查看: 1093|回复: 1
[LISP程序]:修改缺少字体定义文件的程序
发表于 2004-2-15 21:22:42 | 显示全部楼层 |阅读模式
  1. (defun c:zt ()
  2.   (setq        tlist (tblnext "STYLE" T)
  3.         slist nil
  4.         bgfnt nil
  5.   )
  6.   (while tlist
  7.     (setq sname (cdr (assoc 2 tlist)))
  8.     (if        (and (/= sname "")
  9.              (/= (logand 16 (cdr (assoc 70 tlist))) 16)
  10.         )
  11.       (setq slist (cons sname slist))
  12.     )
  13.     (setq smpfnt (cdr (assoc 3 tlist)))
  14.     (setq bgfnt (cdr (assoc 4 tlist)))
  15.     (if
  16.       (and (/= bgfnt "")
  17.            (not (or (findfile (strcat bgfnt ".shx")) (findfile bgfnt)))
  18.       )
  19.        (progn
  20.          (princ "\n********")
  21.          (princ sname)
  22.          (princ "********\n")
  23.          (setq tlist(entget(tblobjname "style" sname)))
  24.          (setq tlist (subst (cons 4 "hztxt.shx") (assoc 4 tlist) tlist))
  25.          (princ(entmod tlist))
  26.        )
  27.     )
  28.     (if
  29.       (or (and (/= smpfnt "")
  30.                (not
  31.                  (or (findfile (strcat smpfnt ".shx")) (findfile smpfnt))
  32.                )
  33.           )
  34.           (wcmatch smpfnt "*`.ttf")
  35.       )
  36.        (progn
  37.          (princ "\n********")
  38.          (princ sname)
  39.          (princ "********\n")
  40.          (setq tlist(entget(tblobjname "style" sname)))
  41.          (setq tlist (subst (cons 4 "hztxt.shx") (assoc 4 tlist) tlist))
  42.          (setq tlist (subst (cons 3 "txt.shx") (assoc 3 tlist) tlist))
  43.          (princ(entmod tlist))
  44.          (setq tlist_last tlist)
  45.        )
  46.     )
  47.     (setq tlist (tblnext "STYLE"))
  48.   )
  49.   (princ slist)
  50.   (princ)
  51. )
 楼主| 发表于 2004-2-25 18:13:57 | 显示全部楼层
结果怎样?
GMT+8, 2026-11-4 05:20 , Processed in 0.460006 second(s), 34 queries , Gzip On.
