查看: 699|回复: 4
[ARX程序]:急求问!调用自定义类画一个图形,编译时出错
发表于 2004-5-14 16:41:14 | 显示全部楼层 |阅读模式
急求问!调用自定义类画一个图形,编译时出错,fatal error C1010: unexpected end of file while looking for precompiled header directive
      出错文件是RectWindow.cpp
This error can be caused by specifying an incorrect file as a header file, or by specifying an include file with the /Yu (Use Precompiled Header) command line option that is not listed in the source file as an include file.
这是MSDN上的提示,我不太明白,望大虾指点!!!!
类头文件和执行文件如下:
//RectWindow.h
#ifndef RECTWINDOW_H
#define RECTWINDOW_H
#include <gept2dar.h>
class RectWindow
        public:
                RectWindow();        // Constructor
                ~RectWindow();        // Destructor
                void drawWindow(AcDbBlockTableRecord* pBlkTableRecord);
                void setWindowRows(int rowQty);
                void setWindowCols(int colQty);
                virtual void setWindowHeight(double windHeight);
                void setWindowLength(double windLength);
                void setWindowStartPoint(AcGePoint2d lowLeftPoint);
        protected:
                double getWindowLength() const;
                double getWindowHeight() const;
                AcGePoint2d getWindowStartPoint() const;
                double getIntrFrameThk() const;
                double getRectFrameThk() const;
                Adesk::Boolean drawIntBar(AcDbBlockTableRecord* pBlkTableRecord,
        AcGePoint2dArray intBarAr);
        private:
                Adesk::Boolean drawRectFrame(AcDbBlockTableRecord* pBlkTableRecord,
        AcGePoint2dArray &inrRectFrame);
                int getWindowRows() const;
                int getWindowCols() const;
                int rows;
                int cols;
                double rectFrameLen;
                double rectFrameHt;
                double rectFrameThk;
                double intrFrameThk;
                AcGePoint2d lowLeftPt;
#endif
////////执行文件//////////////  RectWindow.cpp
#include <acdb.h>                // acdb definitions
#include <adslib.h>                // ads defs
#include <dbsymtb.h>
#include <adeskabb.h>
#include <dbpl.h>                // AcDbPolyline
#include <gepnt2d.h>
#include "RectWindow.h"
RectWindow::RectWindow()
        rectFrameThk = 2.00;
        intrFrameThk = 1.00;
        rows = 1;
        cols = 1;
        rectFrameLen = 0.0;
        rectFrameHt         = 0.0;
        lowLeftPt.set(0.0, 0.00);
RectWindow::~RectWindow()
void RectWindow::drawWindow(AcDbBlockTableRecord* pBlkTableRecord)
        AcGePoint2dArray inrRectFrame;
        AcGePoint2dArray inrTopAr, inrBtmAr, inrLeftAr, inrRtAr;
        AcGePoint2dArray barAr;
        AcGeLineSeg2d inrTop, inrBtm, inrLeft, inrRt;
        AcGeVector2d vec;
        AcGePoint2d sp, ep, ll, lr, ul, ur;
        double frameThk;
        int arSize;
        int rowPos, colPos;
        int rows, cols;
        if(!drawRectFrame(pBlkTableRecord, inrRectFrame))
                return;
        rows = getWindowRows();
        cols = getWindowCols();
        if(rows == 1 && cols == 1)
                return;
        arSize = inrRectFrame.length();
        if(arSize != 4)
                acutPrintf("\nInvalid internal rect frame array. ");
                return;
        frameThk = getIntrFrameThk();
        barAr.setLogicalLength(0);
        inrTop.set(inrRectFrame.at(3), inrRectFrame.at(2));
        inrBtm.set(inrRectFrame.at(0), inrRectFrame.at(1));
        inrTop.getSamplePoints(cols + 1, inrTopAr);
        inrBtm.getSamplePoints(cols + 1, inrBtmAr);
        inrRt.getSamplePoints(rows + 1, inrRtAr);
        if(cols == 1 && rows > 1)
                // Draw horizontal bars only
                for (rowPos = 1; rowPos < rows; rowPos++)
                        // Get the start point and the end point from the array
                        sp = inrLeftAr.at(rowPos);
                        ep = inrRtAr.at(rowPos);
                        // from sp and ep calculate ll, lr ,ul, ur
                        vec.set(0, (frameThk / 2));
                        ll = sp - vec;
                        lr = ep - vec;
                        ul = sp + vec;
                        ur = ep + vec;
                        barAr.append(ll);
                        barAr.append(lr);
                        barAr.append(ur);
                        barAr.append(ul);
                        if(!drawIntBar(pBlkTableRecord, barAr))
                                acutPrintf("\nError drawing internal horizontal frame member. ");
                }// for
        }// if
        if(rows == 1 && cols > 1)
                // Draw vertical bars only
                for (colPos = 1; colPos < cols; colPos++)
                        sp = inrBtmAr.at(colPos);
                        ep = inrTopAr.at(colPos);
                        vec.set((frameThk / 2), 0);
                        ll = sp - vec;
                        lr = sp + vec;
                        ul = ep - vec;
                        ur = ep + vec;
                        barAr.append(ll);
                        barAr.append(lr);
                        barAr.append(ur);
                        barAr.append(ul);
                }// for
        }// if
        if(rows > 1 && cols > 1)
                for(rowPos = 1; rowPos < rows; rowPos++)
                        for(colPos = 1; colPos <= cols; colPos++)
                                sp.x = inrBtmAr.at(colPos - 1).x;
                                sp.y = inrLeftAr.at(rowPos).y;
                                ep.x = inrBtmAr.at(colPos).x;
                                ep.y = inrLeftAr.at(rowPos).y;
                                // Calculate ll, lr, ul, ur
                                if(colPos == 1)
                                        ll = sp - vec;
                                        ul = sp + vec;
                                        vec.set( -(frameThk / 2), -(frameThk / 2));
                                        lr = ep + vec;
                                        vec.set( -(frameThk / 2), (frameThk / 2));
                                        ur = ep + vec;
                                        // Add the point to the barAr array
