查看: 827|回复: 3
[LISP函数]:用LISP出现了虚拟点的问题。
发表于 2004-5-15 18:37:30 | 显示全部楼层 |阅读模式
用了本论坛上的这段程序出现了一个奇怪的问题,请大家帮忙解决。
(defun c:spr (/ SD ED THS THSN THSH THS TAS NVSN NVS STEP X Y Z R A H)
(setq oldos (getvar "osmode"))
(setvar "osmode" 0)
(setq b1 (getpoint "基点"))
(setq SD (/ (getreal "弹簧起始直径: ") 2))
(setq ED (/ (getreal "弹簧終點直径: ") 2))
(setq THSN (getreal "圈数"))
(setq THSH (getreal "每圈高度"))
(setq THS (* THSN THSH))
(setq TAS (* 360 THSN))
(setq NVSN (getreal "间隔角度"))
(setq NVS (+ (fix (/ TAS NVSN)) 1))
(setq STEP (- NVS 1))
(setq X (/ (- ED SD) STEP))
(setq Y (/ THS STEP))
(setq Z (/ TAS STEP))
(setq bb (caddr b1))
(setq R SD)
(setq A 0)
(setq H 0)
(setvar "CMDECHO" 0)
(command "UCS" "O" B1)
(command "3DPOLY"
(strcat (rtos R) "<" (rtos A) "," (rtos H))
(repeat STEP
(setq A (+ A Z))
(setq H (+ H Y))
(setq R (+ R X))
(command (strcat (rtos R) "<" (rtos A) "," (rtos H)))
(command "")
(setvar "CMDECHO" 1)
(setvar "osmode" oldos)
(princ)
发表于 2004-5-15 18:48:44 | 显示全部楼层
blipmode=0
发表于 2004-5-15 19:19:51 | 显示全部楼层
这种点重生成一下应该就没了吧??
发表于 2004-5-16 11:21:13 | 显示全部楼层
重生成下也行,改BLIPMODE也行。
GMT+8, 2026-11-5 03:56 , Processed in 0.499184 second(s), 39 queries , Gzip On.
