= jus 3) 2))) (if (= jus 0)
                    (list 11 0.0 0.0 0.0) (cons 11 pt)) (cons 100 "AcDbText") (cons 73 (cond ((= jus 0) 0) ((= jus 1) 2) ((= jus 2) 3) ((= jus 3) 2)))
  (defun dis(ent / obj laynm name st1 st2 st3 lst h ang n)
    (setq obj (vlax-ename->vla-object ent))
    (setq laynm (strcat "图层:" (dxf ent 8)) name (dxf ent 0))
    (cond
      ((= name "3DFACE")
        (setq lst (list "【三维面】" laynm))
      ((= name "3DSOLID")
        (setq lst (list "【三维实体】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
      ((= name "ACAD_PROXY_ENTITY")
        (setq lst (list "【代理】" laynm))
      ((= name "ARC")
        (setq lst (list "【圆弧】" laynm (strcat "半径:" (rtos (vla-get-radius obj) 2 0))
                                         (strcat "圆心角:" (rtos (toang (vla-get-TotalAngle obj) 1) 2 1) "度")
                                         (strcat "起始角:" (rtos (toang (vla-get-StartAngle obj) 1) 2 1) "度")
                                         (strcat "终止角:" (rtos (toang (vla-get-EndAngle obj) 1) 2 1) "度")
                                         (strcat "总弧长:" (rtos (vla-get-ArcLength obj) 2 0))
                                         (strcat "面积:" (rtos (/ (vla-get-Area obj) 1000000) 2 2) "㎡")
      ((= name "ATTDEF")
        (setq lst (list "【属性定义】" laynm (strcat "标签:" (vla-get-TagString obj))
                                             (strcat "提示:" (vla-get-PromptString obj))
                                             (strcat "缺省值:" (vla-get-TextString obj))
                                             (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
                                             (strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")
                                             (strcat "文字样式:" (vla-get-StyleName obj))
      ((= name "ATTRIB")
        (setq lst (list "【属性】" laynm (strcat "标签:" (vla-get-TagString obj))
      ((= name "BODY")
        (setq lst (list "【体】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
      ((= name "CIRCLE")
        (setq lst (list "【圆】" laynm (strcat "半径:" (rtos (vla-get-radius obj) 2 0))
                                       (strcat "周长:" (rtos (vla-get-Circumference obj) 2 0))
      ((= name "DIMENSION")
        (setq lst (list "【尺寸标注】" laynm (strcat "标注样式:" (vla-get-StyleName obj))
                                             (strcat "文字样式:" (vla-get-TextStyle obj))
                                             (strcat "文字高度:" (rtos (vla-get-TextHeight obj) 2 1))
                                             (strcat "替带文字:" (if (= (dxf ent 1) "") "无" (dxf ent 1)))
      ((= name "ELLIPSE")
        (setq lst (list "【椭圆】" laynm (strcat "长轴半径:" (rtos (vla-get-MajorRadius obj) 2 0))
                                         (strcat "短轴半径:" (rtos (vla-get-MinorRadius obj) 2 0))
      ((= name "HATCH")
        (setq lst (list "【图案填充】" laynm (strcat "图案名称:" (vla-get-PatternName obj))
                                             (strcat "角度:" (rtos (toang (vla-get-PatternAngle obj) 1) 2 1))
                                             (strcat "比例:" (rtos (vla-get-PatternScale obj) 2 0))
