查看: 892|回复: 8
[教学]:cad建摸的一些心得
发表于 2003-12-30 15:27:23 | 显示全部楼层 |阅读模式
闲着没事,给大家写写教程
关于cad的模型,我已经习惯了14,就以14为准,有什么错误和遗漏大家不妨说说
第一
cad的使用,要养成一手键盘,一手鼠标的习惯,要不然,速度永远也别想提高
3A, *3Darray
3F, *3Dface
3P, *3Dpoly
A, *Arc
Aa, *Matchprop
Aad, *Aseadmin
Aex, *Aseexport
Al, *Align
Ali, *Aselinks
Ap, *Appload
Ar, *Array
Aro, *Aserows
Ase, *Aseselect
Asq, *Asesqled
At, *Ddattdef
-At, *Attdef
Ate, *Ddatte
-Ate, *Attedit
Av, *Dsviewer
B, *Bmake
-B, *Block
Bh, *Bhatch
Bo, *Boundary
-Bo, *-Boundary
Br, *Break
C, *Circle
Cc, *Copy
Cg, *Chprop
-Ch, *Change
Cha, *Chamfer
Col, *Ddcolor
D, *Dist
Dal, *Dimaligned
Dan, *Dimangular
Dba, *Dimbaseline
Dce, *Dimcenter
Dco, *Dimcontinue
Dd, *Ddim
Ddi, *Dimdiameter
Ded, *Dimedit
Dimali, *Dimaligned
Dimang, *Dimangular
Dimbase, *Dimbaseline
Dimcont, *Dimcontinue
Dimdia, *Dimdiameter
Dimed, *Dimedit
Dimlin, *Dimlinear
Dimord, *Dimordinate
Dimover, *Dimoverride
Dimrad, *Dimradius
Dimsty, *Dimstyle
Dimted, *Dimtedit
Div, *Divide
Dli, *Dimlinear
Do, *Donut
Dor, *Dimordinate
Dov, *Dimoverride
Dr, *Draworder
Dra, *Dimradius
Dst, *Dimstyle
Dt, *Dtext
Dv, *Dview
E, *Erase
Ed, *Ddedit
El, *Ellipse
Ex, *Extend
Exit, *Quit
Exp, *Export
Ext, *Extrude
F, *Offset
Ff, *Fillet
Fi, *Filter
G, *Group
-G, *Group
Gr, *Ddgrips
H, *Bhatch
-H, *Hatch
He, *Hatchedit
Hi, *Hide
I, *Ddinsert
-I, *Insert
Iad, *Imageadjust
Iat, *Imageattach
Icl, *Imageclip
Im, *Image
-Im, *-Image
Imp, *Import
In, *Intersect
Inf, *Interfere
Io, *Insertobj
La, *Layer
-La, *-Layer
Le, *Leader
Lead, *Leader
Len, *Lengthen
Li, *List
Ls, *List
Lt, *Linetype
-Lt, *-Linetype
Lts, *Ltscale
Me, *Measure
Ml, *Mline
Mo, *Ddmodify
Ms, *Mspace
Mt, *Mtext
Mv, *Mview
Os, *Ddosnap
-Os, *-Osnap
-P, *-Pan
Pa, *Pastespec
Pe, *Pedit
Po, *Point
Pol, *Polygon
Pr, *Preferences
Pre, *Preview
Print, *Plot
Ps, *Pspace
Pu, *Purge
Q, *Plan
R, *Redraw
Ra, *Redrawall
Re, *Regen
Rea, *Regenall
Rec, *Rectangle
Reg, *Region
Ren, *Ddrename
-Ren, *Rename
Rev, *Revolve
Rm, *Ddrmodes
Rpr, *Rpref
Rr, *Mirror
Rt, *Rotate
S, *Pan
Sa, *Shade
Sc, *Scale
Scr, *Script
Se, *Ddselect
Sec, *Section