                                        barAr.append(ll);
                                        barAr.append(lr);
                                        barAr.append(ep);
                                        barAr.append(ur);
                                        barAr.append(ul);
                                else if(colPos == cols)
                                        vec.set((frameThk / 2), (frameThk / 2));
                                        ul = sp + vec;
                                        vec.set((frameThk / 2), -(frameThk /2));
                                        ll = sp + vec;
                                        lr = ep - vec;
                                        ur = ep + vec;
                                        barAr.append(sp);
                                        barAr.append(ll);
                                        barAr.append(lr);
                                        barAr.append(ur);
                                        barAr.append(ul);
                                else
                                        ul = sp + vec;
                                        ll = sp + vec;
                                        ur = ep + vec;
                                        lr = ep + vec;
                                        barAr.append(sp);
                                        barAr.append(ll);
                                        barAr.append(lr);
                                        barAr.append(ep);
                                        barAr.append(ur);
                                        barAr.append(ul);
                        }// for
                        colPos = 1;
                }// for
                for(colPos = 1; colPos < cols; colPos++)
                        for(rowPos = 1; rowPos <= rows; rowPos++)
                                sp.x = inrBtmAr.at(colPos).x;
                                sp.y = inrLeftAr.at(rowPos - 1).y;
                                if(rowPos == 1)
                                        ll = sp - vec;
                                        lr = sp + vec;
                                        ul = ep + vec;
                                        vec.set((frameThk / 2), -(frameThk / 2));
                                        ur = ep + vec;
                                        barAr.append(ll);
                                        barAr.append(lr);
                                        barAr.append(ur);
                                        barAr.append(ep);
                                        barAr.append(ul);
                                else if(rowPos == rows)
                                        ul = ep - vec;
                                        ur = ep + vec;
                                        vec.set ( -(frameThk / 2), (frameThk / 2));
                                        ll = sp + vec;
                                        vec.set ( (frameThk / 2), (frameThk / 2));
                                        lr = sp + vec;
                                        barAr.append(sp);
                                        barAr.append(lr);
                                        barAr.append(ur);
                                        barAr.append(ul);
                                        barAr.append(ll);
                                else
                                        vec.set((frameThk / 2), (frameThk /2));
                                        lr = sp + vec;
                                        ul = ep - vec;
                                        ll = sp + vec;
                                        ur = ep - vec;
                                        barAr.append(sp);
                                        barAr.append(lr);
                                        barAr.append(ur);
                                        barAr.append(ep);
                                        barAr.append(ul);
                                        barAr.append(ll);
                        }// for
                        rowPos = 1;
                }// for
        }// if
// Get and Set functions
int RectWindow::getWindowRows() const
        return rows;
int RectWindow::getWindowCols() const
        return cols;
double RectWindow::getWindowHeight() const
        return rectFrameHt;
double RectWindow::getWindowLength() const
        return rectFrameLen;
AcGePoint2d RectWindow::getWindowStartPoint() const
        return lowLeftPt;
double RectWindow::getRectFrameThk() const
        return rectFrameThk;
double RectWindow::getIntrFrameThk() const
        return intrFrameThk;
void RectWindow::setWindowRows(int rowQty)
        rows = rowQty;
void RectWindow::setWindowCols(int colQty)
        cols = colQty;
void RectWindow::setWindowHeight(double windHeight)
        rectFrameHt = windHeight;
void RectWindow::setWindowLength(double windLength)
        rectFrameLen = windLength;
void RectWindow::setWindowStartPoint(AcGePoint2d lowLeftPoint)
        lowLeftPt = lowLeftPoint;
Adesk::Boolean RectWindow::drawRectFrame(AcDbBlockTableRecord* pBlkTableRecord,
        AcDbPolyline* pBar;
        AcGePoint2d vrtxPt;
        AcDbObjectId plineId;
        Acad::ErrorStatus es;
        pBar = new AcDbPolyline(intBarAr.length());
        for(int count = 0; count < intBarAr.length(); count++)
                vrtxPt = intBarAr.at(count);
                pBar->addVertexAt(count, vrtxPt);
        pBar->setClosed(Adesk::kTrue);
        es = pBlkTableRecord->appendAcDbEntity(plineId, pBar);
        if(es != Acad::eOk)
                acutPrintf("\nError in drawing frame member. ");
                if(pBar != NULL)
                        delete pBar;
                return Adesk::kFalse;
        pBar->close();
        return Adesk::kTrue;
发表于 2004-5-15 10:56:07 | 显示全部楼层
没包含正确的头文件所导致的问题,在.cpp中加入#include "stdafx.h"即可了
 楼主| 发表于 2004-5-16 02:07:03 | 显示全部楼层
谢谢指点,问题已经解决。导入文件时弄错了
发表于 2004-5-18 14:01:53 | 显示全部楼层
frankzht ,像您请教一下,你自定义类画一个图形,是否可以画出不同与CAD给出的line spline arc等基本图形单元?
发表于 2005-8-16 02:48:59 | 显示全部楼层
那么又如何去调用自定义类呢
GMT+8, 2026-11-6 02:45 , Processed in 0.548227 second(s), 40 queries , Gzip On.
