查看: 609|回复: 0
[LISP函数]:矩形截面双向偏心受压计算程序
发表于 2004-1-18 10:30:54 | 显示全部楼层 |阅读模式
;+双向偏心受压构件偏心矩增大系数计算+
;根据给定条件按单向偏压求解对称配筋
(defun as1(b h l0 M N yei mode fcm fy / pxin e as1 as2 ksi C h0 x C a as txt)
(setq  h0 (- h 40)
           ksib 0.544
        ksi (/ N fcm b h0)
        pxin "\n大偏心 x/h0="
        e (+ yei (* 0.5 h) -40)
        x (* ksi h0)
        x (if (< x 80) 80 x)
        as1 (+ yei (* -0.5 h) (* 0.5 x))
        as1 (* N as1)
        as2 (* fy (- h0 40))
        as  (/ as1 as2)
) ;setq end
(if (= mode 0)
     (setq l_fac1 0.45  l_fac2 0.8) ;旧规范
     (setq l_fac1 0.43  l_fac2 (beta1 c)) ;新规范
) ;if end
(if (> ksi ksib) ;小偏心
     (setq as1 (- (* N e) (* l_fac1 fcm b h0 h0))
           as2 (* (- l_fac2 ksib) (- h0 40))
           as1 (/ as1 as2)
           as2 (* fcm b h0)
           as1 (+ as1 as2)
           as2 (- N (* ksib fcm b h0))
           ksi (/ as2 as1)
           ksi (+ ksi ksib)
           pxin "\n小偏心 x/h0="
                  C (- ksi (* 0.5 ksi ksi))
           a (* fy (- h0 40))
           Asc (* fcm b h0 h0)
           as1 (- (* N e) (* Asc C))
           as (/ as1 a)
     ) ;setq end
  ) ;if end
  (setq txt (strcat pxin (rtos ksi 2 4) "  Ase= " (rtos as 2 1) "(mm2)" ))
  (princ txt)
  (setq as as)
) ;defun end
(defun yta(b h l0 M N fc / yta1 yta2 dyta yta txt-yta1 txt-yta2 txt-dyta txt-yta h0)
(setq  e0 (/ M N )
        h0 (- h 40)
              ea (if (<= e0 (* 0.3 h0)) (* 0.12 (- (* 0.3 h0) e0)) 0)
        ei (+ e0 ea)
        eih0 (/ ei h0)
        yta1 (* 0.5 fc B H (/ 1.0 N))
          yta1 (if (> yta1 1.0) 1 yta1)
        yta2 (/ l0 h 100)
        yta2 (- 1.15 yta2)
        yta2 (if (< (/ l0 h) 15) 1.0 yta2)
        dyta (* (/ l0 h) (/ l0 h))
        dyta (/ dyta 1400 eih0)
        yta (+ 1 (* dyta yta1 yta2))
        yta (if (<= (/ l0 h) 8) 1.0 yta)
        txt-yta1 (strcat "\nyta1=" (rtos yta1 2 4))
        txt-yta2 (strcat "\nyta2=" (rtos yta2 2 4))
        txt-dyta (strcat "\ndyta=" (rtos dyta 2 4))
        txt-yta  (strcat "\nyta=1+dyta*yta1*yta2=" (rtos yta 2 4))
) ;setq end
(princ txt-yta1)
(princ txt-yta2)
(princ txt-dyta)
(princ txt-yta)
(setq yta (* ei yta))
) ;defun end
(defun c:nm2-as()
(textscr)
(inivar) ;初始化系统变量
(load "tab.lsp")
(load "concrete.lsp")
(setq scale 1)
(princ "\n          ^        X        ")
(princ "\n          |          ")
(princ "\n     +----|----+        ")
(princ "\n     |    |    |        ")
(princ "\n     |    |    | Asy ")
(princ "\n   --+----+----+----> Y ")
(princ "\n     |    |    |        ")
(princ "\n     |    |    |        ")
(princ "\n             Asx        ")
(princ "\n")
(princ "\n本程序用于求解对称配筋矩形截面双向偏心受压构件配筋")
(princ "\n钢筋内定为II级钢筋,如按I级钢筋,应乘以系数310/210")
(princ "\nb,h--截面高,宽; l0--构件计算长度; ")
(princ "\nN--设计轴力,e0x e0y--x,y向初始偏心;")
(princ "\nc--砼等级, fy--钢筋受拉强度")
(PRINC "\nb(mm),h(mm),l0(m),N(KN),e0x(mm),e0y(mm),c,fy\n:")
(setq l-l (readlh)
       mode (getint "\n按旧规范GB10-89(0)/按新规范GB50010-2002(1)计算:<1>")
       mode (if mode mode 1)
       b (nth 0 l-l)
       h (nth 1 l-l)
       b0 (- b 40)
       h0 (- h 40)
       l0 (* (nth 2 l-l) 1000)
