查看: 654|回复: 0
[VBA函数]:大家给我看看我的vba程序问题在哪里呀
发表于 2004-7-30 16:57:29 | 显示全部楼层 |阅读模式
我用vba例子里的程序改了个给文本求和的程序(见附件)
可是总也实现不了
只能在状态拦显示每次选择的文本值  没有求和
以下是我的类模块
大家帮忙给看看
'Following is the code from the clsAddText class.
Implements IPrimitiveCommandEvents
Dim m_otextElement As TextElement
Dim total As Double
Private Sub IPrimitiveCommandEvents_Cleanup()
End Sub
Private Function Locatetext(Point As Point3d, View As View) As TextElement
On Error GoTo NoElement
    ' LocateElement will locate any type of element, but if it returns
    ' an element that is not an text then VBA will generate an error
    ' when it tries to store the object reference in Locatetext.
    Set Locatetext = CommandState.LocateElement(Point, View, True)
NoElement:
End Function
Private Sub IPrimitiveCommandEvents_DataPoint(Point As Point3d, ByVal View As View)
        If m_otextElement Is Nothing Then
        '  This is the first data point. Use it to locate an text
        Set m_otextElement = Locatetext(Point, View)
            ShowError "No text Found"
            Exit Sub
        End If
    total = Val(m_otextElement.Text) + Val(total)
    ShowStatus "Total=" & total
    CommandState.StartPrimitive New clsAddText
    End If
End Sub
Private Sub IPrimitiveCommandEvents_Dynamics(Point As Point3d, ByVal View As View, ByVal DrawMode As MsdDrawingMode)
        Exit Sub
    End If
End Sub
Private Sub IPrimitiveCommandEvents_Keyin(ByVal Keyin As String)
End Sub
Private Sub IPrimitiveCommandEvents_Reset()
    If Not m_otextElement Is Nothing Then
        m_otextElement.Redraw msdDrawingModeTemporaryErase
    End If
    '  Start from the beginning, using a new object to
    '  be certain that it is completely reinitialized.
End Sub
Private Sub IPrimitiveCommandEvents_Start()
    ShowCommand "Vba Modify text"
    ShowPrompt "Select text"
    CommandState.SetLocateCursor
End Sub
这几个事件的发生顺序如何的
GMT+8, 2026-11-4 04:22 , Processed in 0.446760 second(s), 32 queries , Gzip On.
