查看: 1126|回复: 2
[原创]:改变Lightweightpolyline的绘制方向
已领礼包: 593个
发表于 2005-8-25 18:17:13 | 显示全部楼层 |阅读模式
程序写的比较简单,还可以增加在起点处显示一个方向箭头就更明显了
  1. ;;reverse Lwpolyline
  2. (defun c:t1 (/ e el el1 el2 el3 el4 el5)
  3.   (if (and (setq e (car (entsel "\nSelect Lwpolyline: ")))
  4.            (= (cdr (assoc 0 (setq el (entget e)))) "LWPOLYLINE")
  5.       )
  6.     (progn
  7.       (setq el1        (vl-remove-if-not
  8.                   '(lambda (x) (vl-position (car x) '(10 40 41 42)))
  9.                   (member (assoc 10 el) el)
  10.                 );_ property of coordinate (point startwidth endwidth bulge ...)
  11.             el4        (mapcar        '(lambda (x) (cons (car x) (- (cdr x))))
  12.                         (reverse (vl-remove-if-not
  13.                                    '(lambda (x) (= (car x) 42))
  14.                                    el1
  15.                                  )
  16.                         )
  17.                 );_ Bulge of every coordinate
  18.             el2        (reverse (cdr (member (assoc 10 el) (reverse el))));_ header dxf of lwpline
  19.       )
  20.       (setq el4 (append (cdr el4) (list (car el4))));_ reset bulge of coordinates
  21.       (while (> (length el1) 3)
  22.         (if el3
  23.           (setq        el3
  24.                  (append
  25.                    (list
  26.                      (list (car el1) (cadr el1) (caddr el1) (cadddr el1))
  27.                    )
  28.                    el3
  29.                  )
  30.           )
  31.           (setq
  32.             el3        (list
  33.                   (list (car el1) (cadr el1) (caddr el1) (cadddr el1))
  34.                 )
  35.           )
  36.         );_ ((point startwidth endwidth bulge) ...)
  37.         (setq el1 (cddddr el1))
  38.       )
  39.       (setq el5        (mapcar
  40.                   '(lambda (a b)
  41.                      (append (list (car a) (cadr a) (caddr a) b))
  42.                    )
  43.                   el3
  44.                   el4
  45.                 )
  46.       );_ reset coordinates
  47.       (entmod (append el2 (apply 'append el5)));_ updata pline
  48.     )
  49.   )
  50.   (princ)
  51. )
发表于 2005-8-27 09:35:45 | 显示全部楼层
改变多义线方向的程序论坛里早就有拉, 班主的有什么新创意?
已领礼包: 593个
 楼主| 发表于 2005-8-27 10:48:37 | 显示全部楼层
只看到过一个老外写的源码,好像是用的重画,上面的程序是利用 Pline 的DXF表,对Coordinate 和 Bulge 进行重排后更新 Pline
GMT+8, 2026-11-6 03:23 , Processed in 0.388758 second(s), 36 queries , Gzip On.
