查看: 1612|回复: 10
[LISP程序]:(分享+原创)新手接触lisp 的实用程序
发表于 2004-4-14 11:11:50 | 显示全部楼层 |阅读模式
[php](defun c:ss(/ ent lname);通过选择实体设置当前图层
(setvar "cmdecho" 0)
(setq ent (car (entsel "\nPick an entity on the target layer: ")))
(if ent
  (progn
   (setq ent (entget ent)
         lname (cdr (assoc 8 ent)))
  (progn
     (setq lname (getstring "\nNot to selected, Input layer name: "))
  );if ent
(setvar "clayer" lname)
(princ)
(defun c:cc(/ lname ss ent);通过目标物体改变选择实体的图层属性
(prompt "\nSelect the entity(s): ")
(setq ss (ssget))
(if ss
  (progn
   (setq ent (entsel "\nPick an entity on the target layer: "))
   (if ent
    (progn
     (setq ent (entget (car ent)))
     (setq lname (cdr (assoc 8 ent)))
    (progn
   ) ;if ent
   (command "chprop" ss "" "la" lname "")
(princ)
(defun c:xc( / os s1 s2 ss1 ss2 pt1 pt2 pt3 pt4 p01 p02 p12 p34);连接线段
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq s1 (entsel "\nPick the First Line:"))
  (if s1 (progn
    (redraw (setq s1 (car s1)) 3)
    (setq s2 (entsel "\nPick the Second Line:"))
  (if (and s1 s2)
    (progn
      (setq s2 (car s2))
      (redraw s1 3)
      (setq ss1 (entget s1))
      (setq ss2 (entget s2))
      (if (and (= (cdr (assoc 0 ss1)) "LINE" ) (= (cdr (assoc 0 ss2)) "LINE"))
        (progn
          (setq pt1 (cdr (assoc 10 ss1)) pt2 (cdr (assoc 11 ss1))
                pt3 (cdr (assoc 10 ss2)) pt4 (cdr (assoc 11 ss2))
                p01 (list (* 0.5 (+ (car pt1) (car pt2)))
                          (* 0.5 (+ (cadr pt1) (cadr pt2))))
                p02 (list (* 0.5 (+ (car pt3) (car pt4)))
                          (* 0.5 (+ (cadr pt3) (cadr pt4))))
          (if (> (distance pt1 p02) (distance pt2 p02))
            (setq p12 pt1)
            (setq p12 pt2)
          (if (> (distance pt3 p01) (distance pt4 p01))
            (setq p34 pt3)
            (setq p34 pt4)
          (setq ss1 (subst (cons 10 p12) (assoc 10 ss1) ss1)
                ss1 (subst (cons 11 p34) (assoc 11 ss1) ss1))
          (entdel s2)
          (entmod ss1)
        ) ;progn
        (princ "\nPlease select Line!")
      ) ;if
      (redraw s1 4)
    ) ;progn
    (princ "\nPlease select entity!")
  ) ; if s1 s2
  (setvar "osmode" os)
  (princ)
) ; end xc
(defun c:s() (command "stretch" "C"))
(defun c:1() (command "zoom" "1.5x") (prin1))
(defun c:2() (command "zoom" "0.5x") (prin1))
(defun c:zz() (command "zoom" "p"))
(defun c:za() (command "zoom" "a"))
(defun c:zd() (command "zoom" "d"))
(defun c:ze() (command "zoom" "e"))
(defun c:-() (command "zoom" "0.5x"))
(defun c:+() (command "zoom" "2x"))
(defun c:lo() (setvar "cmdecho" 0) (command "layer" "on" "*" ""))
(defun c:lp( / ent lname)
  (if ent (progn
  )) ;if ent
  (command "layer" "off" "*" "n" "")
  (princ)
(defun c:lk( / ent lname);关闭图层
  (if ent
    (progn
  ) ;if ent
  (if (= (getvar "clayer") lname)
    (setvar "clayer" "0")
  (command "layer" "off" lname "")
  (princ)
;以下程序 源自 Chstart
;改变物体到当前层,并使用层颜色,层的线型
(defun c:rr(/ lname ss )
     (setq ss (ssget))
        (if ss
            (progn
               (setq lname (getvar "clayer"))
                                        "color" "bylayer"
                                        "ltype" "bylayer" "")
        );if ss
;原点打断线段
(defun c:BB()(setq p1 (getpoint "Select Break Point"))
       (command "break" p1 p1 "" )
;隐藏实体,通过regen 可以恢复显示,方便重复线段的选择
(defun c:ee()(setq ss (ssget))
                (setq i 0)
                (while (<= i (sslength ss))
                         (setq abc (ssname SS i))
                          (redraw abc 2)
                          (setq i (+ 1 i))
))[/php]
发表于 2004-4-15 14:00:54 | 显示全部楼层
开卷有益!
得到不少提示!
发表于 2004-4-16 17:38:11 | 显示全部楼层
请问“原点打断线段  ”你测试了吗?好像不能用吧
 楼主| 发表于 2004-4-16 19:43:37 | 显示全部楼层
可以啊。
我一直都在用这些命令。
break命令可以打断pline,arc,line,spline,不过圆不能直接从原点打断,得另外写程序。
已领礼包: 1491个
发表于 2004-4-29 14:48:40 | 显示全部楼层
我是新手,那些bylayer可以改的对吗?谢谢。
发表于 2004-5-7 11:03:22 | 显示全部楼层
对于我来说都是很好的东西,感谢分享!
 楼主| 发表于 2004-5-8 15:56:58 | 显示全部楼层
最初由 flowerson 发布
[B]我是新手,那些bylayer可以改的对吗?谢谢。 [/B]
“改的对”指得是什么?
发表于 2004-5-17 17:52:06 | 显示全部楼层
chstart ,你是不是在深圳啊?
好像我在深圳一公司的lisp程序,
我现在自制了好多lisp(结构方面的),
也有用到原来公司的程序.
发表于 2004-5-17 23:01:00 | 显示全部楼层
最初由 chstart 发布
[B]可以啊。
我一直都在用这些命令。
break命令可以打断pline,arc,line,spline,不过圆不能直接从原点打断,得另外写程序。 [/B]
确实不行,反馈:
BB Select Break Point
Arc cannot be full 360 degreesUnknown command "BB".  Press F1 for help.
nil
发表于 2004-5-18 07:43:38 | 显示全部楼层
最初由 海豚 发布
[B][QUOTE]最初由 chstart 发布
[B]可以啊。
我一直都在用这些命令。
break命令可以打断pline,arc,line,spline,不过圆不能直接从原点打断,得另外写程序?.. [/B]
程序是没有大问题,只是缺乏必要的判断,在一些特殊情况下会出错,或者说程序不够健壮。
发表于 2004-5-19 11:14:11 | 显示全部楼层
最初由 david96007 发布
[B]开卷有益!
得到不少提示! [/B]
谢楼住发布
GMT+8, 2026-11-4 20:49 , Processed in 0.581233 second(s), 52 queries , Gzip On.
