查看: 1133|回复: 2
[原创]:Autodesk Land Desktop v2004 Keymaker
发表于 2003-12-2 15:50:24 | 显示全部楼层 |阅读模式
When asked select 'Authorize the product', then 'Enter authorization code' and copy your request code to our keymaker to get your authorization code.
Note that our keymaker can be used only for standalone installations, so if you already used PDX crack then remove from registry the value that their .reg adds,  otherwise you will not have option to authorize the
software.
发表于 2003-12-6 07:09:27 | 显示全部楼层
下不了呀,再看看
发表于 2004-1-2 23:10:06 | 显示全部楼层
请问有autodesk land desktop3 的注册机 ?
GMT+8, 2026-11-22 11:24 , Processed in 0.196126 second(s), 14 queries , Gzip On, File On.
