查看: 518|回复: 1
[求助]:选择易3.0问题,wkai 请进。
发表于 2004-5-17 23:46:47 | 显示全部楼层 |阅读模式
关于选择易使用角度的问题,你让我,
将过滤设置文件中的
("旋转角度" (ATOF (ANGTOS (DXF 50 ZF_SENT))))
修改为
("旋转角度" (rem(ATOF (ANGTOS (DXF 50 ZF_SENT)))360))
但我只找到easysel_filter.LSP文件,里面内容:
(("通用" ((0 "实体类型") (6 "实体线型") (8 "所在图层") (48 "线型比例") (62 "实体颜色") (370 "实体线宽"))) ("ARC" ((-4 "圆弧") (39 "实体厚度") (10 "圆心坐标") (40 "圆弧半径") (50 "起点角度") (51 "端点角度"))) ("CIRCLE" ((-4 "圆形") (39 "实体厚度") (10 "圆心坐标") (40 "圆形半径"))) ("LINE" ((-4 "直线段") (39 "实体厚度") (10 "起点坐标") (11 "终点坐标"))) ("ELLIPSE" ((-4 "椭圆") (10 "椭圆中心") (11 "长轴端点") (40 "长短轴比") (41 "开始参数") (41 "结束参数"))) ("INSERT" ((-4 "图块") (2 "图块名称") (41 "X 轴比例") (42 "Y 轴比例") (43 "Z 轴比例") (50 "旋转角度"))) ("LWPOLYLINE" ((-4 "复义线") (38 "复线标高") (39 "复线厚度") (43 "固定宽度") (70 "是否闭合" ((0 "不闭合") (1 "闭合"))) (90 "顶点个数"))) ("HATCH" ((-4 "图案填充") (2 "填充图案") (52 "填充角度") (41 "填充比例") (71 "边界关联" ((0 "不关联") (1 "关联"))) (76 "图案类型" ((0 "用户定义") (1 "预定义") (2 "自定义"))))) ("TEXT" ((-4 "文字") (1 "文字值") (7 "文字样式") (10 "插入点") (40 "文字高度") (50 "旋转角度") (51 "倾斜角度") (71 "文字镜像" ((0 "默认") (2 "文字反向") (4 "文字倒置"))) (72 "水平对正" ((0 "左对正") (1 "居中对正") (2 "右对正") (3 "对齐") (4 "中间") (5 "拟合"))) (73 "垂直对正" ((0 "基线对正") (1 "底端对正") (2 "居中对正") (3 "顶端对正"))))) ("MTEXT" ((-4 "多行文字") (1 "文字值") (7 "文字样式") (10 "插入点") (40 "文字高度") (50 "旋转角度") (51 "倾斜角度"))) ("SPLINE" ((-4 "样条曲线") (70 "曲线标志") (71 "曲线阶数") (71 "节点数") (73 "控制点数") (74 "拟合点数") (42 "节点公差") (43 "控制点公差") (44 "拟合公差"))) ("DIMENSION" ((-4 "尺寸标注") (1 "标注文字") (42 "测量值") (3 "标注样式") (70 "标注类型" ((32 "水平垂直") (33 "对齐标注") (34 "角度标注") (35 "直径标注") (36 "半径标注") (37 "三点角度") (38 "坐标标注"))))))
没有你所说的参数。请指点。
发表于 2004-5-18 09:34:40 | 显示全部楼层
你用的不是最新版的选择易~
没有附加过滤选项~
GMT+8, 2026-11-5 13:55 , Processed in 0.439436 second(s), 34 queries , Gzip On.