Set, *Setvar
Sl, *Slice
Sn, *Snap
So, *Solid
Sp, *Spell
Spe, *Splinedit
Spl, *Spline
Ss, *Stretch
St, *Style
Su, *Subtract
-T, *-Mtext
Ta, *Tablet
Th, *Thickness
Ti, *Tilemode
Tm, *Tilemode
To, *Toolbar
Tol, *Tolerance
Tor, *Torus
Tr, *Trim
Ttt, *Mtext
Uc, *Dducs
Ucp, *Dducsp
Un, *Ddunits
-Un, *Units
Uni, *Union
V, *Move
-V, *View
Ve, *Ddview
Vp, *Ddvpoint
Vv, *Vpoint
W, *Wblock
We, *Wedge
Ww, *Ucs
X, *Line
Xa, *Xattach
Xb, *Xbind
-Xb, *-Xbind
Xc, *Xclip
Xl, *Xline
Xr, *Xref
-Xr, *-Xref
Xx, *Pline
Xxx, *Explode
Z, *Zoom
这是我常用的一些设定,希望新手能按照这个来做,习惯了之后,速度会有大幅度的提高
这是最正常的要求,原因很简单,是因为我做图的时候,所有的命令几乎都是用左手完成
的,所以新手们最好按照我的说法来做
文件位置acad14\support\acad.pgp
我先说明一下cad模型的原理,他实际上大多数的时候是在用一个具有宽度的pline给厚度
这样的话,物体是一个标准的六面体
然后说几个最重要的快捷建
f2你的历史,f3,捕捉开/关
f8正交打开/关闭
说明一下,例如pline,line,rotate,trim ,mirror,extend,array等命令就不做讲解了,就是
说,所有的平面命令我除了特殊情况,我不会作其他的讲解
***cad的模型,最重要的,我总结的一句话,在什么坐标系上,用什么视点看,用什么命令来做。***
第一个命令
pline的画法,特别说明,pl只要你给出一个方向,那么,就可以直接给出长度的数值
,不需要给相对坐标
视图命令
vpoint-vv,这个命令的意思是,从你输入的3点的坐标的那个点,向原点引射线,那么,
射线的方向就是视线方向,你得到的,是一个轴侧图
也就是说,这个是解决你怎么看物体的问题
第二个命令
ucs
这个命令有点不好理解,它的意思是用户坐标系。其实,这个命令是和change这个命令
联系的,因为作模型的时候,物体的厚度是沿着当前坐标系下的z轴方向。也就是说,用
ucs 只是为了给一个z轴的方向。就是说,你看到东西的时候,你的工作平面不一定在你看到
这个东西的时候的视点上。这一点要特别注意。
change
这个命令是cad模型里面最核心的命令
也就是说,它能改变物体的高度,也就是厚度
和他类似的一个命令是chprop,但是不同的是,你用change只能改变当前ucs下的物体的厚度,
但是chprop可以改变任何一个坐标系下的物体(物体可能是在不同的坐标系下建立起来的),
并且,改变的厚度的方向是创建该物体时候的坐标系的z轴方向
看一个范例。。。。。。。。
发表于 2003-12-30 16:48:12 | 显示全部楼层
我记得默认的A是指ARRAY啊,阵列,不是吗?
发表于 2003-12-30 21:57:31 | 显示全部楼层
有空我会多来这逛逛 学学一些课堂上学不到的东西。。。。。
发表于 2003-12-30 22:09:13 | 显示全部楼层
我习惯这样改,因其常用优先,双击快捷。
CC,  *Circle
C,    *Copy
EE,   *Extend
T,    *Trim
MM, *Mirror
发表于 2003-12-30 23:20:51 | 显示全部楼层
喜欢用体建模,心得不太相同.
发表于 2003-12-31 16:27:42 | 显示全部楼层
怎么修改快捷键?
发表于 2003-12-31 22:32:55 | 显示全部楼层
我想问家乐大哥一个很初级的问题,一个三维物体怎样修改它的长、宽、高?CHPROP是不行的。别见笑啊,刚学CAD建模。
发表于 2003-12-31 22:42:39 | 显示全部楼层
最初由 VGASY 发布
[B]怎么修改快捷键? [/B]
把 pgp文件的内容改掉,1楼楼主已经说得很清楚了.
发表于 2004-1-1 08:10:32 | 显示全部楼层
CAD做模
我做过
3D建模我也做过
不过如果有了平面和立面 直接导入3D中
那样就直接可以生成的呀
GMT+8, 2026-11-5 21:29 , Processed in 0.439707 second(s), 46 queries , Gzip On.