       N (* (nth 3 l-l) 1000)
       e0x (nth 4 l-l)
       e0y (nth 5 l-l)
       M0x (* N e0x)
       M0y (* N e0y)
       c (nth 6 l-l)
       fcm (if (= mode 0) (concrete "fcm" c mode)  ;旧规范
                          (* (alfa1 c) (concrete "fc" c mode))  ;新规范
           ) ;if end
       fc (concrete "fc" c mode)
       fy (nth 7 l-l)
       ksib 0.544
       yeix (yta b h l0 M0x N fc)
       yeiy (yta h b l0 M0y N fc)
       yeixh (/ yeix h0)
       yeiyb (/ yeiy b0)
       addy (+ yeixh yeiyb)
       psix (/ yeixh addy)
       psiy (/ yeiyb addy)
       Nex (/ N psix)
       Ney (/ N psiy)
       txt1 (strcat "\npsix=" (rtos psix 2 3) " Nex=" (rtos (/ Nex 1000) 2 2) " KN")
       txt2 (strcat "\npsiy=" (rtos psiy 2 3) " Ney=" (rtos (/ Ney 1000) 2 2) " KN")
) ;setq end
(princ txt1)
(princ txt2)
(princ "\nx方向计算:")
(Setq Asex0 (* 0.2 b h0 fcm (/ 1.0 fy))
        txt1 (strcat "\nAsex0=0.2*b*h0*fcm/fy= " (rtos Asex0 2 2) " mm2")
        temp t)
(princ txt1)
(while temp ;x方向迭代求Asex
     (setq
        Nu0x (+ (* fc b h) (* 2 fy Asex0))
        d_Nu0x (/ 0.5 Nu0x)
        d_Nex (/ 1.0 Nex)
        Nux (/ 1.0 (+ d_Nex d_Nu0x))
        Asex (as1 b h l0 M0x Nux yeix mode fcm fy)
        delta (abs (- Asex Asex0))
        temp (if (< delta (* Asex 0.001)) nil t)
        Asex0 Asex
      ) ;setq end
) ;while end
(setq txt1 (strcat "\nNux= " (rtos (/ Nux 1000) 2 2) " KN Asex=" (rtos Asex 2 2) " mm2"))
(princ txt1)
(princ "\ny方向计算:")
(Setq Asey0 (* 0.2 h b0 fcm (/ 1.0 fy))
        txt1 (strcat "\nAsey0=0.2*h*b0*fcm/fy= " (rtos Asey0 2 2) " mm2")
        temp t)
(princ txt1)
(while temp  ;y方向迭代求Asex
     (setq
        Nu0y (+ (* fc b h) (* 2 fy Asey0))
        d_Nu0y (/ 0.5 Nu0y)
        d_Ney (/ 1.0 Ney)
        Nuy (/ 1.0 (+ d_Ney d_Nu0y))
        Asey (as1 h b l0 M0y Nuy yeiy mode fcm fy)
        delta (abs (- Asey Asey0))
        temp (if (< delta (* 0.001 Asey)) nil t)
        Asey0 Asey
      ) ;setq end
) ;while end
(setq txt1 (strcat "\nNuy= " (rtos (/ Nuy 1000) 2 2) " KN Asey=" (rtos Asey 2 2) " mm2"))
(princ txt1)
(if (> yeixh 0.5)
        (Setq ksix (- 0.36 (/ 0.13 yeixh)))
        (Setq ksix (- 0.50 (* 0.80 yeixh)))
) ;if end
(if (> yeiyb 0.5)
        (Setq ksiy (- 0.36 (/ 0.13 yeiyb)))
        (Setq ksiy (- 0.50 (* 0.80 yeiyb)))
) ;if end
(Setq kk1 (- 1.0 (* 4 ksix ksiy))
       d_rei (getreal "\n输入角筋直径<20>:")
       d_rei (if d_rei d_rei 20)
       Asc (* 0.25 pi d_rei d_rei)
       kk2 (- Asex (* 2 ksix Asey)
                   (* 2 Asc (- 1.0 (* 2 ksix))))
       kk3 (- Asey (* 2 ksiy Asex)
                   (* 2 Asc (- 1.0 (* 2 ksiy))))
       Aswx (/ kk2 kk1)
       Aswy (/ kk3 kk1)
       txt1 (strcat "\nksix=" (rtos ksix 2 3) " 垂直x方向两对边腹部筋 Aswx=" (rtos Aswx 2 2) " mm2")
       txt2 (strcat "\nksiy=" (rtos ksiy 2 3) " 垂直y方向两对边腹部筋 Aswy=" (rtos Aswy 2 2) " mm2")
       txt3 (strcat "\n角部筋 Asc=" (rtos Asc 2 2) " mm2")
) ;setq end
(princ txt3)
(princ txt1)
(princ txt2)
(resvar) ;还原系统变量
(princ)
) ;defun end
GMT+8, 2026-11-3 01:52 , Processed in 0.422966 second(s), 32 queries , Gzip On.
