查看: 1149|回复: 0
[VBA程序]:通过VBA获得块的常量属性
发表于 2002-9-27 18:18:15 | 显示全部楼层 |阅读模式
How to get the constant attributes of a blockref through VBA
ID    12559
Applies to:    AutoCAD 2000
AutoCAD 2000I
AutoCAD 2002
This document is part of    Attribute   Block Reference   COM-ActiveX Interfaces   VBA
Question
I have a drawing that has many different blocks, each block has three constant
attributes (tags 'code' 'desc' and 'linfoot'). How do I get the block name,the
attribute values, and find how many times the block is inserted and put this
information into a spreadsheet using VBA?
Answer
You can get the block information from the block definition in the block table
using VBA.
The following sample demonstrates this by getting all the attributes of all the
block references found in model space. You need to create a simple form which
contains a listbox named ListBox1 and a button that starts the following
procedure:
  1. [FONT=courier new]
  2. Private Sub CommandButton1_Click()
  3.   Dim elem As Object
  4.   Dim block As AcadBlock
  5.   Dim item As Object
  6.   Dim Array1 As Variant
  7.   Dim count As Integer
  8.   Dim MBtest1 As String
  9.   Dim str As String
  10.   For Each elem In ThisDrawing.ModelSpace
  11.     If elem.EntityName = "AcDbBlockReference" Then
  12.         If elem.HasAttributes Then
  13.         Array1 = elem.GetAttributes
  14.         For count = LBound(Array1) To UBound(Array1)
  15.             If (Array1(count).EntityName) = "AcDbAttribute" Then
  16.                 MBtest1 = Array1(count).TagString & " - " &
  17. Array1(count).TextString
  18.                 ListBox1.AddItem MBtest1
  19.             End If
  20.         Next count
  21.         'Get the block definition from the block table
  22.         str = elem.Name
  23.         Set block = ThisDrawing.Blocks.item(str)
  24.         For Each item In block
  25.           str = item.EntityName
  26.          'Get the Constant attributes
  27.           If item.EntityName = "AcDbAttributeDefinition" Then
  28.             If item.Mode = acAttributeModeConstant Then
  29.               ListBox1.AddItem item.TagString & " - " & item.TextString
  30.             End If
  31.           End If
  32.         Next item
  33.         End If
  34.     End If
  35.    Next elem
  36. End Sub
  37. [/FONT]
GMT+8, 2026-11-22 09:44 , Processed in 0.334790 second(s), 10 queries , Gzip On, File On.
