查看: 820|回复: 0
[原创]:Autodesk Mechanical Desktop 2004 Keymaker
发表于 2003-12-2 16:30:16 | 显示全部楼层 |阅读模式
When asked select 'Authorize the product', then 'Enter  authorization code' and copy your request code to our  keymaker to get your authorization code.
Note that our keymaker can be used only for standalone  installations, so if you already used PDX crack then  remove from registry the value that their .reg adds,   otherwise you will not have option to authorize the   software.
GMT+8, 2026-11-3 00:44 , Processed in 0.417313 second(s), 33 queries , Gzip On.
