查看: 1035|回复: 0
[VBA程序]:如何往“块对象”里面增加尺寸实体。
发表于 2002-9-27 17:55:46 | 显示全部楼层 |阅读模式
How to add dimension entities to a block object?
ID    48357
Applies to:    AutoCAD 2000
This document is part of    Dimensions   Block Reference   COM-ActiveX Interfaces   VBA
Question
The AddDimAligned method of Block object produces incorrect dimension objects.
How can I add dimension entities to a Block object?
Answer
The AddDimAligned method as well as other AddDimxxx methods of adding dimension
entities to a Block object results in dimension objects that are incorrect.
This is a known problem. Use the following workaround to add dimension entities
to a block object:
1.  Create a Dimension entity in model space.
2.  Use the CopyObject method to copy the Dimension entity to a Block object.
3.  Delete the original Dimension entity from model space.
The following sample code creates a block "test", adds a DimRotated entity to
the block, and then inserts the block into model space.
  1. [FONT=courier new]
  2. Sub f_SolAddDiminBlocks()
  3. 'Workaround for Adding dimensions to block AutoCAD 2000.
  4. Dim po_rotDim As AcadDimAligned
  5. Dim po_block As AcadBlock
  6. Dim pd_ext1(0 To 2) As Double
  7. Dim pd_ext2(0 To 2) As Double
  8. Dim pd_lineLoc(0 To 2) As Double
  9. Dim po_array(0) As Object
  10. pd_ext1(0) = 3: pd_ext1(1) = 3: pd_ext1(2) = 0
  11. pd_ext2(0) = 10: pd_ext2(1) = 3: pd_ext2(2) = 0
  12. pd_lineLoc(0) = 5: pd_lineLoc(1) = 4: pd_lineLoc(2) = 0
  13. 'create dimeionsion object
  14. Set po_rotDim = ThisDrawing.ModelSpace.AddDimAligned(pd_ext1, pd_ext2,
  15. pd_lineLoc)
  16. 'create a new block by name test
  17. Set po_block = ThisDrawing.Blocks.Add(pd_ext1, "test")
  18. 'insert a block reference
  19. ThisDrawing.ModelSpace.InsertBlock pd_ext1, "test", 1, 1, 1, 0
  20. 'copy dimension object
  21. Set po_array(0) = po_rotDim
  22. ThisDrawing.CopyObjects po_array, po_block
  23. po_rotDim.Delete
  24. 'release the references
  25. Set po_block = Nothing
  26. Set po_rotDim = Nothing
  27. End Sub[/FONT]
GMT+8, 2026-11-22 09:44 , Processed in 0.369166 second(s), 10 queries , Gzip On, File On.
