查看: 735|回复: 0
[日积月累]:有用的lisp小工具(4)--带均分功能的array命令
发表于 2004-1-14 22:56:44 | 显示全部楼层 |阅读模式
这个array命令带有上期offset命令所讲的均分功能。用法请参看。
  1. (defun c:lary( / dis kw ls nc nr disc disr ss fnc fnr)
  2.   (setvar "cmdecho" 0)
  3.   (if (setq ss (ssget)) (progn
  4.     (initget "R P")
  5.     (if (setq ls (getkword "\n 输入阵列类型 [矩形(R)/环形(P)] <R>: "))
  6.         (setq kw ls)
  7.         (setq kw "R")
  8.     )
  9.     (cond
  10.       ((= kw "R")
  11.         (if (setq ls (getint "\n行数(---)<1>: ")) (setq nr (abs ls) fnr (/ ls nr)) (setq nr 1 fnr 1))
  12.         (if (setq ls (getint "\n列数(|||)<1>: ")) (setq nc (abs ls) fnc (/ ls nc)) (setq nc 1 fnc 1))
  13.         (initget "Divide")
  14.         (if (/= 1 nr) (progn
  15.           (setq disr (getreal "\n行间距(---/计算均分D): "))
  16.           (if (= disr "Divide")
  17.             (setq dis (getdist "\n总的距离: ")
  18.                   disr (/ dis (1- nr) fnr)
  19.             )
  20.             (setq disr (* fnr disr))
  21.           ) ;if
  22.         )) ;if
  23.         (initget "Divide")
  24.         (if (/= 1 nc) (progn
  25.           (setq disc (getreal "\n列间距(|||/计算均分D): "))
  26.           (if (= disc "Divide")
  27.             (setq dis (getdist "\n总的距离: ")
  28.                   disc (/ dis (1- nc) fnc)
  29.             )
  30.             (setq disc (* fnc disc))
  31.           ) ;if
  32.         )) ;if
  33.         (if (and (= 1 nc) (= 1 nr))
  34.           (princ "\n单元素阵列,没有可执行的操作. ")
  35.           (progn
  36.             (command "array" ss "" "r" nr nc)
  37.             (if disr (command disr))
  38.             (if disc (command disc))
  39.           ) ;progn
  40.         ) ;if
  41.       ) ;
  42.       ((= kw "P")
  43.        (princ "\n弧形阵列请使用cad命令.")
  44.       ) ;
  45.       (T)
  46.     ) ;cond
  47.   )) ;if
  48.   (princ)
  49. )
GMT+8, 2026-11-6 23:59 , Processed in 0.372249 second(s), 31 queries , Gzip On.