                                             (strcat "关联:" (if (= (vla-get-AssociativeHatch obj) :vlax-false) "关闭" "打开"))
                                             (strcat "填充样式:" (nth (vla-get-HatchStyle obj) '("普通" "外部" "忽略")))
      ((= name "IMAGE")
        (setq lst (list "【图像】" laynm (strcat "图像大小:" (rtos (car (dxf ent 13)) 2 0) "X" (rtos (cadr (dxf ent 13)) 2 0))))
      ((= name "INSERT")
        (setq lst (list "【图块】" laynm (strcat "名称:" (dxf ent 2))
                                         (strcat "X比例:" (rtos (dxf ent 41) 2 1))
                                         (strcat "Y比例:" (rtos (dxf ent 42) 2 1))
                                         (strcat "Z比例:" (rtos (dxf ent 43) 2 1))
      ((= name "LEADER")
        (setq lst (list "【引线】" laynm (strcat "标注样式:" (vla-get-StyleName obj))
                                         (strcat "引线类型:" (dxf (list (cons 0 "折线") (cons 1 "样条曲线")) (dxf ent 72)))
      ((= name "LINE")
        (setq lst (list "【直线】" laynm (strcat "长度:" (rtos (vla-get-length obj) 2 0))
                                         (strcat "角度:" (rtos (toang (vla-get-angle obj) 1) 2 1) "度")
      ((= name "LWPOLYLINE")
        (setq lst (list "【多段线】" laynm (strcat "常量宽度:" (if (dxf ent 43) (rtos (vla-get-ConstantWidth obj) 2 0) "变宽度"))
                                            (strcat "多段线:" (if (= (vla-get-Closed obj) :vlax-false) "不闭合" "闭合"))
      ((= name "MLINE")
        (setq lst (list "【多线】" laynm (strcat "多线样式:" (vla-get-StyleName obj))
                                         (strcat "比例因子:" (rtos (dxf ent 40) 2 1))
                                         (strcat "对齐:" (nth (dxf ent 70) '("上" "零" "下")))
      ((= name "MTEXT")
        (setq lst (list "【多行文字】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
                                             (strcat "样式:" (vla-get-StyleName obj))
      ((or (= name "OLEFRAME") (= name "OLE2FRAME"))
        (setq lst (list "【OLE边框】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
      ((= name "POINT")
        (setq lst (list "【点】" laynm))
      ((= name "POLYLINE")
        (setq lst (list "【三维多段线】" laynm))
      ((= name "RAY")
        (setq lst (list "【射线】" laynm))
      ((= name "REGION")
        (setq lst (list "【面域】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
      ((= name "SHAPE")
        (setq lst (list "【形】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
                                       (strcat "宽度系数:" (rtos (vla-get-ScaleFactor obj) 2 1))
      ((= name "SOLID")
        (setq lst (list "【实体】" laynm))
      ((= name "SPLINE")
        (setq lst (list "【样条曲线】" laynm (strcat "多段线:" (if (= (vla-get-Closed obj) :vlax-false) "不闭合" "闭合"))
                                             (strcat "阶数:" (rtos (vla-get-Degree obj) 2 0))
      ((= name "TEXT")
        (setq lst (list "【文字】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
                                         (strcat "对齐:" (nth (vla-get-Alignment obj) '("Left" "Center" "Right" "Aligned" "Middle" "Fit" "TopLeft" "TopCenter" "TopRight"
        "MiddleLeft" "MiddleCenter" "MiddleRight" "BottomLeft" "BottomCenter" "BottomRight")))
      ((= name "TOLERANCE")
