查看: 990|回复: 0
[LISP程序]:使用AutoCAD三维命令自动成生成机件三视图,剖面图的程序实例
发表于 2003-10-14 05:16:46 | 显示全部楼层 |阅读模式
  1. (defun c:test ()
  2.   (vl-cmdf "vpoint" "0,0,1")
  3.   (vl-cmdf "ucs" "")
  4.   (setvar "osmode" 0)
  5.   (setq h0 5.9055  ;150
  6.         h1 1.9685  ;50
  7.         h2 3.937   ;100
  8.         l3 1.1811  ;30
  9.         l4 1.1811  ;30
  10.         l5 1.5748  ;40
  11.         l6 0.19685 ;5
  12.         l7 1.1811  ;30
  13.         r0 0.7874  ;20
  14.         r1 0.7874  ;20
  15.         l0 3.937   ;100
  16.   )
  17.   (setq p0 (getpoint "\nEnter the Base point: "))
  18.   (setq l2 (* 1.414 (- h2 h1))
  19.         l1 (- l0 l3))
  20.   (vl-cmdf "pline" p0
  21.            (setq p1 (polar p0 0 l0))
  22.            (setq p2 (polar p1 (/ pi 2) h1))
  23.            (setq p3 (polar p2 pi l1))
  24.            (setq p4 (polar p3 (/ pi 4) l2))
  25.            (setq p5 (polar p4 pi l3))
  26.            (setq p6 (polar p5 (* pi 1.25) l2)) "c")
  27.   (vl-cmdf "extrude" "l" "" h0 "")
  28.   (setq e0 (entlast))
  29.   (vl-cmdf "vpoint" "1,1,1")
  30.   (vl-cmdf "ucsicon" "OR")
  31.   (vl-cmdf "ucs" "o" p0 "ucs" "y" "90")
  32.   (vl-cmdf "ucs" "o" (list (- h0) 0 0))
  33.   (vl-cmdf "box" "" (list l5 l4) l0)
  34.   (setq e1 (entlast))
  35.   (vl-cmdf "box" (list h0 0)(list (- h0 l5) l4) l0)
  36.   (setq e2 (entlast))
  37.   (vl-cmdf "cylinder" (list (/ h0 2.0)(/ h1 2.0) 0) r0 l0)
  38.   (setq e3 (entlast))
  39.   (vl-cmdf "subtract" e0 "" e1 e2 e3 "")
  40.   (setq e0 (entlast))
  41.   (vl-cmdf "slice" e0 "" (list (+ l5 l6) 0 0)(list l5 l6 0)(list l5 l6 h2)
  42.                          (list (/ h0 2.0)(/ h1 2.0)))
  43.   (vl-cmdf "slice" e0 "" (list (- h0 l5 l6) 0 0)(list (- h0 l5) l6 0)
  44.                          (list (- h0 l5) l6 h2)(list (/ h0 2.0)(/ h1 2.0)))
  45.   (vl-cmdf "section" e0 "" "xy" (list 0 0 (/ l0 2.0)))
  46.   (setq e (entlast))
  47.   (vl-cmdf "ucs" "")
  48.   (vl-cmdf "ucs" "o" p4 "ucs" "z" "135" "ucs" "y" "-90")
  49.   (vl-cmdf "pline" (setq p1 (list (- (/ h0 2.0) r1) 0))
  50.                    (setq p2 (polar p1 (/ pi 2) l7))
  51.            "a" "d" (polar p2 (/ pi 2) l0)
  52.                    (setq p3 (polar p2 0 (* 2 r1)))
  53.                "l" (polar p3 (- (/ pi 2)) l7)
  54.                "c")
  55.   (vl-cmdf "extrude" "l" "" (- l3) "")
  56.   (setq e4 (entlast))
  57.   (vl-cmdf "subtract" e0 "" e4 "")
  58.   (vl-cmdf "ucs" "")
  59.   (vl-cmdf "vpoint" "0,-1,0")
  60.   (vl-cmdf "vports" "s" "main")
  61.   (vl-cmdf "vpoint" "0,0,-1")
  62.   (vl-cmdf "vports" "s" "bottom")
  63.   (vl-cmdf "vpoint" "1,0,0")
  64.   (vl-cmdf "vports" "s" "right")
  65.   (vl-cmdf "vpoint" "-1,-1,1")
  66.   (vl-cmdf "vports" "s" "swiv")
  67.   (vl-cmdf "vpoint" "1,0,0")
  68.   (vl-cmdf "ucs" "v")
  69.   (vl-cmdf "move" e "" (setq p0 (list 0 0))(polar p0 0 15))
  70.   (vl-cmdf "zoom" "all")
  71.   (vl-cmdf "hatch" "ansi31" "2" "0" e "")
  72.   (vl-cmdf "pan" p0 (polar p0 0 20))
  73.   (vl-cmdf "zoom" "c" (polar p0 0 15)(* 2 h0))
  74.   (vl-cmdf "vports" "s" "sect")
  75.   (if (= (getvar "tilemode") 1)(setvar "tilemode" 0))
  76.   (vl-cmdf "pspace")
  77.   (vl-cmdf "limits" "0,0" "12,9")
  78.   (vl-cmdf "zoom" "all")
  79.   (vl-cmdf "mview" "R" "main" "0,10.0" "2.5,6.0")
  80.   (vl-cmdf "mview" "R" "bottom" "2.5,10.0" "5.0,6.0")
  81.   (vl-cmdf "mview" "R" "right" "5.0,10.0" "7.5,6.0")
  82.   (vl-cmdf "mview" "R" "sect" "0,2" "3.75,6.0")
  83.   (vl-cmdf "mview" "R" "swiv" "3.75,2" "7.5,6.0")
  84.   (princ)
  85. )
GMT+8, 2026-11-4 18:06 , Processed in 0.572120 second(s), 32 queries , Gzip On.
