查看: 1482|回复: 2
[LISP程序]:圆形截面偏心受压计算程序
发表于 2004-1-18 10:36:16 | 显示全部楼层 |阅读模式
;+圆形截面偏心受压构件偏心矩增大系数计算+
(defun fun(N a / at pia piat X1 X2 X3 X4 Y1 Y2 Area f)
  (setq at (att a)
        pia (* pi a)
        piat (* pi at)
        X1 (sin (* 2 pia))
        X1 (/ X1 2 pia)
        X0 (- 1 X1)
        Area (* pi R R)
        X1 (* a fcm Area X0)
        txt (strcat "a*fcm*Area*X0=" (rtos a 2 3) "X" (rtos fcm 2 1) "X" (rtos Area 2 2) "X"
                    (rtos X0 2 3) " =" (rtos X1 2 3))
  ) ;setq end
;  (princ txt)
  (setq
        Y1 (- N X1)
        Y1 (/ Y1 (- a at))
        X2 (sin pia)
        X22 X2
        X4 (* X2 X2 X2)
        X2 (* (/ 2.0 3.0 pi) fcm Area R X4)
   ) ;setq end
;  (princ "\n2/3fcm*Area*...=")
;  (princ X2)
  (setq
        X2 (- (* N yei) X2)
        X3 (sin piat)
        X3 (+ X22 X3)
        Y3 (* Rs X3 (/ 1.0 pi))
        Y2 (/ X2 Y3)
) ;setq end
(setq         f (- Y1 Y2))
) ;defun end
(defun att(a)
(setq at (- 1.25 (* 2 a))
       at (if (> a 0.625) 0 at)
) ;setq end
(setq at at)
) ;defun end
(defun yta(b h l0 M N c mode / yta1 yta2 dyta yta txt-yta1 txt-yta2 txt-dyta txt-yta Area)
(if (null (type concrete)) (load "concrete.lsp"))
(setq         e0 (/ M N )
              ea (if (<= e0 (* 0.3 h0)) (* 0.12 (- (* 0.3 h0) e0)) 0)
        ei (+ e0 ea)
        eih0 (/ ei h0)
        fc (concrete "fc" c mode)
        Area (* 0.25 pi h h)
        yta1 (* 0.5 fc Area (/ 1.0 N))
          yta1 (if (> yta1 1.0) 1 yta1)
        yta2 (/ l0 h 100)
        yta2 (- 1.15 yta2)
        yta2 (if (< (/ l0 h) 15) 1.0 yta2)
        dyta (* (/ l0 h) (/ l0 h))
        dyta (/ dyta 1400 eih0)
        yta (+ 1 (* dyta yta1 yta2))
        yta (if (<= (/ l0 h) 8) 1.0 yta)
        txt-yta1 (strcat "\nyta1=" (rtos yta1 2 4))
        txt-yta2 (strcat "\nyta2=" (rtos yta2 2 4))
        txt-dyta (strcat "\ndyta=" (rtos dyta 2 4))
        txt-yta  (strcat "\nyta=1+dyta*yta1*yta2=" (rtos yta 2 4))
) ;setq end
(princ txt-yta1)
(princ txt-yta2)
(princ txt-dyta)
(princ txt-yta)
(setq yta (* ei yta))
) defun end
;根据求得的a计算配筋As
(defun fun-as(N a / at pia piat X1 Y1 Area as)
  (setq at (att a)
        pia (* pi a)
        piat (* pi at)
        X1 (sin (* 2 pia))
        X1 (/ X1 2 pia)
        X0 (- 1 X1)
        Area (* pi R R)
  ) ;setq end
;  (princ txt)
  (setq
        Y1 (- N X1)
        Y1 (/ Y1 (- a at))
  ) ;setq end
(setq         as (/ Y1 fy))
) ;defun end
(defun c:Rnm-as()
(textscr)
(inivar) ;初始化系统变量
(load "tab.lsp")
(setq scale 1)
(princ "\n本程序用于求解沿周边均匀配筋圆形截面偏心受压构件配筋")
