查看: 1459|回复: 1
[LISP程序]:为什么不能在2000中调用?getvar什么意思?
发表于 2002-9-16 22:12:55 | 显示全部楼层 |阅读模式
;* 图幅坐标初始化,插入图幅和图形比例
(DEFUN C:BEGIN(/ ST SCALE TU CR1 E oldh)
  (SETQ ST (getvar "textstyle"))
  (COMMAND "STYLE" "HZ" "" "" "" "" "" "" ""
           "layer" "s" "0" ""
  );command
  (SETQ SCALE (GETSTRING "\nPlease input the scale of graph请输入图形比例<1:10>: "))
  (IF (= SCALE "") (SETQ SCALE "1:10"))
  (INITGET 1 "A0 A1 A2 A3 A4")
  (SETQ TU (STRCASE (GETKWORD "\nSelect the frame选择图框<A0,A1,A2,A3,A4>: ")))
  (SETQ SCA (ATOF (SUBSTR SCALE 3)))
  (IF (= TU "A0")
    (SETQ B 841 L 1189 A 25 C 10
          CR1 (LIST (* (- L C 6) SCA) (* 29.25 SCA))
          TU "C:\\BYQ94\\BYQ\\A0"
    );SETQ
  );IF
  (IF (= TU "A1")
    (SETQ B 594 L 841 A 25 C 10
          TU "C:\\BYQ94\\BYQ\\A1"
    );SETQ
  );IF
  (IF (= TU "A2")
    (SETQ B 420 L 594 A 25 C 10
          TU "C:\\BYQ94\\BYQ\\A2"
    );SETQ
  );IF
  (IF (= TU "A3")
    (SETQ B 297 L 420 A 25 C 5
          CR1 (LIST (* (- L C 6) SCA) (* 24.25 SCA))
          TU "C:\\BYQ94\\BYQ\\A3"
    );SETQ
  );IF
  (IF (= TU "A4")
    (SETQ B 210 L 297 A 25 C 5
          CR1 (LIST (* sca (- B C 6))  (* sca 24.25))
          TU "C:\\BYQ94\\BYQ\\A4"
    );SETQ
  );IF
   (SETQ E (tblsearch "style" (getvar "textstyle"))
        oldh (* sca (CDR (ASSOC 40 E)))
   );SETQ
  (COMMAND "INSERT" TU (LIST 0 0) sca "" ""
           "STYLE" "HZ" "" (* sca 3.5) "" "" "" "" "" ""
           "TEXT" "J" "M" CR1 "" SCALE  ;插入图比例
           "STYLE" ST "" oldh "" "" "" "" "" ""
           "ZOOM" "A"
           "dim" "dimsoxd" "off"
                 "dimtih" "off"
                 "dimtoh" "off"
                 "dimtad" "on"
                 "dimtix" "on"
                 "dimdli" (* sca 7)
                 "dimexe" (* sca 3)
                 "dimexo" 0
                 "dimasz" (* sca 2.5)
                 "dimtxt" (* sca 4)
           "exit"
           "scale" "c" '(0 0) (list (* sca L) (* sca B)) "" '(0 0) (/ 1.0 sca)
           "zoom" "e"
           "units" 2 1 1 0 0 "N"
);COMMAND
);DEFUN
(defun start() ; xhcase rl gy dy  is public argument
(prompt "\n")
(if (setq fname1 (open "c:\\byq94\\txt\\fname.txt" "r"))
   (progn
           (setq XinHaoMing (read-line fname1)
                   xinhaoming (read xinhaoming)
                   xhcase (cdr (nth 0 XinHaoMing))
                           rl (cdr (nth 1 XinHaoMing))
                          gy (cdr (nth 2 XinHaoMing))
                          dy (cdr (nth 3 XinHaoMing))
           );setq
;系列号
            (if (= xhcase 7) (setq xh "S7"))
            (if (= xhcase 9) (setq xh "S9"))
           (setq
                  rlst (itoa rl)
                  gyst (itoa gy)
                  dyst (rtos dy 2 1)
                  xhst (strcat xh "--" rlst "/" gyst "/" dyst) ;xhst是型号名
                  TiShi (strcat "当前作图型号为: " xhst )
           );setq
          (prompt TiSHi)
           (initget 1 "Y  N")
           (setq fnayes (getkword "   是否就此型号作图?<Y/N>:   "))
           (setq fnayes (strcase fnayes));setq
    );progn
  (setq fnayes "N")
);if
(if (= fnayes "N")
  (progn
     (initget 1 "S7 S9")
     (setq xh (getkword "请输入型号<:S7 .S9..>  :  "))
     (setq rl (getint "请输入容量<例:100>  :"))
     (initget 1 "6000 6300 10000 35000")
     (setq gy (getkword "请输入高压<10000,35000,6000,6300(单位V)>   :") )
     (initget 1 "400 6300 10000")
     (setq dy (getkword "请输入低压<400,6300,10000>   :"))
     (setq  fna "f"
                gy (atoi gy)
                dy (atof dy)
     );setq
   );progn
);if
      (setq  xh (strcase xh)
              rlst (itoa rl)
             gyst (itoa gy)
            dyst (rtos dy 2 1)
           ;xhst是型号名
              gyst2 (itoa (/ gy 1000))
            dyst2 (rtos (/ dy 1000) 2 1)
            xhst (strcat xh "--" rlst "/" gyst2 "/" dyst2)
       );setq
(if (= xh "S7") (setq  xhcase "7"))
(if (= xh "S9") (setq xhcase "9"))
(if (= fna "f")
    (progn
      (setq XinHaoMing (strcat "((xl . " xhcase ")(rl . " rlst ")(gy . " gyst ")(dy . " dyst "))")
                 fname2 (open "c:\\byq94\\txt\\fname.txt" "w")
      );setq
      (write-line XinHaoMing fname2)
     );progn
);if
);defun
发表于 2002-9-16 23:54:12 | 显示全部楼层
有什么出错提示?
getvar是取得(显示)系统变量的值
GMT+8, 2026-11-3 02:43 , Processed in 0.630244 second(s), 34 queries , Gzip On.
