查看: 746|回复: 1
[求助]:vba中,如何实现物体捕捉???
发表于 2004-4-24 22:25:59 | 显示全部楼层 |阅读模式
在下面这个例子中,如何实现画线的顶点捕捉在物体???thanks very much!!!!!
Sub PlaceLine()
    CommandState.StartPrimitive New clsPlaceLineCommand
End Sub
Implements IPrimitiveCommandEvents
Private m_atPoints(0 To 1) As Point3dPrivate m_nPoints As Integer
Private Sub IPrimitiveCommandEvents_Cleanup()
End Sub
Private Sub IPrimitiveCommandEvents_DataPoint(Point As Point3d, ByVal View
As View)
    If m_nPoints = 0 Then
        CommandState.StartDynamics
        m_atPoints(0) = Point
        m_nPoints = 1
        ShowPrompt "Place end point"
    ElseIf m_nPoints = 1 Then
        m_atPoints(1) = Point
        Dim oEl As LineElement
        Set oEl = CreateLineElement1(Nothing, m_atPoints)
        ActiveModelReference.AddElement oEl
        oEl.Redraw
        m_atPoints(0) = m_atPoints(1)
    End If
End Sub
Private Sub IPrimitiveCommandEvents_Dynamics(Point As Point3d, ByVal View As
View, ByVal DrawMode As MsdDrawingMode)
        oEl.Redraw DrawMode
    End If
End Sub
Private Sub IPrimitiveCommandEvents_Keyin(ByVal Keyin As String)
End Sub
Private Sub IPrimitiveCommandEvents_Reset()
    CommandState.StartPrimitive Me
    m_nPoints = 0
End Sub
Private Sub IPrimitiveCommandEvents_Start()
    ShowCommand "VBA PlaceLine Example"
    ShowPrompt "Select start of line"
End Sub
 楼主| 发表于 2004-4-26 19:13:49 | 显示全部楼层
各位大虾:
帮帮我,急急!!!!!!!!!
GMT+8, 2026-11-4 18:01 , Processed in 0.676623 second(s), 34 queries , Gzip On.
