查看: 714|回复: 2
[求助]:CAD2004 中文版快捷键怎样更改?
发表于 2004-3-11 10:19:09 | 显示全部楼层 |阅读模式
我想把CAD 2004中文版的快捷键设置成自己熟悉的左手键,如ES,    *ELLIPSE
FF,    *LINE
A,     *ARC  创建圆弧
AD,    *ATTEDIT 改变属性信息
AG,    *ALIGN 将对象与其他对象对齐
AR,    *ARRAY 阵列
B,     *BLOCK 创建块
BR,    *BREAK 打断选定对象
C,     *CIRCLE 创建圆
CA,    *CAL 计算算术和几何表达式
CC,    *COPY 复制对象
CF,    *CHAMFER 为对象的边加倒角
D,     *DIMSTYLE 创建和修改标注样式
DA,    *DIMANGULAR 创建角度标注
DD,    *DIMDIAMETER 创建圆和圆弧的直径标注
DE,    *DIMLINER 创建线性标注
DG,    *DIMALIGNED 创建对齐线性标注
DR,    *DIMRADIUS 创建圆和圆弧的半径标注
E,     *ERASE 从图形中删除对象
ES,    *ELLIPSE 创建椭圆
EX,    *EXTEND 延伸对象
F,     *FILLET 倒圆角
FC,    *POLYGON 创建闭合的等边多段线
FF,    *LINE 创建直线段
FS,    *OFFSET 偏移
FV,    *MOVE 移动对象
R,     *PAN 在当前视口中移动视图
RA,    *RAY 画射线
RD,    *REDO 撤销前面UNDO 或 U 命令的效果
REC,   *RECTANG 绘制矩形多段线
RT,    *ROTATE 旋转
SC,    *SCALE 按比例放大或缩小对象
SD,    *DDSELECT 选项设置
T,     *TRIM 修剪对象
V,     *UNDO 撤消命令
WW,    *MIRROR 镜像    等等       听一些高手说可以改 安装目录下的support文件夹里的 acad2004.lsp    我的更改如下
; MODULE_ID ACAD2004_LSP_
;;;    ACAD2004.LSP Version 1.0 for AutoCAD 2004
;;;    Copyright (C) 1994-2002 by Autodesk, Inc.
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;;    Note:
;;;            This file is normally loaded only once per AutoCAD session.
;;;            If you wish to have LISP code loaded into every document,
;;;            you should add your code to acaddoc.lsp.
;;;    Globalization Note:
;;;            We do not support autoloading applications by the native
;;;            language command call (e.g. with the leading underscore
;;;            mechanism.)
(if (not (=  (substr (ver) 1 11) "Visual LISP")) (load "acad2004doc.lsp"))
;; Silent load.
(princ)
(defun C:ar ( / )
  (command "._array" "all" "" "No")
  (princ)
(defun C:b ( / )
  (command "._block" "all" "" "No")
  (princ)
  可是更改了之后还是不能用,有哪位高手可以指点一下,帮我把上面的程序修改!!!  先谢谢了
发表于 2004-3-11 10:51:52 | 显示全部楼层
点菜单[工具]/[自定义]/[编辑自定义文件]/[程序参数]  就可以改了  改了重新启动2004  就可以用了!!:)
 楼主| 发表于 2004-3-11 11:38:46 | 显示全部楼层
哈哈,懂了, 多谢!!!
GMT+8, 2026-11-5 08:55 , Processed in 0.360160 second(s), 36 queries , Gzip On.