        (setq lst (list "【公差】" laynm (strcat "标注样式:" (vla-get-StyleName obj))
      ((= name "TRACE")
        (setq lst (list "【宽线】" laynm))
      ((= name "VERTEX")
        (setq lst (list "【顶点】" laynm (strcat "起始宽度:" (rtos (dxf ent 40) 2 0))
                                         (strcat "结束宽度:" (rtos (dxf ent 41) 2 0))
                                         (strcat "凸度:" (rtos (dxf ent 42) 2 1))
      ((= name "XLINE")
        (setq lst (list "【构造线】" laynm))
      (T
        (setq lst (list "【未知对象】" laynm))
    (setq ss (ssadd) h (/ (getvar "viewsize") 50))
    (setq ang (fx (angle (getvar "viewctr") pt)))
    (setq n (* 1.4 (1+ (/ (apply 'max (mapcar 'strlen lst)) 2.0))))
    (ssadd (add_solid pt (polar pt (car ang) (* n h)) (setq pt (polar pt (cadr ang) (+ h (* 1.8 h (length lst))))) (polar pt (car ang) (* n h))) ss)
    (setq pt (polar pt (car ang) (/ (* n h) 2)))
    (if (= (caddr ang) 0)
      (setq pt (polar pt (/ pi 2) (* 0.4 h)))
      (setq pt (polar pt (/ pi 2) (+ (* 1.4 h) (* 1.8 h (length lst)))))
    (setq n -1)
    (repeat (length lst)
      (ssadd (add_text (setq pt (polar pt (+ pi (/ pi 2)) (* 1.8 h))) h 0 (nth (setq n (1+ n)) lst) "宋体" 1) ss)
  (vl-load-com)
  (command "_.undo" "_m")
  (prompt "\n***移动鼠标掠过对象查看信息!***")
  (setq olderr *error* *error* myerr)
  (setq oldos (getvar "osmode"))
  (setq oldfill (getvar "fillmode"))
  (setvar "osmode" 0)
  (setvar "fillmode" 1)
  (setvar "cmdecho" 0)
  (if (not (tblsearch "style" "宋体"))
    (command "_.style" "宋体" "宋体" "" "" "" "" "")
  (setq ss (ssadd))
  (while (not pd)
    (while (not (progn
                  (setq gr (grread T 1))
    (if (= (car gr) 5)
      (setq pt (cadr gr)
            ent (nentselp pt)
            ent (if (and ent (= (type (last (last ent))) 'ename))
                  (last (last ent))
                  (car ent)
      (setq pd T)
    (if (and (not pd) (not (equal ent entold)) (not (ssmemb ent ss)))
      (progn
        (if entold (redraw entold 4))
        (if ss (command "_.erase" ss ""))
        (redraw ent 3)
(dis ent)
(setq entold ent)
  (setvar "osmode" oldos)
  (setvar "fillmode" oldfill)
  (princ)
(prompt "\n***动态查询信息info***   YAD建筑")
(princ)
已领礼包: 488个
发表于 2003-9-13 23:57:30 | 显示全部楼层
牛!
"BODY"是什么东东.
发表于 2003-9-15 13:12:59 | 显示全部楼层
面积好象算错了,还有能否显示文字信息
发表于 2003-10-5 01:23:02 | 显示全部楼层
这几行代码在我的系统上会出错,可能我用的是英文版的Win2000。
发表于 2003-10-17 01:22:20 | 显示全部楼层
我也不能用
发表于 2003-10-17 01:39:14 | 显示全部楼层
程序很长,应该可以写出一个更短的
发表于 2004-9-27 16:37:53 | 显示全部楼层
没多达用处!
主要是:长度,角度精度不够,面积就更不用说了!
发表于 2004-9-27 17:05:03 | 显示全部楼层
刚试了一下,没有测试全部的功能
感觉很好,只是有些查询结果对于我来说用处不大,只能根据个人需要来更改了
发表于 2006-7-7 18:32:45 | 显示全部楼层
太好了,程序功能非常强大,而且给了一个很好的方法,多谢呀
发表于 2007-8-4 02:32:31 | 显示全部楼层
还不错,我用的是全屏CAD,这个不用每次用命令打开属性来看了!
值得一学!
发表于 2007-8-4 17:46:55 | 显示全部楼层
我想更多的是一种思路和方法,结果是什么并不重要。如果你要的是结果,我想,你可能并不适合在这个版块晃悠。
顶楼主一帖!
另:
这个是需要执行命令才能激发,而且在查询结束后需要再次激发。能否实现超链接一样的效果?长期驻停!
发表于 2007-8-4 18:54:43 | 显示全部楼层
育游兄在忙什么,现在已经变成初级会员了?
发表于 2007-8-27 15:47:28 | 显示全部楼层
好东西。。。有意思。
发表于 2007-8-30 09:22:46 | 显示全部楼层
这东西不错,先收藏了
发表于 2007-9-14 13:22:45 | 显示全部楼层
不错不错,这个东东确实不错,不过如能加上对属性的更改会更完美
GMT+8, 2026-11-7 09:41 , Processed in 0.530879 second(s), 60 queries , Gzip On.
