查看: 3790|回复: 13
[LISP程序]:我的LSP文字排版程式,很好用的。
发表于 2002-8-14 13:51:55 | 显示全部楼层 |阅读模式
  1. ; 创作说明 文字排版程式。对DTXT有用!
  2. ;此程序由seaon编写!
  3. ;seaon@eyou.com
  4. (defun c:Ts (/ pp2 startpts ss l ll fal th pt1 pty);start1
  5.   (if (not (setq SS (ssget "i")))
  6.     (progn
  7.       (prompt "选择文字实体。\n")
  8.       (setq SS (ssget))
  9.     )
  10.   )
  11. (if (ssname ss 0)
  12. (if (/= (cdr (assoc 0 (entget (ssname ss 0)))) "TEXT")
  13. (progn
  14. (alert " 所选实体中并非都是文字.ho-o! ")
  15. (quit)
  16. )))
  17. (COMMAND "UNDO" "MARK")
  18. (command "ucs" "w" )
  19. (setvar "texteval" 1)(setq oldos (getvar "osmode"))
  20. (setvar "osmode" 0)
  21. (setq startpts (getpoint "输入起点位置:"))
  22. (print)
  23. (if (= nil startpts);start2
  24. (setq startpts (cdr (assoc 10 (entget (ssname ss 0)))))
  25. );end2
  26. (setq th (cdr (assoc 40 (entget (ssname ss 0)) )))
  27. (setq startpts (list (car startpts) (- (car (cdr startpts)) (/ th 2))))
  28. (if (= nil r )(setq r 0.67) (setq r (/ r (cdr (assoc 40 (entget (ssname ss 0)))) )))
  29. (setq rr (getreal (strcat "输入行间距与字高的比例<" (rtos r 2 2) ">:")))
  30. (if (/= nil rr)(setq r rr))
  31. (if (or (= nil r) (= r 0.67))
  32. (setq r (* 0.67 (cdr (assoc 40 (entget (ssname ss 0)))) ))
  33. (setq r (* r (cdr (assoc 40 (entget (ssname ss 0))))))
  34. )
  35. (setq l (sslength ss))
  36. (setq ii 0
  37.       ooo t
  38.       highy nil highent nil)
  39. (setq endss (ssadd))
  40. (repeat l
  41. (repeat l
  42. (if (ssname ss ii)
  43.     (setq en (ssname ss ii))(setq ooo Nil)
  44. )
  45. (if (ssname ss ii)
  46. (if (/= (cdr (assoc 0 (entget (ssname ss ii)))) "TEXT")
  47. (progn
  48. (alert " 所选实体中并非都是文字.ho-o! ")
  49. (quit)
  50. )))
  51. (if (and ooo (= (cdr (assoc 0 (entget (ssname ss ii)))) "TEXT"))
  52. (progn
  53. (setq pt1 (car (cdr(cdr (assoc 10 (entget en))))))
  54.    (if (> pt1 highy);start5
  55.    (progn;start6
  56.    (setq highy pt1)
  57.    (setq highent en)
  58.    ));end65
  59. ))
  60. (setq ii (1+ ii)
  61.       ooo t
  62.       )
  63. );end repeat1
  64. (setq ii 0 ooo t en nil)
  65. (ssdel highent ss)
  66. (ssadd highent endss)
  67. (setq highy nil highent nil)
  68. );end repeat2
  69. (setq i 0)
  70. (setq ll (sslength endss))
  71. (repeat ll
  72. (setq enn (ssname endss i))
  73. (setq pp2 (cdr (assoc 10 (entget enn))))
  74. (command "move" enn "" pp2 startpts)
  75. (setq startpts (list (car startpts) (- (car (cdr startpts)) th r)))
  76. (setq i (1+ i))
  77. );end3 1
  78. (command "ucs" "prev""")
  79. (setvar "osmode" oldos)
  80. )
发表于 2002-8-31 08:58:00 | 显示全部楼层
請問這是什么功能?
发表于 2002-9-19 17:15:22 | 显示全部楼层
我要好好参考一下
发表于 2002-10-12 21:34:56 | 显示全部楼层
我也用用看
发表于 2002-10-16 11:38:49 | 显示全部楼层
请问sz961此lisp程序的功能是什么,试用了一下只有第一步能用,以后cad就不认命令ts了,原因何在,请指教!谢谢!
 楼主| 发表于 2002-12-5 18:18:33 | 显示全部楼层
文字排版程式。对DTXT有用!文字对齐及行间距设定.对作表格很有用(如图纸目录)
lucy 你要把它保存成LISP文件.以后每次就可以调用了.
发表于 2003-5-17 19:43:48 | 显示全部楼层
试用一下,不知排版功能有多强?
发表于 2005-2-17 23:45:05 | 显示全部楼层
大家用过了,觉得如何
发表于 2005-8-10 23:09:10 | 显示全部楼层
该命令ssget '((0 . "text"))可以只选择单行文本,其他图元均不选,版主可以采用并改进程序.
发表于 2005-8-12 19:18:28 | 显示全部楼层
我也要来呀
发表于 2017-4-26 00:22:31 | 显示全部楼层
谢谢楼主,支持下
发表于 2018-4-27 15:57:06 来自手机 | 显示全部楼层
你好,能帮我这一个小程序吗
发表于 2018-5-1 20:06:17 | 显示全部楼层
好东西
发表于 2025-12-27 10:52:41 | 显示全部楼层
谢谢楼主,支持下
GMT+8, 2026-11-22 08:55 , Processed in 0.445072 second(s), 36 queries , Gzip On, File On.