(princ "\n钢筋内定为II级钢筋,如按I级钢筋,应乘以系数310/210")
(princ "\nc--砼等级")
(PRINC "\nR(mm),l0(m),N(KN),M(KN-m),c\n:")
(setq l-l (readlh)
       mode (getint "\n按旧规范GB10-89(0)/按新规范GB50010-2002(1)计算:<1>")
       mode (if mode mode 1)
       R (nth 0 l-l)
       Rs (- R 35)
       h (* 2 R)
       h0 (+ R Rs)
      l0 (nth 1 l-l)
      l0 (* l0 1000)
      N (nth 2 l-l)
      N (if (< N 0.1) 0.1 N)
      N (* N 1000)
      M (* (nth 3 l-l) 1e6)
      c (nth 4 l-l)
      fcm (if (= mode 0) (concrete "fcm" c mode)  ;旧规范
                          (* (alfa1 c) (concrete "fc" c mode))  ;新规范
          ) ;if end
      fy 310
      ksib 0.544
      yei (yta b h l0 M N c mode)
) ;setq end
;----画出函数图形
(graphscr)
(command "erase" "w" "0,-10" "3,10" "")
(setq p0 '(0 0) p1 '(3 0) p2 '(0 2) dl 3 x0 0.01)
(command "line" p0 p1 "")
(command "line" p0 p2 "")
(setq y0 (fun N x0)
      y0 (/ y0 1e8) ;将y0缩小1e8倍
        x0 (* dl x0)
      p1 (list x0 y0)
      x1 (+ x0 0.01)
) ;setq end
(repeat 100
(setq y1 (fun N x1)
        y1 (if (> (abs y1) 1e9) 1e9 y1)
        y1 (/ y1 1e8) ;将y1缩小1e8倍
        x0 (* dl x1)
        p2 (list x0 y1)
        x1 (+ x1 0.01)
);setq end
(command "line" p1 p2 "")
(setq p1 p2)
) ;repeat end
;----放大图形
(command "zoom" "w" "0,-10" "3,10")
(princ "\n输入放大两点:")
(command "zoom" "w" pause pause)
(princ "\n点取计算区间")
  (setq  p1 (getpoint "\n第一点:")
         a1 (/ (nth 0 p1) 3.0)
        p2 (getpoint "\n第二点:")
        a2 (/ (nth 0 p2) 3.0)
        da (abs (- a2 a1))
(princ "\n二分法迭代:")
(while   (> da 0.0001)
  (setq f1 (fun N a1)
        f2 (fun N a2)
        a3 (* 0.5 (+ a1 a2))
        f3 (fun N a3)
        temp (if (> (* f1 f2) 0) T nil)
        txt1 (strcat "\nx1=" (rtos a1 2 3) "  f=" (rtos f1 2 3))
        txt2 (strcat "\nx2=" (rtos a2 2 3) "  f=" (rtos f2 2 3))
        txt3 (strcat "\nx3=" (rtos a3 2 3) "  f=" (rtos f3 2 3))
  );setq end
  (princ (strcat "\na=" (rtos a3 2 4) " f(a)=" (rtos f3 2 4)))
  (if (< (* f1 f3) 0)
     (setq a1 a1
           a2 a3
           da (abs (- a2 a1))
     ) ;setq end
  ) ;if end
  (if (< (* f2 f3) 0)
      (setq a1 a3
            a2 a2
            da (abs (- a2 a1))
     ) ;setq end
  ) ;if end
) ;while end
(princ "\n结果:")
(setq as (fun-as N a3)
       txt1 (strcat "\na=" (rtos a3 2 4) "   As=" (rtos as 2 2) "mm2")
) ;setq end
(princ txt1)
(resvar) ;还原系统变量
(princ)
) ;defun end
发表于 2004-1-18 10:42:50 | 显示全部楼层
楼主,你这是什么??
发表于 2009-6-15 22:42:34 | 显示全部楼层
请楼主告诉怎么用啊
GMT+8, 2026-11-22 09:11 , Processed in 0.431092 second(s), 14 queries , Gzip On, File On.
