查看: 1502|回复: 4
[ARX程序]:求教:这个插入图块的函数错在哪?
发表于 2004-4-12 16:46:31 | 显示全部楼层 |阅读模式
[php]
void insrtBlk(CString blk_name)
        char blkName[50];
        AcDbDatabase *pCurDb;
        AcDbBlockTable *pBlkTable;
        AcDbBlockTableRecord *pBlkTableRecord;
        AcDbBlockTableRecord *pBlkDefRecord;
        AcDbBlockReference *pInsrtObj;
        AcDbEntity *pEnt;
        AcDbBlockTableRecordIterator *pIterator;
        AcDbAttributeDefinition *pAttDef;
        AcDbAttribute *pAtt;
        AcDbObjectId blkId;
        AcDbObjectId insrtId;
        AcGePoint3d insPt(0.0,0.0,0.0);
        AcGePoint3d basePt;
        strcpy(blkName,blk_name);
        char *pTagPrompt;
        if(blkName[0] == '\0')
                acutPrintf("\nInvalid block name.");
                return;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
        if(!pBlkTable->has(blkName))
                acutPrintf("\nBlock definition %s not found. ", blkName);
                pBlkTable->close();
                return;
        pBlkTable->getAt(blkName, blkId);
        pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
        pBlkTable->close();
        pInsrtObj = new AcDbBlockReference(insPt, blkId);
        pBlkTableRecord->appendAcDbEntity(insrtId, pInsrtObj);
        acdbOpenObject(pBlkDefRecord, blkId, AcDb::kForRead);
        if(pBlkDefRecord->hasAttributeDefinitions())
                pBlkDefRecord->newIterator(pIterator);
                for(pIterator->start(); !pIterator->done(); pIterator->step())
                        pIterator->getEntity(pEnt, AcDb::kForRead);
                        pAttDef = AcDbAttributeDefinition::cast(pEnt);
                        if(pAttDef != NULL && !pAttDef->isConstant())
                                pAtt = new AcDbAttribute();
                                pAtt->setPropertiesFrom(pAttDef);
                                pAtt->setInvisible(pAttDef->isInvisible());
                                basePt = pAttDef->position();
                                basePt += pInsrtObj->position().asVector();
                                pAtt->setPosition(basePt);
                                pAtt->setHeight(pAttDef->height());
                                pAtt->setRotation(pAttDef->rotation());
                                pTagPrompt = pAttDef->tag();
                                pAtt->setTag(pTagPrompt);
                                free(pTagPrompt);
                                pTagPrompt = pAttDef->prompt();
                                acutPrintf("%s%s", "\n", pTagPrompt);
                                free(pTagPrompt);
                                pAtt->setFieldLength(25);
                                pAtt->setTextString("This is a test");
                                pInsrtObj->appendAttribute(pAtt);
                                pAtt->close();
                        pEnt->close();
                }// for
        }// if has attribute definitions
        delete pIterator;
        pBlkTableRecord->close();
        pInsrtObj->close();
前面的insrtBlk函数用在下面的ReadBlockName的函数中就出错!
void ReadBlockName()
        char *pLtName;
        CString blkName;
        AcDbDatabase *pCurDb = NULL;
        AcDbBlockTable *pltTable;
        AcDbBlockTableRecord *pLtTableRcd;
        AcDbBlockTableIterator *pLtIterator;
        pCurDb->getBlockTable(pltTable, AcDb::kForRead);
        pltTable->newIterator(pLtIterator);
        for(; !pLtIterator->done(); pLtIterator->step())
                pLtIterator->getRecord(pLtTableRcd, AcDb::kForRead);
                pLtTableRcd->getName(pLtName);
                pLtTableRcd->close();
                blkName = pLtName;
                if((blkName[0] != '*') && (blkName[0] != '\0'))
                {        acutPrintf("\nBlock name: %s", blkName);
                        insrtBlk(blkName);  //在这里
                blkName.Empty();
                delete [] pLtName;
        }// for
        delete pLtIterator;
        pltTable->close();
[/php]
望高手指点!
发表于 2004-4-13 21:43:38 | 显示全部楼层
会不会是database 没有关闭?
 楼主| 发表于 2004-4-14 01:25:47 | 显示全部楼层
当前的数据库,好像不用关闭
insrtBlk函数是抄<<AUTOCAD 2000 ObjectARX编程指南>>书上的.
发表于 2004-4-14 02:54:20 | 显示全部楼层
Re: 当前的数据库,好像不用关闭
最初由 zxb888 发布
[B]insrtBlk函数是抄<<AUTOCAD 2000 ObjectARX编程指南>>书上的. [/B]
你把出错的现象、错误提示和自己调试到哪个位置出现错误等详细信息贴论坛来吧,这样大家也有目的的看。
发表于 2016-9-21 22:32:17 | 显示全部楼层
楼主,你的两段代码里面,都打开了块表进行读操作,另外,为什么不在每个操作后判定下返回值呢,尤其那些打开对象读写的地方,有返回值,根据是否成功在进行下一步操作。
GMT+8, 2026-11-22 08:57 , Processed in 0.299378 second(s), 18 queries , Gzip On, File On.
