查看: 867|回复: 1
[必看]:VisualLISP和LISP谁的性能更好?
已领礼包: 1915个
财富等级: 堆金积玉
发表于 2004-2-26 15:04:24 | 显示全部楼层 |阅读模式
在AUTOCAD 2002的SAMPLE\VISUALLISP\ACTIVEX下有两个程序AL-TST.LSP,VLA-TST.LSP作为AUTOLISP和VISUALLISP的性能对比,显示VISUALLISP的优越性,我对AL-TST.LSP中的子函数aal-tst做了如下修改:
  1.   [FONT=courier new]
  2. (defun aal-tst (/ ent centerPoint nPoint i ind offs ss cnt lwh2 lwh pt1
  3.                 pt2 pt3 pt4)
  4. (setq offs (car (getvar "snapunit")))
  5. (setq lwh2 (/ (setq lwh 5.0) 2.0))
  6. (princ "Creating 2000 PolyLines.\n")
  7.   (setq i 0)
  8.   (while (< i 2000)
  9.     ;; creates an LWPolyLine in model space
  10.     (setq pt1 (list (* -1.0 lwh2) (* -1.0 lwh2)))
  11.     (setq pt2  (list lwh2 (* -1.0 lwh2)))
  12.     (setq pt3  (list lwh2 lwh2))
  13.     (setq pt4  (list (* -1.0 lwh2) lwh2))
  14.     (setq entm (entmake
  15.                  (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(8 . "0") '(100 . "AcDbPolyline")
  16.                        '(38 . 0.0) '(39 . 0.0) '(90 . 4) '(70 . 1)
  17.                         (cons 10 pt1) (cons 10 pt2) (cons 10 pt3) (cons 10 pt4)
  18.                  ))
  19.     )
  20.     (entupd (entlast))
  21. ;    (command "PLINE" pt1 pt2 pt3 pt4 "C")
  22.     (setq lwh2 (/ (setq lwh (+ lwh offs)) 2.0))
  23.     (setq i (1+ i))
  24.   )
  25.   (REDRAW)
  26.   (setq cnt (SSLENGTH (setq ss (ssget "_X"))))
  27. ;; Changes the Color
  28.   (princ "Changing 2000 LWPolylines to Red Color.\n")
  29.   (command "_.change" ss "" "P" "C" "1" "")
  30. ;;  (change-property-s ss 62 1)
  31.   (REDRAW)
  32. ;; Sets to Invisible  - Cannot be Done Via AutoLisp
  33. ;;  (change-property-s ss 60 acFalse)
  34.   (REDRAW)
  35.   (princ "Erasing 2000 LWPolylines.\n")
  36.   (COMMAND "ERASE" SS "")
  37. ;  (setq i (1- (SSLENGTH ss)))
  38. ;  (while (>= i 0)
  39. ;    (setq ent (ssname ss i);
  40. ;          i   (1- i)
  41. ;    )
  42. ;    (COMMAND "ERASE" ent "")
  43. ;  )
  44.   (setq ss nil)
  45. )
  46. [/FONT]
性能有了极大的提高,运行时间不到不到原来的1/10,大家对比一下带分号和不带分号的代码就知道了,不知道AUTODESK这种自欺欺人的做法是什么意思?在我看来AUTOLISP的性能要好过VISUALLISP和VBA,略差于ARX,却是最简单易用Q
已领礼包: 593个
发表于 2004-2-26 19:45:30 | 显示全部楼层
GMT+8, 2026-11-4 06:23 , Processed in 0.705021 second(s), 34 queries , Gzip On.
